#71
Bela P. Havasreti wrote:
/snip/ I'm guessing you're just one of those folks who like to "argue" and/or get the last word in.....? /snip/ Good Grief, Bela, I thought you'd been around here long enough to know that! There's an old saying involving mud wrestling and pigs, and it applies here. Happy Flying! Scott Skylane |
#72
![]() "Bela P. Havasreti" wrote in message ... It is not unsafe, and you did not "explain why that is so". I did explain why turning towards an aircraft on downwind is more hazardous than overflying the runway. You may not have seen that message, but you're wrong when you say I didn't provide the explanation. You quoted some regs. Regs are open to interpretation. Not this one. |
#73
![]() "Steven P. McNicoll" wrote There's no "maybe" about it. The Pilot/Controller Glossary was compiled to promote a common understanding of the terms used in the Air Traffic Control system. The instruction "Go Around" is defined as: "Instructions for a pilot to abandon his/her approach to landing. Additional instructions may follow. Unless otherwise advised by ATC, a VFR aircraft or an aircraft conducting visual approach should overfly the runway while climbing to traffic pattern altitude and enter the traffic pattern via the crosswind leg. I would consider sidesteping by 50 or 100 feet to increase ability to see traffic, as still complying with the "overfly the runway" bit. I'm sure you feel differently. -- Jim in NC |
#74
![]() "Steven P. McNicoll" wrote in message ink.net... "Kyle Boatright" wrote in message ... True, but ATC isn't likely to suffer the ultimate price should there be a mid-air collision. I'm announcing intentions and keeping the rogue aircraft in sight. If ATC has a problem with that, we can sort it out later. A midair with the rogue departure? That seems unlikely. You're behind and above the aircraft taking off. For a collision to occur it would have to climb significantly faster than your aircraft. If it can it do that it is probably significantly faster as well and will stay in front of you. The safest thing to do is comply with the instruction and overfly the runway. In *my* scenario, there isn't an instruction. Either I'm a step ahead of the controller, or (more likely) I'm at an uncontrolled field with no tower. I make the decision to abort the landing and announce my intentions, regardless of my previous announcemets, clearances, whatever. My comfort level dictates what I do, which will be what I percieve to be the safest course of action. KB |
#75
"Steven P. McNicoll" wrote:
"Ron Lee" wrote in message ... I agree. Be safe and if they want to scream and yell at least everyone is alive to vent. Not if you turn and collide with somebody on downwind. If you choose to worry about that situation you may. It is not a realistic scenario to me. Ron Lee |
#76
"Bela P. Havasreti" wrote in message ... It is not unsafe, and you did not "explain why that is so". I did explain why turning towards an aircraft on downwind is more hazardous than overflying the runway. You may not have seen that message, but you're wrong when you say I didn't provide the explanation. Left hand traffic. You sided step a bit to the RIGHT of final. That is on the opposite side of the runway to downwind. No safety issue. Steve, perhaps you feel that ATC is faultless but that would be an inorrect assumption. Anyone who blindly follows ATC without exercising proper pilot responsibilities may become a statistic. Ron Lee |
#77
On Fri, 10 Feb 2006 22:55:30 GMT, "Steven P. McNicoll"
wrote: "Bela P. Havasreti" wrote in message ... It is not unsafe, and you did not "explain why that is so". I did explain why turning towards an aircraft on downwind is more hazardous than overflying the runway. You may not have seen that message, but you're wrong when you say I didn't provide the explanation. You quoted some regs. Regs are open to interpretation. Not this one. I offer my congratulations on your coming to your own conclusion that you were right. If it makes you feel better, you are welcome to that thought! I am cognizant of the fact that it might be a bit disturbing for you to realize it, but there may be one or two of us (possibly more) on this planet who think otherwise.... Be safe, have a nice flight. Bela P. Havasreti |
#78
On Fri, 10 Feb 2006 13:51:40 -0900, Scott Skylane
wrote: Bela P. Havasreti wrote: /snip/ I'm guessing you're just one of those folks who like to "argue" and/or get the last word in.....? /snip/ Good Grief, Bela, I thought you'd been around here long enough to know that! There's an old saying involving mud wrestling and pigs, and it applies here. Happy Flying! Scott Skylane You're right, I should know better.... For a nanosecond or two, I thought maybe a reasoned response would elicit a meaningful exchange of information / ideas. What was I thinking!. 8^) Bela P. Havasreti |
#79
![]() "Chris G." wrote in message reenews.net... helloooooo..... Howdy. I wouldn't sidestep THAT far... Apparently there are those that would. At least one person here has stated the reason to move to the right is to avoid other pattern traffic. If you're not moving THAT far it doesn't matter which way you turn. NOR would I sidestep into traffic (that I know about). Who would? You may not know about all of the traffic. Steve, Give it a rest. Give what a rest? As PIC, I'm responsible for the safety of my aircraft and of my actions. Yes, I've already pointed that out. You quoted the regs saying just that. If I feel that I *need* to deviate from ATC instructions to avoid an imminent collision, then I believe that would constitute and EMERGENCY. In an emergency, it is well known that I may deviate from the FARs to meet the needs of that emergency. Also, remember, Aviate, Nagivate, and Communicate. I'll tell ATC what is going on, but not before I ensure the safety of my flight. That being said, I don't doubt that ATC will not intentionally issue an instruction that would put me in harm's way. That still does not relieve me of being situationally aware and ready to respond appropriately to a given situation/instruction. Nothing in the OP suggests a need to deviate from any ATC instructions to avoid an imminent collision. The threat of an imminent collision was averted by the go around maneuver which was initiated by the controller. |
#80
![]() "Kyle Boatright" wrote in message ... In *my* scenario, there isn't an instruction. Either I'm a step ahead of the controller, or (more likely) I'm at an uncontrolled field with no tower. I make the decision to abort the landing and announce my intentions, regardless of my previous announcemets, clearances, whatever. My comfort level dictates what I do, which will be what I percieve to be the safest course of action. I don't see where you introduced *your* scenario. We've been discussing the scenario in the OP in which the go around was imitated by ATC. |
