176. cjcampbell
Feb 6, 9:41 pm show options Newsgroups: rec.aviation.student, rec.aviation.piloting From: "cjcampbell" - Find messages by this author Date: 6 Feb 2006 18:41:35 -0800 Local: Mon, Feb 6 2006 9:41 pm Subject: Can a Plane on a Treadmill Take Off? Reply | Reply to Author | Forward | Print | Individual Message | Show original | Report Abuse "cjcampbell" wrote Okay, I see why the plane moves forward normally no matter how fast the treadmill is going and even why it would not work in an automobile. Well, not exactly. This dead horse is fun to beat. Suppose I tell you the car is going forward at 60 mph. That means the belt is going the other way at 60, right? The speedometer would be indicating 120. The OP said the belt is moving backward as fast as the whatever is moving forward. When you substitute real numbers into the thing it becomes more clear. Or not. |
![]() Tony wrote: 176. cjcampbell Feb 6, 9:41 pm show options Newsgroups: rec.aviation.student, rec.aviation.piloting From: "cjcampbell" - Find messages by this author Date: 6 Feb 2006 18:41:35 -0800 Local: Mon, Feb 6 2006 9:41 pm Subject: Can a Plane on a Treadmill Take Off? Reply | Reply to Author | Forward | Print | Individual Message | Show original | Report Abuse "cjcampbell" wrote Okay, I see why the plane moves forward normally no matter how fast the treadmill is going and even why it would not work in an automobile. Well, not exactly. This dead horse is fun to beat. Suppose I tell you the car is going forward at 60 mph. That means the belt is going the other way at 60, right? The speedometer would be indicating 120. The OP said the belt is moving backward as fast as the whatever is moving forward. When you substitute real numbers into the thing it becomes more clear. Or not. Apparently not to everyone. :-) The speedometer would indicate 60. |
If the car had an airspeed indicator it would, I agree, indicate 60. In
the model I suggested the car is moving to the north at 60, the treadmill to the south at 60, and the speedometer will indicate 120. |
![]() Tony wrote: If the car had an airspeed indicator it would, I agree, indicate 60. In the model I suggested the car is moving to the north at 60, the treadmill to the south at 60, and the speedometer will indicate 120. If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. An aircraft would need no additional power to accelerate to 60 on a treadmill. |
I agree that it would not require much more additional power to overcome the
additional friction drag of wheels spinning at twice the normal speed but it is not zero. -- ------------------------------- Travis "cjcampbell" wrote in message oups.com... Tony wrote: If the car had an airspeed indicator it would, I agree, indicate 60. In the model I suggested the car is moving to the north at 60, the treadmill to the south at 60, and the speedometer will indicate 120. If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. An aircraft would need no additional power to accelerate to 60 on a treadmill. |
"cjcampbell" wrote:
Tony wrote: If the car had an airspeed indicator it would, I agree, indicate 60. In the model I suggested the car is moving to the north at 60, the treadmill to the south at 60, and the speedometer will indicate 120. If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. Nope. The same energy as it would take to accelerate to 60 on an ordinary road, assuming that the mechanical system of the conveyor is taking care of its motion. The work being done is to accelerate the same mass to the same velocity in either case. If the car is providing the energy to move the conveyer (reasonable, if its mass and friction loads are less than those of the car), how much additional energy it takes will depend on the conveyer. An aircraft would need no additional power to accelerate to 60 on a treadmill. True. The same laws of physics apply to the car as well. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
Accelerating the mass to the same velocity requires the same energy
regardless of what the surface is doing but wheel drag cannot be totally ignored. Why did you suggest that the car is providing the energy for the conveyor? This would imply wheels with normal friction behavior but a frictionless conveyor with a brake. The conveyor needs to be frictionless for you theory that no additional energy is needed but a brake to keep it from being flung backwards preventing forward motion of the car. Since the same frictionless conveyor would get dragged along under an accelerating plane, it seems like a strange experimental model. A conveyor that is motor driven but controlled makes a more consistent model. I agree that very little additional thrust is necessary (either from the wheels of a car or from the propeller of a plane) to counteract the counter-moving conveyor. But some additional energy will be needed due to the additional drag provided by the faster spinning wheels (both for the car and the plane). -- ------------------------------- Travis "alexy" wrote in message ... "cjcampbell" wrote: Tony wrote: If the car had an airspeed indicator it would, I agree, indicate 60. In the model I suggested the car is moving to the north at 60, the treadmill to the south at 60, and the speedometer will indicate 120. If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. Nope. The same energy as it would take to accelerate to 60 on an ordinary road, assuming that the mechanical system of the conveyor is taking care of its motion. The work being done is to accelerate the same mass to the same velocity in either case. If the car is providing the energy to move the conveyer (reasonable, if its mass and friction loads are less than those of the car), how much additional energy it takes will depend on the conveyer. An aircraft would need no additional power to accelerate to 60 on a treadmill. True. The same laws of physics apply to the car as well. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
"Travis Marlatte" wrote:
Accelerating the mass to the same velocity requires the same energy regardless of what the surface is doing but wheel drag cannot be totally ignored. True. Another factor that I ignored as being insignificant (and this applies to the plane or car) is the extra energy it takes to provide the angular acceleration of the wheel to higher rotational velocities. E.g, at speed, one car includes 4 flywheels spinning with rim velocities of 60mph, while the other car has 4 flywheels spinning with rim velocities of 120mph. This additional energy need will cause slower acceleration if the same power is available. Why did you suggest that the car is providing the energy for the conveyor? We've had one recent poster who apparently thought that the power source for moving the conveyer was key to the problem. I'm not suggesting THAT the car was providing the energy, but only examining what IF it did. This would imply wheels with normal friction behavior but a frictionless conveyor with a brake. Not needed. As long as the conveyer has less friction and mass than the car, and has a brake to control its speed, the car can power it. And how much power that absorbs will determine how much the car's acceleration is lowed down. At the limit, it is CJ's speculation of the car's acceleration to 120 (on the speedometer) matching a regular road acceleration to 120. A conveyor that is motor driven but controlled makes a more consistent model. Agreed. I agree that very little additional thrust is necessary (either from the wheels of a car or from the propeller of a plane) to counteract the counter-moving conveyor. But some additional energy will be needed due to the additional drag provided by the faster spinning wheels (both for the car and the plane). And to accelerate the wheels to a higher angular velocity, assuming they are not massless. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
oups.com... If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. No, not really. Most of the horsepower of a car is used to counteract aerodynamic drag, at that speed. Unless the treadmill (conveyor belt, whatever) somehow gets the air above it to move rearward along with the belt, the car barely has to use more power than it would accelerating to, and cruising at, 60 mph on a regular road. It absolutely doesn't require anywhere near as much power as it would to travel at 120 mph on a regular road. Pete |
![]() cjcampbell wrote If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. An aircraft would need no additional power to accelerate to 60 on a treadmill. To which I'll note that you're on the right track, but remember kinetic energy varies as velocity squared: it takes 4 times the energy (at non relativistic velocities) to get to 120 as it does to 60: actually a lot more than that because windage losses and the like are not linear, either. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
