Andrew Sarangan wrote:
Also, why are the entry procedures so important? Is there any example where an incorrect entry procedure would have caused an accident? My guess on this question is.... You don't bump into someone in the soup doing a proper entry. The proper entry makes it so that ATC can anticipate / predict your next move, knowing how the entry to the hold from your direction of travel. Just like working in the pattern at an uncontrolled airport, you would want people to enter the pattern appropriately to keep things neat and orderly. Don't want some one doing a right hand pattern at a left hand pattern airport.... Allen |
A Lieberman wrote in
: Andrew Sarangan wrote: Also, why are the entry procedures so important? Is there any example where an incorrect entry procedure would have caused an accident? My guess on this question is.... You don't bump into someone in the soup doing a proper entry. The proper entry makes it so that ATC can anticipate / predict your next move, knowing how the entry to the hold from your direction of travel. Just like working in the pattern at an uncontrolled airport, you would want people to enter the pattern appropriately to keep things neat and orderly. Don't want some one doing a right hand pattern at a left hand pattern airport.... Allen I can understand that a recommended entry will keep things neat and tidy. But that can't be the reason for requiring holds for recency experience. It's got to be something more important than that. A hold ranks way up there with an instrument approach when it comes to currency. A VFR traffic pattern is not a fair comparison because the traffic pattern could packed full of airplanes bumper to bumper. That can't be the case under IFR. I am not sure what kind of separation is used by ATC when in a hold. It can't be that close because the turn radius depends on the aircraft speed. During the outbound turn from the holding fix, a Citation will go past the holding fix much farther than a 172. |
I am not sure what kind of separation is used by ATC when in a hold. It can't be that close because the turn radius depends on the aircraft speed. During the outbound turn from the holding fix, a Citation will go past the holding fix much farther than a 172. Of course. All this is covered in TERPS http://av-info.faa.gov/terps/directives%20page.htm If you read the chapter on holds, you will know more than you ever wanted to about how these things are figured out. Faster airplanes are allotted more protected airspace. |
![]() A Lieberman wrote: Andrew Sarangan wrote: Also, why are the entry procedures so important? Is there any example where an incorrect entry procedure would have caused an accident? My guess on this question is.... You don't bump into someone in the soup doing a proper entry. The proper entry makes it so that ATC can anticipate / predict your next move, knowing how the entry to the hold from your direction of travel. From ATC's perspective, there is lots of protected airspace for a holding pattern, unless you are holding at max speed (almost never less than 200 knots). The entires are part of the criteria design to assure that you don't depart protected airspace. Some folks never get holds. Other, especially those who use the IFR system often, get lots of holds. Most of them are direct entries, however. Holding entries and figuring out the proper side is a great tool for an examiner or inspector to determine whether the applicant has a good feeling for what it is all about. |
Some good guesses, but I think I can suggest some better ones...
A Lieberman wrote: Andrew Sarangan wrote: Also, why are the entry procedures so important? Is there any example where an incorrect entry procedure would have caused an accident? My guess on this question is.... You don't bump into someone in the soup doing a proper entry. ATC is not going to assign holds to two aircraft at the same holding point at the same altitude. So unless "improper entry" includes an altitude bust, I don't think this is a problem. The proper entry makes it so that ATC can anticipate / predict your next move, knowing how the entry to the hold from your direction of travel. I don't think ATC can see well enough (or cares) what kind of entry you perform. Just like working in the pattern at an uncontrolled airport, you would want people to enter the pattern appropriately to keep things neat and orderly. Don't want some one doing a right hand pattern at a left hand pattern airport.... I think a better answer is that doing the prescribed entry gives you the most margin for error while keeping you inside protected airspace. If you're buzzing around in a C172, your turn radius is tight and there's plenty of protected airspace, and you can screw up the entry big-time and still stay protected. If you're flying at the limits of holding airspeed, and the wind is blowing, and you're a little sloppy with your navigation, and you do the wrong entry, it may put you outside protected airspace. Dave Remove SHIRT to reply directly |
![]() Dave Butler wrote: Some good guesses, but I think I can suggest some better ones... ATC is not going to assign holds to two aircraft at the same holding point at the same altitude. So unless "improper entry" includes an altitude bust, I don't think this is a problem. I'll give you something better than guesses. Controllers working traffic don't care, perhaps, but their managers do. There are holding patterns in the New York and Washington Center areas that are so close to each other, that speed is limited to 200 knots above 6,000 to keep the patterns from overlapping. Improper entires, at least in jets, could cause an aircraft to go into the other pattern's airspace. This was demonstrated in holding pattern criteria meetings. Radar doesn't help, because radar service is usually terminated in these busy patterns due to multiple merging targets. The proper entry makes it so that ATC can anticipate / predict your next move, knowing how the entry to the hold from your direction of travel. I don't think ATC can see well enough (or cares) what kind of entry you perform. That's right, they can't see well enough to help out in conjested airspace. Just like working in the pattern at an uncontrolled airport, you would want people to enter the pattern appropriately to keep things neat and orderly. Don't want some one doing a right hand pattern at a left hand pattern airport.... I think a better answer is that doing the prescribed entry gives you the most margin for error while keeping you inside protected airspace. If you're buzzing around in a C172, your turn radius is tight and there's plenty of protected airspace, and you can screw up the entry big-time and still stay protected. If you're flying at the limits of holding airspeed, and the wind is blowing, and you're a little sloppy with your navigation, and you do the wrong entry, it may put you outside protected airspace. In a Cessna 172, no doubt about it. But, the instrument rating is not a rating ride limited to 172's. |
IFR Checkride Checklist | BTIZ | Instrument Flight Rules | 0 | April 18th 04 12:06 AM |
IFR Checkride Scheduled | Jon Kraus | Instrument Flight Rules | 15 | April 6th 04 05:30 AM |
Passed my IFR checkride today. | [email protected] | Instrument Flight Rules | 5 | February 8th 04 07:04 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
CFI-I Checkride stories? | Jim | Instrument Flight Rules | 11 | July 18th 03 01:04 AM |
