Thanks Paul!
I might just do the upgrade soon- if i can figure out how to make what I have now work right :-) ....however, i (had) have tried following your advice on the pd file about loading and reloading pocket-nav, and unfortunately the pesky black bar and log remains in the way regardless! Thanks! john roe www.roenation.com |
Hi John,
Another thought... On the 1520 and 1530 Compaq Aero units, it was possible to have the menu bar "auto-hide". You can enable it by going to Start Menu/Settings/Taskbar and check the "Auto hide" checkbox. If the tips I gave don't work to hide the menu bar then you are probably running the wrong version on your PDA. There were different compilations for different versions of WinCE. If you have the wrong one installed then the menu bar will never go away. Let me know if neither of those tips help. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "quietman" wrote in message oups.com... Thanks Paul! I might just do the upgrade soon- if i can figure out how to make what I have now work right :-) ...however, i (had) have tried following your advice on the pd file about loading and reloading pocket-nav, and unfortunately the pesky black bar and log remains in the way regardless! Thanks! john roe www.roenation.com |
You are right on. I found on a top shelf in a closet an aero 1550 that
I loaded up my version of pocket nav. I had never used this particular unit, and when I loaded the same pocket-nav program into a 1520 and a 1530 it worked fine, no bar at the bottom. However I have another 1550 that Mark DID figure out how to make work, perhaps by loading his version of pocket nav years ago... Oh well I have now have 4 defunct compact aeros and three working ones, so all is good...until I upgrade my glider and/or my glider software... thanks! John Roe "ZR" www.roenation.com |
MSFS 2004 Video frame rate very slow | Greg Brown | Simulators | 1 | November 11th 05 07:24 PM |
A-6 Redar Display? | Mike Kanze | Naval Aviation | 0 | September 28th 04 01:34 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
