Jim,
I have been keeping my eye on the Xenos ever since they announced it. Since then I bought an LS3 and wonder now if I would be satisfied with the claimed 1-26 performance. So far no customer Xenos kits have been completed. Have you flown the factory built Xenos? I am also curious why you have purchased a Sonex kit instead of the Xenos? What is your motivation to promote the Xenos? Looking at the factory site it appears that you have not yet built your Sonex kit #855. Slightly confused by your posting, Randy Cone Jim Culp wrote: Dear Aviators, Know this, GentleFolk: THERE IS A MOTORGLIDER for homebuilder complete kit, at Oshkosh AirVenture. Yes indeed, displayed and sold and affordable at Oshkosh, appealing and pitched to the eaa type aircraft homebuilder, and also aimed at the Soaring Pilot who wants to build and to soar, to save big bucks, and to fly airplane style cross country-pilot and carry up to one passenger in a go-fly-an-airplane in engine running xc transport mode with good airplane speeds xc. Yes. All that. There is a COMPLETE KIT available, powered by a Jabiru 3.3 Liter Jabiru direct drive AERO engine, six cylinder aero engine with aerocarb, with Sensenich prop and spinner there on the nose, in tractor configuration. Yes, it is a Tailwheel style side by side two seater GLIDER, two stick, monoplane, made of CAD-CAM cut and pre-laser pilot hole drilled 6061-T6 Aluminum (same stuff as the Douglas C-47 nd DC-3 is made of). It shall be HOMEBUILT FROM KIT and have a Special Airworthiness Certificate, Experimental-Amateurbuilt. By building it, you shall gain the credential to do inspection and repair on the aircraft. Or at your choice you may hire an A&P mechanic to do annual condition inspections. It has all the parts perfectly cut, much of the structure is pretty much pre-made, with every skin hole already pre-drilled so you dont have to use your time measuring measuring for every dang blasted hole. yes the holes are already drilled by laser, and you finish drill, and teh complete kit includes fine machined spar caps and has spar webbing and prebent airfoil skins and all fuselage skins. What a fine piece of work is the XENOS glider for quick kit building; includes motor mount, landing gear and brakes, cowling, wheel pants, plexi canopy, gastank, canopy frame kit, etc et al. Add the engine and instruments when you have completed the fuselage building. Building Classes are given at Oshkosh Sonex factory several times a year. Next class is scheduled for May 2006, and costs only $200 which is credited in multiples to you if you order a Sonex or Waiex or Xenos within reasonable time after you have attended the factory festivities and building class and wine and beer and pizza party hosted by Sonex at their Oshkosh factory. This class should answer all your questions and wipe out any curiosity about quality and reliability of the kits and the company. The GLIDER aircraft is kit called XENOS. It is a stable-mate among kits from the John, Betty, and Jeremy Monnett Sonex-Ltd company, being available with the Sonex and Waiex airplanes. There you see them and make your choice. The Xenos is the GLIDER aircraft; it being a self-launching glider with fixed pitch small chord prop, with spoilers on wings and a wider span than the Sonex or Waiex, it using a Wortman airfoil. Nice gliderplane. It shall be on display, as it was in 2005, at the Sonex exhibit of aircraft in the Homebuilder area of the show. see http://sonex-ltd.com/new.html Dancing on clouds, Keep it up! Jim Culp USA GatorCity Florida Asw-20C Sonex Complete Kit - Nr 855 |
Production rates? | Ed Byars | Soaring | 38 | November 24th 04 04:13 PM |
Underwater Gliders | Burt Compton | Soaring | 6 | November 25th 03 04:43 AM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
Gliders at Oshkosh 2003 | Apis Gliders | Soaring | 0 | August 11th 03 12:28 PM |
Gliders at Oshkosh 2003 | Apis Gliders | Home Built | 0 | August 11th 03 12:28 PM |
