cylinder replacement
Old February 15th 06, 03:15 AM posted to rec.aviation.owning
Default cylinder replacement
I had a friend with a Mooney with an 0-360 that was topped at 2500
hours and made it to 4500 hours. I would go with new cylinders.
Personally I like Lycoming cylinders, but the others are ok too. There
is a chance of problems with any of them.
Old February 16th 06, 01:53 PM posted to rec.aviation.owning
If you assume that you are going to keep the airplane a 1000 or more
hours, then factory new cylinders are the only way to go... If you are
going to keep the airplane for the forseeable future then a complete
overhaul at this time is the smart money...
I was with you up to that last line, Denny. Why do you conditionally
advocate a complete overhaul (if he's keeping it 1000 or more hours) when
the engine only has 850 hours on it?
To Scott: Personally, I'd go with all new Millennium cylinders, and find a
different A&P. His quote is too high, IMHO.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 16th 06, 09:03 PM posted to rec.aviation.owning
Vapor lock of the prefrontal lobes, aka, brain fart.... Scratch that
line, just put new cylinders on it...
************************************************** *************************************************8
when
Bad cylinder Denny Owning 17 September 12th 05 06:04 PM
Path of an airplane in a 1G roll Chris W Piloting 47 July 4th 05 10:53 PM
Path of an airplane in a 1G roll Chris W Aerobatics 20 June 29th 05 09:35 AM
Path of an airplane in a 1G roll Chris W Home Built 22 June 29th 05 09:35 AM
Start Anywhere Cylinder (SSA rules proposal) Mark Navarre Soaring 15 September 25th 03 01:13 PM
