"Jay Honeck" wrote in message
This all said, I'm not sure I'm following your train of thought here. By saying "s*it happens" are you implying that I survived these challenges through luck? Minimizing the risk through good training is great. And there certainly are some idiots out there that I don't want to share the sky with. However, I'm not so quick to categorize all non-mechanical, non-medical accidents to pilots being idiots. I don't judge a pilot until I have all the facts. Sometimes circumstances are beyond the control of the best pilots. I also don't believe NTSB accident reports to be gospel. In my younger days, I was quick to judge other pilots. I was 10 years old the first time I saw a crashed airplane. It was a C-150 with 2 bodies still in it. They were the victims of a mid-air collision. I wondered how they could have let that happen. What was wrong with them? In the years since then, I've had some close calls of my own. I quit judging others quickly. I check that my landing gear is down and green 3 times before landing. Want to guess why I am so paranoid about it? I haven't yet, but I've come close. If I do land with the gear up one day, would that make me a bad pilot? Some of my friends with over 10,000 hours each have landed with the gear too short. Does that make them bad pilots? In 2 cases mechanical discrepencies were discovered after the investigation was over. One of those helped spawned an AD concerning Mooney's electric gear. People sure were quick to judge that pilot before the switches were found to be at fault. None of them apologized afterwards. Here's another angle. Last fall, I went into the Mexican desert, put some air in the tires of Navajo, put some gas in the tanks, and flew it to Florida. It was a drug confiscation that had set there for 16 years. The instrument panel had nothing but bullet holes. One wing leading edge had a dent nearly back to the spar. The paint and interior was long gone. The airplane looked like crap. The risk of me needing to fill out an NTSB report was somewhat higher than when you fly Atlas. Does that make me a bad pilot? Some may think so, and I have been labeled a cowboy. And yet I have 10 years of airline management and the Administrator's blessing to give checkrides on 3 families of aircraft. Who's right about me? One other lesson that took me many, many years to learn is to not hold others to my standards. Most won't be able to meet my standards, including some airline pilots I have flown with. I have to respect the ideal that even the idiots have a right to fly, and a right to crash. D. |
Capt Doug
BRAVO !!! I have often asked some of my students if they would fly an airplane when they KNEW something was wrong with it.The answer was always a resounding NOOOOoooo. Then in their aviation history they are faced with something similar to the Navajo you describe. I don't know how many aircraft I've been tasked to fly that were like that. In my 45 years of professional aviation around the world, and now pushing 23,000 hours logged, I've had one accident that injured someone. A student on a dual XC with a C-150 back in 1966. We had contaminated fuel and junk in the fuel lines. Engine puked at night over trees. We both got hurt. I've been called as an expert witness in agricultural aircraft operation crashes and was appalled at the sloppy field work by whoever did the investigations...both FAA and NTSB. I got the impression if it wasn't a major news event with lots of press coverage, the "C" team was sent to investigate. Back in my earlier days I too was labeled a cowboy or renegade. That has morphed into more like..."That old guy knows his sh*& and if you can get some dual with him take it." Now I am smart enough to wait to see all the facts before I make a judgement and even then sometimes I elect to keep my conclusions to myself. That holds true here as well. I never realized I could strike such a nerve with my original post and I'm glad I did. Best Professional Regards Rocky |
On Fri, 17 Feb 2006 05:49:11 GMT, "Capt.Doug"
