oxygen tank
Old February 8th 06, 04:57 PM posted to rec.aviation.soaring
Default oxygen tank
5Z wrote:
I got my filling hose and gauge from an online scuba supplier as the
local gas house didn't want to sell such supplies to "the public" -
whatever that means.
Divers do a lot of transfilling and gas mixing for deep diving, etc.
-Tom
meaning that working with compressed gas is hazardous and they don't
want the liability exposure. I've worked around compressed gases for
years and part of OSHA mandatory safety training is required on an
annual basis.
As you are probably aware, there is lot of heat generated when filling
the cylinder. Hence the need for hydrostatic testing. The cylinder
self destructs if it fails the test.
I cringe every time I see a p/up truck with regulators on cylinders on
the road, instead of properly capped. I had the opportunity to see
what happens when a large O2 welding cylinder which was unsecure in the
bed of a truck, with no cap, fall off and knock the valve off.
Old February 9th 06, 10:41 PM posted to rec.aviation.soaring
Default oxygen tank
On 8 Feb 2006 08:57:08 -0800, "chipsoars"
the cylinder.
I don't really know how to "generate" heat by transferring a
compressed gas from one storage container to another; yes, the heat of
compression will cause the filled cylinder to get warmer (and the
supplying source to cool), but at the rates to which I am accustomed,
it doesn't get even uncomfortably warm to touch.
Well, ok? ... Huh?
The cylinder self destructs if it fails the test.
I've personally done only 4 hydrostatic tests of cylinders; one failed
because the recovery was too little. We filled with deionized water,
pressurized to 5/3 stamped pressure measuring water needed to do so,
then verified that we got (man, I've forgotten that number, think it
is 95%) out dropping back to atmospheric .
I've witnessed perhaps 200; none that failed was exciting. What other
method of hydrostatic testing is used?
Now the one talked about in every scuba shop in the country ...
1960's, I'd guess? ... when a guy's buddy told him he'd give him a
GREAT paint job on his cylinder at his "paint" line at work ... and
the freshly powder coated cylinder was being filled with air ... the
heat treated aluminum tank was annealed during powder coating and my
memory is that the explosion killed and injured and did lots of
property damage.
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Reprise - Oxygen concerns Neptune Soaring 20 May 27th 04 03:27 PM
Need oxygen information Neptune Soaring 3 May 10th 04 06:06 AM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
