On 8 Feb 2006 14:05:06 -0800, "Mike Granby" wrote:
Concerening arrival and flight through Class C airspace... 91.130(c)(1) Each person must establish two-way radio communications with the ATC facility [...] providing air traffic services prior to entering that airspace and thereafter maintain those communications while within that airspace. Note the use of "THE" in reference to the ATC facility to which one has to talk. Does this mean THE specific ATC facility controlling the Class C airspace? Or just the ATC facility providing services to you at the time? In other words, if you blunder into Class C while talking to Center on VFR advisories, either perhaps because they forgot to hand you off or because you wandered off altitude and they didn't notice, would you be ok, or would you be busted? Mike, My recollection, which may be incorrect, is that this was a change from the original wording specifically designed to ensure that the entering pilot would be talking with the ATC facility actually controlling the Class C airspace. In the original proposal establishing CCA, I don't believe that requirement was present -- only that the pilot be talking with ATC. I also seem to recall AOPA being against the change, feeling that if the pilot was talking with any ATC facility, it should be the responsibility of that facility to coordinate the CCA entry. AOPA lost that fight. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message ... My recollection, which may be incorrect, is that this was a change from the original wording specifically designed to ensure that the entering pilot would be talking with the ATC facility actually controlling the Class C airspace. In the original proposal establishing CCA, I don't believe that requirement was present -- only that the pilot be talking with ATC. Your recollection is correct. This was addressed in responses to comments received when ARSA/Class C airspace was in the test period. The FAA addressed it as follows: "Specifically, aircraft arriving at any airport in an ARSA, and overflying aircraft, prior to entering the ARSA must: (1) Establish two-way radio communications with the ATC facility having jurisdiction over the area; and, (2) while in the ARSA, maintain two-way radio communication with that ATC facility." But when it came time to implement ARSAs nationwide and incorporate them in the FARs they didn't include that nice, clear language. The original regulation was: § 91.88 Airport Radar Service Areas. (c) Arrivals and Overflights. No person may operate an aircraft in an airport radar service area unless two-way radio communication is established with ATC prior to entering the area and is thereafter maintained with ATC while within that area. This language was corrected, I believe during airspace reclassification back in 1993, to make it clear that contact with any ATC facility did not permit entry into ARSA/Class C airspace, it had to be with the ATC facility having jurisdiction over the area. |
On Fri, 10 Feb 2006 16:52:48 GMT, "Steven P. McNicoll"
wrote: "Ron Rosenfeld" wrote in message .. . My recollection, which may be incorrect, is that this was a change from the original wording specifically designed to ensure that the entering pilot would be talking with the ATC facility actually controlling the Class C airspace. In the original proposal establishing CCA, I don't believe that requirement was present -- only that the pilot be talking with ATC. Your recollection is correct. This was addressed in responses to comments received when ARSA/Class C airspace was in the test period. The FAA addressed it as follows: "Specifically, aircraft arriving at any airport in an ARSA, and overflying aircraft, prior to entering the ARSA must: (1) Establish two-way radio communications with the ATC facility having jurisdiction over the area; and, (2) while in the ARSA, maintain two-way radio communication with that ATC facility." But when it came time to implement ARSAs nationwide and incorporate them in the FARs they didn't include that nice, clear language. The original regulation was: § 91.88 Airport Radar Service Areas. (c) Arrivals and Overflights. No person may operate an aircraft in an airport radar service area unless two-way radio communication is established with ATC prior to entering the area and is thereafter maintained with ATC while within that area. This language was corrected, I believe during airspace reclassification back in 1993, to make it clear that contact with any ATC facility did not permit entry into ARSA/Class C airspace, it had to be with the ATC facility having jurisdiction over the area. Thanks for confirming my memory of how that unfolded. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
