L/D of Virgin Atlantic GlobalFlyer
Old February 12th 06, 03:15 PM posted to rec.aviation.soaring
Default L/D of Virgin Atlantic GlobalFlyer
The subject says it all. Has anybody found information about L/D of
GlobalFlyer? My guess is that Steve knows it, because he is also known
as glider pilot.
Regards,
Mika Koski
Old February 12th 06, 06:03 PM posted to rec.aviation.soaring
There was an article in Popular Mechanics I found on the web that
claims that the GlobalFlyer has
"a lift-to-drag ratio of 37-to-1--topping even the Voyager's 27-to-1"
(http://www.popularmechanics.com/scie...tml?page=3&c=y).
There was another interesting piece of information on the GlobalFlyer
website in an article
(http://www.globalflyer.com/ScienceAv...ilotsView2.jsp)
by Jon Krakow, the GlobalFlyer's chief engineer:
"One of the characteristics of the aircraft is that it glides well. It
glides so well that with the gear up and at light weights with the
engine at idle, it cannot descend. Switching to ground idle helps
reduce the idle thrust, but to descend at a normal 3-degree glide
angle, the gear must be extended and the drag chutes deployed."
Scaled Composite's website (Burt Rutan's shop - the designer/builder of
the GlobalFlyer, the Voyager and the SpacShipOne) can be found he
http://www.scaled.com
Looks like on a final glide the GlobalFlyer would beat more familiar
gliders such as a Grob 103 or an ASK 21... And you got a beefy
self-launcher in case you blow it...
Markus
Old February 12th 06, 07:35 PM posted to rec.aviation.soaring
In article .com,
And yet they said yesterday that if he ran out of fuel he could glide
200 miles from 50,000 ft. Which is 24:1, assuming nautical miles.
Which makes one suspect that the 37:1 is with the engine idling, not
dead.
Which doesn't contradict the above.
ASK21 certainly. But that's right around the same as our Grob Twin
Astirs. Assuming he still has fuel to keep the engine idling...
And you got a beefy self-launcher in case you blow it...
They say it can climb with the chutes (called "shoots" in one article on
their site yesterday!) deployed. Good thing as they don't jettison.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old February 12th 06, 07:44 PM posted to rec.aviation.soaring
dead.
If someone was going to tow you out to sea in your Standard Cirrus,
would you determine how far you can glide back based on the
manufacturers advertised 37:1 glide ratio, or perhaps something a bit
more reasonable like, say, 24:1?
Marc
Old February 12th 06, 11:31 PM posted to rec.aviation.soaring
On Sun, 12 Feb 2006 19:44:42 GMT, Marc Ramsey
Any current airliner features an L/D better than 20:1 with engines
off. Looking at the GlobalFlyers aspect ratio and design, I get the
impression that it's probably even better than 37:1.
Bye
Andreas
Old February 13th 06, 07:10 AM posted to rec.aviation.soaring
off.
Cite?
Jack
Old February 13th 06, 05:35 AM posted to rec.aviation.soaring
dead.
From 50,000 ft? If I was going for a world record and had a parachute,
people standing by to pick me up, and a wealthy backer? I would expect
that the probability of sink the whole way would be vanishingly low and
that working on 32:1 or 33:1 would be pretty safe but that there would
be a pretty good chance of using what atmospheric variation was
available to manage a good bit better than the glider's raw glide angle.
Old February 13th 06, 11:36 AM posted to rec.aviation.soaring
dead.
It was pretty late in the day when he landed at Bournemouth and would
have been later still at Manston. Good glider or not, I wouldn't count
more than still air, with maybe a bit of added sink, at that time of day.
BTW I agree it would be interesting to see how it performed as a glider.
Let's see now:
- restricted vis - I wouldn't want to share airspace with it
- it might run a cloud street, but could it turn tight enough to
core a thermal?
- with a design cruise of 250kts, it may be too fast to use
anything but wave or ridge lift.
- Anybody fancy running the Appalachians in it? A two hour 750
should be on in theory.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old February 13th 06, 04:54 PM posted to rec.aviation.soaring
dead.
Maybe they were factoring in a headwind.
Old February 14th 06, 01:55 PM posted to rec.aviation.soaring
On the global flyers website, it says that it was sensitive
to turbulance, at it might cause structual failure
(certainly whilst full of fuel anyway!) so maybe a
bumpy ridge or rotor may not be that fun...!
It certainly looks better than ETA though.
Virgin Globalflyer finally takes off John Doe Piloting 2 February 9th 06 01:07 AM
Atlantic Tow?? Ed Byars Soaring 14 October 9th 05 03:22 PM
X-C from NC to FL over Atlantic ? John Doe Instrument Flight Rules 20 July 11th 05 03:50 PM
Air Ops North Atlantic - Ron Knott Greasy Rider© @invalid.com Naval Aviation 1 June 4th 05 06:52 PM
Scaled Composites will build Virgin Galactic's fleet of five spaceships Larry Dighera Piloting 3 January 5th 05 02:36 PM
