Mid-air in San Diego
Old February 9th 06, 12:50 PM posted to rec.aviation.piloting
Default Mid-air in San Diego
Grumman-581 wrote:
"Flyingmonk" wrote in message
One of the aircraft was apparently an experimental Cessna plane,
according
to George Wood of the Heartland Fire Department.
Didn't know Cessna is still experimenting with airplanes.
Knowing how accurate the media is, that probably just means an experimental
high wing aircraft... Technically, if someone was developing an STC for a
certified plane and doing test flights, wouldn't it be classified as an
'experimental' at that point?
You think the press is smart enough to know that?
Old February 9th 06, 07:55 PM posted to rec.aviation.piloting
"Rachel" wrote in message
Nawh, I believe that one should not underestimate the stupidity of the
press...
Old February 10th 06, 10:32 PM posted to rec.aviation.piloting
http://www.signonsandiego.com/news/m...7m10crash.html :
"The Cessna 172RG with the student and instructor left Gillespie Field
in El Cajon first, and the second plane took off about a minute later
from the same airport. The crash occurred about three miles away at an
altitude of 2,300 feet.
Dunks said the student pilot was flying under instrument flight rules,
learning how to control the plane in inclement weather."
"Kupiec, the pilot of the other plane [a Cessna 182], had started
flying from Montgomery Field and stopped off at Gillespie Field before
resuming his flight."
"The plane with the pilot and instructor had filed a flight plan
indicating they were heading south toward Brown Field. The other plane
had contacted the tower on takeoff, but the pilot's destination was
unknown."
"The Cessna 172RG was owned by Scandinavian Aviation Academy, a flight
school based at Gillespie Field. Officials at the school refused to
talk to reporters."
TMG around San Diego Ingo Wolf Piloting 19 December 9th 04 01:50 AM
TMG around San Diego Mark James Boyd Soaring 19 December 9th 04 01:50 AM
Military jet crashes in San Diego Bay Otis Willie Military Aviation 0 August 28th 04 12:24 AM
Navy F-14 crashes into the ocean off San Diego - Pilots Rescued Rusty B Military Aviation 0 March 29th 04 10:42 PM
Good instrument program near San Diego? [email protected] Instrument Flight Rules 1 October 26th 03 03:59 AM
