You will be paying a big price for retract, in initial cost,
maintenance and insurance. Extra speed for 1 to 2 hour trips doesn't amount to much. If the wife wants 2 doors, you should probably get two doors. |
On 5-Feb-2006, "Doug" wrote:
You will be paying a big price for retract, in initial cost, maintenance and insurance. Extra speed for 1 to 2 hour trips doesn't amount to much. If you fly over 100 hrs/year the savings in fuel costs with RG compared to a FG with similar performance will more than offset the added costs for maintenance and insurance. -- -Elliott Drucker |
John Theune wrote:
: I'd really like to see some number to support your conclusion. By my : estimates 100 hrs * 11 gals per hour = 1100 gal per year. RG decreases : fuel need by 5% or 55 gal * $3.50 = 192.50 per year in fuel savings. : From the numbers throw about by my aircraft owning buddies the delta in : ownership costs for a retract are much more then that. : Assumptions in above: Fuel burn is about the same for 180HP engines in : Comanche 180 and 172s with 180HP engine. Increased speed reduces need : for fuel by 5% by higher speed in cruise, climb fuel burn is the same. : Big YMMV is added ![]() Not to be too argumentative, but 5% might not be the right number. A quick example: http://www.risingup.com/planespecs/i...plane432.shtml http://www.risingup.com/planespecs/i...plane427.shtml That's a PA-28-180 vs. a PA-28-180R. Cruise of 119 kts vs. 141 kts. That's 18% improvement in speed. Others are similar around 15%. So, multiply your fuel savings by a factor of 3 and you get $600/year. That's starting to sound more in line with the additional costs of a gear swing every year, some more lube, and a replacement part averaging every 5 or so. Just food for thought. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Very good, I was hoping somebody could come up with better numbers then I
had. It looks like from your numbers the fuel savings come close to the extra maintenance costs so the insurance costs would swing the balance toward the FG model cost wise. I think the extra "sex appeal" of the RG might swing it back toward the RG side, but bottom line you can't argue for the RG just on cost savings over FG. Sorry, I'm late to this thread, but it's an interesting point you bring up. However, it's only applicable to what we might call "legacy aircraft" -- Pipers, Cessnas, Beechcraft, Navions, etc. All of the "modern" aircraft (Cirrus, Lancair, Diamond) are going with stiff legs, and don't appear to be paying much of a price penalty for doing so. Anyone care to venture a guess as to how much faster an SR-22 (for example) would go with retractable gear? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() On 8-Feb-2006, John Theune wrote: I'd really like to see some number to support your conclusion. By my estimates 100 hrs * 11 gals per hour = 1100 gal per year. RG decreases fuel need by 5% or 55 gal * $3.50 = 192.50 per year in fuel savings. From the numbers throw about by my aircraft owning buddies the delta in ownership costs for a retract are much more then that. Assumptions in above: Fuel burn is about the same for 180HP engines in Comanche 180 and 172s with 180HP engine. Increased speed reduces need for fuel by 5% by higher speed in cruise, climb fuel burn is the same. Big YMMV is added ![]() I said "RG compared to a FG WITH SIMILAR PERFORMANCE..." For comparison to an Arrow or Sierra than burns about 10.5 GPH at 75%, that would be something like a Skylane or Dakota that burns about 3 GPH more. For 100 hrs, that's 300 gallons, or well over $1000 at today's fuel prices. Additional maintenance costs for an RG will probably run about $300/yr. (This is based upon my experience and what my A&P told me.) Insurance difference could be wildly variable depending upon pilot experience and IR status, In my case, the extra premium for RG runs about $500/yr. In other words, the cost of folding the gear is more than offset by the cost of the fuel needed to drag it through the air. -Elliott Drucker |
Comanche accident averted last evening | [email protected] | Piloting | 23 | April 13th 05 10:02 AM |
REAL BUDGET BUSTER | Cribsheet | Piloting | 2 | December 18th 04 10:02 PM |
Commanche alternatives? | John Cook | Military Aviation | 99 | March 24th 04 03:22 AM |
Commanche alternatives? | Kevin Brooks | Naval Aviation | 23 | March 24th 04 03:22 AM |
RAH-66 Comanche helicopter could face budget cuts in 2005 | Larry Dighera | Military Aviation | 0 | November 19th 03 02:18 PM |
