#261
Not true. The original problem statement was this:
"An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) I restated it, but either version clearly implies that the airplane must be moving for the conveyor to be moving. Sure if the plane isn't moving, it won't take off. But if the conveyor is moving, the plane must be moving in the opposite direction, because that's what the problem says. The problem never said that the conveyor somehow moves in a way that cancels the plane's forward motion. As many have stated, unless the pilot is applying the brakes, so that there is friction between the wheels and the belt, the movement of the conveyor has nothing to do with the speed of the plane. All the problem says is that the conveyor is moving in the opposite direction at the same speed as the plane. -- Bob (Chief Pilot, White Knuckle Airways) "Peter Duniho" wrote in message ... "Bob Chilcoat" wrote in message ... On the contrary, the problem clearly states that the conveyor is moving at the speed that the plane is moving (but in the opposite direction). The statement "the conveyor is moving at the speed that the plane is moving" (the one you say the problem states) is a very different statement from "which always reduces the plane's forward movement to zero" (the statement Thomas responded to). How is your post contrary to Thomas'? Pete |
#262
My post is not contrary to Thomas', it reinforces his comment. My statement
is a further rebuttal to the statement thomas was responding to. -- Bob (Chief Pilot, White Knuckle Airways) "Peter Duniho" wrote in message ... "Bob Chilcoat" wrote in message ... On the contrary, the problem clearly states that the conveyor is moving at the speed that the plane is moving (but in the opposite direction). The statement "the conveyor is moving at the speed that the plane is moving" (the one you say the problem states) is a very different statement from "which always reduces the plane's forward movement to zero" (the statement Thomas responded to). How is your post contrary to Thomas'? Pete |
#263
"Tony" wrote in message
oups.com... We don't have enough information. What color is the airplane? What ratings does the pilot have? How many postings will this thread have before it dies? Also need more information on the treadmill. Is this the same type of treadmill that a guy named George walks his dog on, a cat jumps onto the treadmill and the dog starts chasing it causing the treadmill to speed up. George falls down on the treadmill but isn't thrown off... Hence, if George can't get off the treadmill, how can a plane??? |
#264
"Jim Macklin" wrote:
"alexy" wrote in message news ![]() wrote: | | | b. If the treadmill was powered [and everything was timed | in sync] the belt would be accelerating rearward and the | engine thrust would be pulling forward at the same rate, | thus the airframe mounted wigs would have near zero airspeed | and lift and would not fly. | | Just to "set the hook" here, are you saying that it will be possible | to have the conveyer move backwards fast enough that the plane remains | still, even under full power, and with no brakes on? sure, in our imaginary world. in the real world nobody will try this so mechanical limitations are unimportant. Okay, if that happens (the treadmill moving fast enough backwards to offset the thrust of the plane's propulsion system), how fast will the plane be moving forward? ? Given your answer to that, how fast will the conveyor be moving, given that the conveyer moves backward at the same speed at which the plane moves forward? Given your answer to that, what's to stop the plane from moving forward? The problem says the conveyer moves at the same speed as the plane. How in the world can it, by moving the same speed as the plane, prevent the plane's motion? One more thought: I'm getting ready to get an emissions test on my car. They put the back wheels on rollers, put it in gear, and run the engine up until the indicated speed is, e.g., 30mph. This seems to be the situation that you and a few others picture happening here. But in my case, my car is NOT moving forward, so I would NOT say that the roller under my wheels was moving at the same speed as my car. It is turning at the same rate as my car's wheels, which is a whole 'nother kettle of fish. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#265
... My post is not contrary to Thomas', it reinforces his comment. My statement is a further rebuttal to the statement thomas was responding to. You made two replies to my own post, which are in contradiction with each other. Furthermore, if you intend to reinforce a person's post, I suggest you not begin the post with the words "on the contrary". |
#266
Bob,
On the contrary, the problem clearly states that the conveyor is moving at the speed that the plane is moving (but in the opposite direction). Huh? The OP was saying "If you have a conveyoer which always reduces the airplane's movement to zero", to which I said "the original question doesn't say that". What does you statement have to do with what I said, let alone it being "contrary"? -- Thomas Borchert (EDDH) |
#267
Peter,
Furthermore, if you intend to reinforce a person's post, I suggest you not begin the post with the words "on the contrary". I didn't get it, either ;-) -- Thomas Borchert (EDDH) |
#268
![]() "Tony" wrote in message oups.com... We don't have enough information. What color is the airplane? What ratings does the pilot have? How many postings will this thread have before it dies? Was there a flight plan filed? Allen |
#269
Thomas Borchert wrote:
Peter, Furthermore, if you intend to reinforce a person's post, I suggest you not begin the post with the words "on the contrary". I didn't get it, either ;-) Easy, boys! Bob, it took me a couple of readings initially to realize that what you meant was "I agree with your comment, Thomas, and furthermore, to the contrary of the post to which you were replying...". As Perter says, when you start a post with "on the contrary" it sounds like you are disagreeing with the post to which you were replying. Then it's left to the reader to puzzle out whether you didn't understand the post to which you were replying (and thought you were disagreeing when in fact you were agreeing) or whether it was just a careless wording, as I assumed. But, semantics aside, it sounds like the four of us are solidly on the side of a plane not just sitting stationary, spinning its wheels on a conveyer! -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#270
"Peter Duniho" wrote:
"alexy" wrote in message news ![]() Just to "set the hook" here, are you saying that it will be possible to have the conveyer move backwards fast enough that the plane remains still, even under full power, and with no brakes on? I thought you had already established that it would be possible, and that the treadmill speed is "somewhat below the speed of light"? You didn't appear to solve the "materials integrity" aspect of the problem, but that seems like a minor quibble. ![]() You know, there is a fallacy in my reasoning that I am surprised no one has called me on. We are used to aerodynamic drag, which increases as the square of velocity. But if my memory of high school physics is correct (and if Newton hasn't changed his mind in the last 40 yearsg) the friction between two bodies is a coefficient of friction times the force normal to the motion (i.e., the weight of the plane). No component for the relative velocities of the two bodies! So the drag due to wheels is small, and speeding up the conveyer will not increase that small drag, at least until you get to the "noise" elements that make the idealized drag model imperfect. I guess that by _accelerating_ the conveyer, you could make the plane use all of its power for a short while providing the angular acceleration to the wheels, but you very quickly get to relativistic speeds, without ever reaching a steady state tradeoff for the engine/prop's thrust. Much easier to just read the problem as stated, and have the conveyer only move as fast backwards as the plane moves forward!! -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
