Bob Lamson's pressurized glider. High flier, but not a world record
setter. IIRC, the flight life was pretty limited. There were attempts in the lee of Mt. Rainier in Washington state, but nothing in excess of 40,000ft achieved. Perhaps better comments will follow. Frank Whiteley |
Earlier, Bruce Hoult wrote:
So what is the pressurized metal sailplane hanging in the Museum of Flight at "Boeing Field" in Seattle? As others point out, it's Bob Lamson's Alcor. It's actually not metal, but rather fiberglass and wood. Weise's book has a lot of great info on Alcor's history. The Alcor itself is a pretty fascinating ship. It's one of those testaments to dedication and ingenuity that find their way into forgotten corners of museums. it's sort of sad to see it hoisted way out of sight. Tony Burton flew Alcor in Canada to explore the climatology of the Chinook Arch that often spans Calgary. He came down to the Tehachapi SHA convention several years ago and gave a presentation on the Chinook project. He'll tell you that he was chosen on the basis of fitting into Alcor's undersized cockpit, but it's clear from the book and also his presentation that he's also a damn good pilot and engineer. If I recall correctly, Alcor's pressurization system is based on an A14 oxygen system in which the mask valves are turned around; the pilot breathes in oxygen-rich air from the cabin and exhales overboard through the hose. The cockpit was originally designed around a fairly small pilot, but apparently turned out even smaller than intended, so they actually stretched the cockpit laterally after the fuselage was finished. But even so, it's said to be a tight fit for anyone over about 5ft7". I believe that the weak link in the Alcor's pressurization system was the canopy seal; I think that the Chinook engineers never got it working and so the Chinook flights were all unpressurized. That's sort of as you'd expect; even with a pressure differential of only 3" of mercury (about 1.5 psi) the separation force on the canopy is going to be several hundred pounds, and it's hard to achieve a good seal under the distortion you get from the pressure differential. Add to that the distortion caused by the different thermal characteristics of the various materials, and it becomes a very tough problem indeed. Thanks, and best regards to all Bob K. |
![]() "Bob Kuykendall" wrote in message ups.com... Earlier, Bruce Hoult wrote: snip---- I believe that the weak link in the Alcor's pressurization system was the canopy seal; I think that the Chinook engineers never got it working and so the Chinook flights were all unpressurized. That's sort of as you'd expect; even with a pressure differential of only 3" of mercury (about 1.5 psi) the separation force on the canopy is going to be several hundred pounds, and it's hard to achieve a good seal under the distortion you get from the pressure differential. Add to that the distortion caused by the different thermal characteristics of the various materials, and it becomes a very tough problem indeed. Thanks, and best regards to all Bob K. Sealing a conventional canopy would be difficult but there might be another way. Gary Sutherland's MOBA (http://esoaring.com/pastarticleprojects.htm#moba) has a cockpit that opens with the entire forward fuselage shell sliking forward relative to the seat and the rest of the fuselage. That design could use a simple O-ring at the separation line. Once properly sealed, the energy required to maintain pressuration isn't too bad. Bill Daniels |
Earlier, Bill Daniels wrote:
...Gary Sutherland's MOBA... Exactly! That's been a feature of all of my back-of-the-envelope sketches for pressurized sailplanes, ever since I saw the MOBA in one of Stan Hall's articles. The circular opening keeps the seal perimeter to a minimum, and it would be very easy to seal using a conventional or inflatable sealing ring. And you could even use a simple eighth-turn thread to latch it with very few moving parts. However, one major issue with that arrangement is emergency egress. That's got pyrotechnics written all over it... Thanks, Bob K. |
![]() "Bob Kuykendall" wrote in message oups.com... Earlier, Bill Daniels wrote: ...Gary Sutherland's MOBA... Exactly! That's been a feature of all of my back-of-the-envelope sketches for pressurized sailplanes, ever since I saw the MOBA in one of Stan Hall's articles. The circular opening keeps the seal perimeter to a minimum, and it would be very easy to seal using a conventional or inflatable sealing ring. And you could even use a simple eighth-turn thread to latch it with very few moving parts. However, one major issue with that arrangement is emergency egress. That's got pyrotechnics written all over it... Thanks, Bob K. Bob, you must use the same brand of envelopes I do. I figgured on a hemispherical pressure bulkhead behind the pilot that was attached to the rest of the glider with three explosive bolts - just drop the whole forward fuselage with pressurization intact. Use a drouge 'chute to stabilize the 'pod' until at a lower altitude and then jetison the forward part of the cockpit shell so the pilot couild use a personal 'chute. A variation would be a 'chute big enough to lower the whole pod. A high altitude pressure cockpit really doesn't look all that hard. The MOBA treatment could be used on any production sailplane. Bill Daniels |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Good for another 2 years! | Jim Burns | Owning | 7 | November 19th 05 03:27 PM |
Ten Years of Flying | Jay Honeck | Piloting | 20 | February 19th 05 02:05 PM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
We have done auto tows in the past few years | Joe Allbritten | Soaring | 2 | March 5th 04 03:45 AM |
