So how far off an airway is an aircraft when they are following a GPS flight
plan with every intersection and VOR? Is there an article or study somewhere that includes metrics to back it up? For example, "a non-WAAS GPS-derived line direct btween two intersection xx miles away will differ from the airway between those same two intersections by x.x statute miles." How do the error allowances play into this? Marco "nooneimportant" wrote in message news:gPgGf.57025$V.55301@fed1read04... But the workaround is very easy... if V123 goes throug the abc bca and cab VOR's then you creat the flight plan wiht waypoints at each vor or intersection on the route. If you are off airway and choose to fly TO the airway, simply go to the FPL screen, select teh NEXT fix on the plan and activate the leg. Your CDI will be in relation to that leg, not a direct line to the fix. Tho i do wish you could simply put AIRPORTA D- abcVOR-V123-cabVORD D- AIRPORTB. But it only saves a few entries on most flights. And in reality I've NEVER gotten what i was cleared for IFR wise when i filed /G.... I MIGHT get to the second fix, then its "Proceed Direct AIRPORTB" or something similar that cuts off about 20 minutes of flying time. "Robert M. Gary" wrote in message oups.com... That's one major limitation of the Garmin products. Not having airways is very, very irritating especially to those of us that fly in high traffic areas (such as L.A.). When an approach controller machine guns you with a new 6 airway route without giving you any intersections it leaves you jumping for your chart. When I had my king unit, I would just put the pink airplane line on top of the blue airway line and I was done. I hope Garmin addresses this someday. -Robert Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
plan with every intersection and VOR? If you miss entering one of the bends in the airway it could be 20 or 30 miles off. The point is that you are now back to the 1970's, grabbing your enroute chart and trying to figure out all the airway bends when you could have a 1990's handheld GPS (King Skymap IIIC) and it would do it all for you. -Robert |
"Marco Leon" mmleon(at)yahoo.com wrote:
So how far off an airway is an aircraft when they are following a GPS flight plan with every intersection and VOR? Is there an article or study somewhere that includes metrics to back it up? For example, "a non-WAAS GPS-derived line direct btween two intersection xx miles away will differ from the airway between those same two intersections by x.x statute miles." How do the error allowances play into this? Since unaugmented GPS (not using WAAS) is accurate to 10 meters or so (plus/minus) and an airway is plus/minus four MILES (or is is two?) the navigation source (GPS) is not a major error source. Ron Lee |
On 02/09/06 08:09, Ron Lee wrote:
"Marco Leon" mmleon(at)yahoo.com wrote: So how far off an airway is an aircraft when they are following a GPS flight plan with every intersection and VOR? Is there an article or study somewhere that includes metrics to back it up? For example, "a non-WAAS GPS-derived line direct btween two intersection xx miles away will differ from the airway between those same two intersections by x.x statute miles." How do the error allowances play into this? Since unaugmented GPS (not using WAAS) is accurate to 10 meters or so (plus/minus) and an airway is plus/minus four MILES (or is is two?) the navigation source (GPS) is not a major error source. An airway is 8 miles wide (4 miles on either side of the centerline). One of the problems is that GPS accounts for magnetic variations differently than the VORs do. Also I don't think GPS accounts for the fact that the VOR radial are not exactly aligned with magnetic north (what is this called? variance? I can't remember - it's documented in the A/FD). GPS position errors would be on top of all this. Ron Lee -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
One of the problems is that GPS accounts for magnetic variations differently than the VORs do. Also I don't think GPS accounts for the fact that the VOR radial are not exactly aligned with magnetic north (what is this called? variance? I can't remember - it's documented in the A/FD). This would have an effect only if the procedure has you tracking a defined VOR radial. There might be some such procedures, but I can't think of any at the moment. All the airway segments (that's what we're talking about, right?) that I know of have a defined point at each end of the segment. There is one and only one great circle route between those two points. It's the same great circle whether you follow it with a GPS or a VOR receiver. Dave |
Dave Butler wrote:
Mark Hansen wrote: All the airway segments (that's what we're talking about, right?) that I know of have a defined point at each end of the segment. There is one and only one great circle route between those two points. It's the same great circle whether you follow it with a GPS or a VOR receiver. The charted airway mag bearing is the issue. It was developed from one source and Garmin, et al, may or may not use the same source. But, you're right, it's no big deal, unless the airway has an intersection course change of some magnitude. |
The issues with mag var and declination are easily absorbed by the huge
widths of the victor airway. The problem is airway course changes between facilities. An autoload of the airway not only solves that issue, it keeps everything "spot on" and has all the non-compulsory reporting points loaded and ready, if needed. |
Ron Lee wrote:
"Marco Leon" mmleon(at)yahoo.com wrote: So how far off an airway is an aircraft when they are following a GPS flight plan with every intersection and VOR? Is there an article or study somewhere that includes metrics to back it up? For example, "a non-WAAS GPS-derived line direct btween two intersection xx miles away will differ from the airway between those same two intersections by x.x statute miles." How do the error allowances play into this? Since unaugmented GPS (not using WAAS) is accurate to 10 meters or so (plus/minus) and an airway is plus/minus four MILES (or is is two?) the navigation source (GPS) is not a major error source. Ron Lee VOR airway's primary is plus/minues 4 to 51 miles, where it expands at 4.5 degrees. The secondary is an additional 2 miles, which expands at 6.7 degrees at 51 miles. |
Odd clearance -- airway given twice | Roy Smith | Instrument Flight Rules | 15 | September 20th 05 03:32 PM |
GNS430 Installation | Wayne Sweet | Home Built | 0 | October 3rd 04 04:39 AM |
B-RNAV with GNS430 | Daniel Hofer | Instrument Flight Rules | 1 | September 1st 04 04:12 PM |
Wanted: Blank Datacard Garmin GNS430 | Marco Leon | Piloting | 4 | August 31st 04 06:20 PM |
Wanted: Blank Datacard Garmin GNS430 | Marco Leon | Owning | 3 | August 31st 04 03:33 PM |