wrote in :: I also don't believe NTSB accident reports to be gospel. You've got that right. Read the NTSB's probable cause of this MAC between an Navy A7 and a glider: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 The National Transportation Safety Board determines the probable cause(s) of this accident as follows: PREFLIGHT PLANNING/PREPARATION..IMPROPER. IN-FLIGHT PLANNING/DECISION..IMPROPER. CHECKLIST..POOR. So while the NTSB found the glider pilot (who obviously had the right of way) to be at fault in this MAC, the truth is, the military pilot's actions weren't merely improper, they were contrary to _regulations_*, but the NTSB failed to mention that. * http://www.e-publishing.af.mil/searc...I11-202&page=2 22 AFI11-202V3 6 JUNE 2003 5.5. Right-of-Way Rules . Usually, right-of-way is given to the aircraft least able to maneuver, which normally permits that aircraft to maintain course and speed. However, visibility permitting, each pilot must take whatever action is necessary to avoid collision, regardless of who has the right-of-way. When another aircraft has the right-of-way, the yielding aircraft must not pass over, under, abeam, or ahead of the other aircraft until well clear. 5.5.1. Distress . Aircraft in distress have the right-of-way over all other air traffic. 5.5.2. Converging. When converging at approximately the same altitude (except head-on or approximately so), the aircraft to the other’s right has the right-of-way. Aircraft of different categories have the right-of-way in the following order of priority: 5.5.2.1. Balloons. 5.5.2.2. Gliders. 5.5.2.3. Aircraft towing or refueling other aircraft. 5.5.2.4. Airships. 5.5.2.5. Rotary or fixed-wing aircraft. 5.5.3. Approaching Head-On . If aircraft are approaching each other head-on or approximately so, each shall alter course to the right. 5.5.4. Overtaking Aircraft . An overtaken aircraft has the right-of-way. The overtaking aircraft must alter course to the right. |
You've got that MORE than right. I was doubly involved with an aircraft
that was destroyed in an emergency landing in 1989. I was the PIC, but also the A&P on that aircraft. Neither the FAA nor the NTSB ever asked for copies of the maintenance logbooks which clearly reflected the overhaul and service bulletins performed on that aircraft. The proximate cause of the accident was double ignition failure -- one magneto failed and leaded up the other set of plugs. After the accident, one set of plugs (the ones on the failed magneto) were white-clean and the other set of plugs were loaded with lead. It can be easily shown how this can happen. The NTSB (which galls me to this day) laid the cause of the accident to "improper maintenance". Yet the magneto overhaul times and bulletin times were complied with to the letter and spirit of the mag company. The plugs had less than 25 hours since cleaning. THe failure mode (open coil) couldn't have been detected even with a full-bore overhaul, much less the service bulletin inspections. Gospel, my tiny hiney. Jim "Larry Dighera" wrote in message ... On Fri, 17 Feb 2006 05:49:11 GMT, "Capt.Doug" wrote in :: I also don't believe NTSB accident reports to be gospel. You've got that right. |
On Fri, 17 Feb 2006 10:26:08 -0800, "RST Engineering"
wrote in :: You've got that MORE than right. [Stupid NTSB finding snipped] I'm beginning to think our federal government is broken to the point of uselessness. The many personnel among its ranks have no incentive to perform competently; apparently they are paid the same amount regardless of their level of performance. I had occasion to contact FEMA a few days ago. The person to whom I spoke was so moronic and illiterate, that I was astonished that she was employed at all, let alone being paid with my tax dollars. Welcome to the 21st century. If something is done about our nation's abysmal education system soon, we're not going to enjoy living in this country in the future. |
Jim-RST Enginering
I've had a number of engine or mechanical failures that caused me to make an unscheduled landing in both airplanes and helicopters. The problems could not have been found short of a tear-down inspection. The fact that I got the machine back on the ground without further damage was how much luck and how much pilot skill? To be sure, in ag operations the vast majority of pilots fly "cocked and locked" for an immediate response to an emergency or malfunction. Now, having said that, with 40 years of crop dusting behind me, and at least 13,000 hours in the lowest reaches of the airspace system, and having had more scares and frights in a year than most pilots will ever experience in a lifetime.... I think too many lesser experienced pilots here tend to limit their views to that narrow range of their experience. Well, that is to be expected. It is their fault if they don't pick the diamonds of wisdom to add to their pilot bag of tricks to help them out if the sh*& hits the fan and they have to react to salvage the ensuing mess. In 50 years of flying as PIC, I've experienced 18 maydays, have had at least 5 actual autorotations with mechanical failures or fuel exhaustion, I've hit 18 wires that were carefully logged, have killed literally hundreds of birds in mid-air collisions aka bird strikes, have many times come back in to the base with pine needles or leaves stuck someplace on the aircraft. Now I ask you, does this put me into the Bad pilot catagory? Does it put me into the LUCKY pilot catagory? Is it a combination of lucky, poor/good/bozo? Doesn't really matter to me since I am still here and able to pass along my mistakes and observations to those who may one day be faced with similar problems. Those who choose to slam me are free to do so. I invite them to fly with me under challenging circumstances and see what THEY can do to cope. Finger pointing doesn't accomplish much. Now I'll take a step back with my big stick and see what happens next. Cheers Rocky aka Ol Shy & Bashful |
