"BDS" wrote:
Maybe he's not so smart after all :) Maybe not, but smart enough to see this one. On a calm day you can run and feel a wind on your face because you are moving across the ground as well as through the air. But, if you run on a treadmill there will be no wind because you are not moving through the air - the air is calm so it has no relative motion with respect to the ground. Neither do you when you run on a treadmill. True. Irrelevant, but true. Assume the airplane is on the conveyor and there is a 10 kt headwind, and assume we need 60 kts for takeoff. The only way to generate the additional 50 kts of airspeed is by moving across the ground at 50 kts. Right so far. If the airplane is standing still Hold that thought... because the conveyor is moving backwards at the same speed that the airplane is moving across the ground at Skip back up to see what speed you say the airplane is moving across the ground. Then go back to the original question and figure out what speed the conveyor must be moving when the airplane is not moving. If the conveyor keeps the airplane standing still relative to the ground, then it cannot take off. Yeah, but the original statement of the problem made no such claim. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
![]() "alexy" wrote If the conveyor keeps the airplane standing still relative to the ground, then it cannot take off. Yeah, but the original statement of the problem made no such claim. Alex - here is what the statement said: "An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) The plane cannot move forward - that means that it is standing still to me. BDS |
![]() "BDS" wrote in message m... "An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) The plane cannot move forward - that means that it is standing still to me. BDS You are taking the statement 'a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward' to mean that somehow there is a force being applied to the mass of the aircraft, equal and opposite the thrust generated by the propellor. The only place the treadmill can exert any force an the airplane is the only place the treadmill is touching the airplane: the wheels. Any motion of the treadmill belt will be translated into rotation of the wheels. This will not prevent the aircraft from moving forward, through the air and taking off. |
("Michael Ware" wrote)
You are taking the statement 'a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward' to mean that somehow there is a force being applied to the mass of the aircraft, equal and opposite the thrust generated by the propellor. The only place the treadmill can exert any force an the airplane is the only place the treadmill is touching the airplane: the wheels. Any motion of the treadmill belt will be translated into rotation of the wheels. This will not prevent the aircraft from moving forward, through the air and taking off. THE AIRPLANE WILL NOT MOVE. (That's my vote) The rotating wheels + gravity (Thank you Sir Isaac!) ANCHOR the plane to the treadmill. Plane/prop move forward, treadmill/wheels fall back. The plane is attached to the wheels. Try it in front of you with a ruler and a magic marker. That airplane is doing 150 mph down that runway, only the runway is really a treadmill which is matching that speed. End result is = to an Olympic sprinter on the same treadmill - I can stand next to him for his entire 10 second (27 mph) race. Montblack 83.7 (I thought some of double-digit people needed to be heard from. g) |
"Montblack" wrote in message
... ("Michael Ware" wrote) You are taking the statement 'a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward' to mean that somehow there is a force being applied to the mass of the aircraft, equal and opposite the thrust generated by the propellor. The only place the treadmill can exert any force an the airplane is the only place the treadmill is touching the airplane: the wheels. Any motion of the treadmill belt will be translated into rotation of the wheels. This will not prevent the aircraft from moving forward, through the air and taking off. That's one of the best so far. THE AIRPLANE WILL NOT MOVE. (That's my vote) The rotating wheels + gravity (Thank you Sir Isaac!) ANCHOR the plane to the treadmill. Plane/prop move forward, treadmill/wheels fall back. The plane is attached to the wheels. Try it in front of you with a ruler and a magic marker. That airplane is doing 150 mph down that runway, only the runway is really a treadmill which is matching that speed. End result is = to an Olympic sprinter on the same treadmill - I can stand next to him for his entire 10 second (27 mph) race. Lordy. BDS answered this pretty well. But, imagine that the plane is held still by a rope secured in front of the conveyor. That rope is attached to a strain guage that measures the force, in kg, say, that the moving conveyor exerts on the plane. This will increase with the speed of the conveyor, but let's use a reasonable number and we will see that the force is minimal since it's only whatever is converted to heat in the wheel bearings. Probably less than a few hundred watts. The amount of power required to move the plane forward will be more than required on a stationary runway by only this much. Dig? Montblack 83.7 (I thought some of double-digit people needed to be heard from. g) moo www.mensa.org |
"BDS" wrote:
"alexy" wrote If the conveyor keeps the airplane standing still relative to the ground, then it cannot take off. Yeah, but the original statement of the problem made no such claim. Alex - here is what the statement said: "An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) The plane cannot move forward - that means that it is standing still to me. If the plane does not move forward, how fast is the conveyor moving? Hint: "a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward." -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
