Can a Plane on a Treadmill Take Off?
Old February 8th 06, 06:00 AM posted to rec.aviation.student,rec.aviation.piloting
Default Can a Plane on a Treadmill Take Off?
Interesting question. Are you suggesting a wind machine that is capable of
creating a wind that matches the conveyor?
Let's start with no wind. The plane must achieve lift off speed relative to
the stable air mass to take off.
airspeed = Vlo
Conveyor moving = - Plane motion relative to ground
Conveyor moving = -xVlo (relative to ground)
airspeed = Vlo = Plane motion relative ground + headwind = xVlo + 0Vlo;
solve for x = 1
Wheels spinning = Plane motion - conveyor motion = xVlo - -x Vlo = 2 Vlo
Plane will liftoff at an airspeed that matches its groundspeed of Vlo. The
conveyor is moving backward also at Vlo. The wheels are spinning at twice
that speed.
Now with a headwind. The plane must still achieve lift off speed relative to
the air mass which is now an accelerating headwind.
airspeed = Vlo
Conveyor moving = -x Vlo (relative to ground)
Headwind = Conveyor moving
Headwind = - x Vlo (relative to ground)
airspeed = Vlo = Plane motion relative ground - headwind = x Vlo + x
Vlo; x = 1/2
Wheels spinning = Plane motion - conveyor motion = 1/2 Vlo - -1/2 Vlo =
Vlo
The plane will be able to lift off at 1/2 the ground speed than under normal
circumstances. The wheels are spinning at twice that speed which is just
Vlo. It would be feasible to construct both such a conveyor and the wind
machine.
Now with a tailwind. The plane must still achieve lift off speed relative to
the air mass which is now an accelerating tailwind.
airspeed = Vlo
Tailwind = - Converyor moving
Tailwind = x Vlo (relative to ground)
airspeed = Vlo = Plane motion relative ground - Tailwind = x Vlo - x
Vlo; ******** No solution ********
With this simple formula, the plane will never take off but will continue to
accelerate (until the wheels disintegrate) since the thrust of the engine is
acting on the air mass which is accelerating as a tailwind. Very much the
dog chasing his tail.
Assumptions:
As with most things in life, we need a point of reference. Almost any
will do but I chose the ground upon which the conveyor belt is built and we
are standing watching. It is from this reference that the conveyor belt's
velocity (backwards) is derived.
I arbitrarily chose the positive sign of velocity in the direction of
the plane motion.
Travis
"darthpup" wrote in message
Must consider the wind at time of experiment. If wind is same speed as
conveyor then real problem??
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
Navy sues man for plane he recovered in swamp marc Owning 6 March 29th 04 12:06 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