On 17 Feb 2006 10:52:04 -0800, wrote in
. com:: To be sure, in ag operations the vast majority of pilots fly "cocked and locked" for an immediate response to an emergency or malfunction. And then, there are those who aren't able to reach the four mile distant work-site before winning a Darwin Award: http://www.ntsb.gov/ntsb/brief.asp?e...08X08016&key=1 NTSB Identification: SEA97LA099 . The docket is stored in the Docket Management System (DMS). 14 CFR Part 137: Agricultural Accident occurred Monday, May 05, 1997 in ROSALIA, WA Probable Cause Approval Date: 1/28/2000 1800 local time Aircraft: Grumman G-164A, registration: N7926 Injuries: 1 Fatal. The pilot-in-command departed the airport in a Grumman G-164A spray plane. En route to the destination field, and while overflying hilly terrain, the aircraft's tail wheel impacted the ground, followed by the main gear. The aircraft continued over an embankment, nosing over while crossing a paved road, before coming to rest and burning. There was no evidence that the pilot jettisoned the 2,040 pound herbicide load. Propeller slash marks early in the ground track indicated high engine RPM at the initial ground impact. Additionally, toxicological evaluation of samples from the pilot-in-command revealed 0.002 ug/ml of Tetrahydrocannabinol detected in blood, 0.08 ug/ml of Tetrahydrocannabinol Carboxylic Acid detected in blood, and 0.035 ug/ml of Tetrahydrocannabinol Carboxylic Acid detected in urine indicating fairly recent (within several hours) use of Marihuana. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: The pilot-in-command's failure to maintain clearance with terrain. Factors contributing to the accident were, hilly terrain conditions and impairment due to recent use of marihuana. Full narrative available: http://www.ntsb.gov/ntsb/GenPDF.asp?...97LA099&rpt=fa |
RST Engineering wrote:
The NTSB (which galls me to this day) laid the cause of the accident to "improper maintenance". Yet the magneto overhaul times and bulletin times were complied with to the letter and spirit of the mag company. The plugs had less than 25 hours since cleaning. THe failure mode (open coil) couldn't have been detected even with a full-bore overhaul, much less the service bulletin inspections. The idiots at the NTSB concluded I was too fast when I crashed and totalled a Piper Lance, estimating I was doing a cool 130 knots when I hit. I must be the toughest man alive, because I wasn't wearing a shoulder strap. Didn't break any ribs either. The engine out approach was flown at 90 mph; I told them that. No telling how much slower I was when I lost the wing but there's no way in hell I was anywhere near the speed they concluded. I sometimes wonder if they mix up the reports in a big stack on the desk when they write their conclusions. -- Mortimer Schnerd, RN VE |
Don't recall the dates..1990's..a crop duster pilot in a Grumman Ag
Cat, Palouse area of SE Washington state was returning to base and got overun by some Navy jets on low level training. He was RUN OVER FROM THE REAR and the Navy tried to blame him for the accident. When fault is being discovered, it seems those with the best legal minds are going to prevail regardless of what happened. OJ Simpson anyone...? |
On 17 Feb 2006 10:30:12 -0800, wrote in
.com:: Don't recall the dates..1990's..a crop duster pilot in a Grumman Ag Cat, Palouse area of SE Washington state was returning to base and got overun by some Navy jets on low level training. He was RUN OVER FROM THE REAR and the Navy tried to blame him for the accident. When fault is being discovered, it seems those with the best legal minds are going to prevail regardless of what happened. OJ Simpson anyone...? Would that have been this MAC? http://www.ntsb.gov/ntsb/brief.asp?e...11X12242&key=1 NTSB Identification: SEA93FA094A. The docket is stored on NTSB microfiche number 50895. 14 CFR Armed Forces Accident occurred Wednesday, April 14, 1993 in STEPTOE, WA Probable Cause Approval Date: 3/18/1994 Aircraft: GRUMMAN A6E, registration: USN Injuries: 2 Serious, 1 Minor. THE A6E WAS TRACKING 033 DEG LEVEL AT 200 FT AGL AT 468 KTS VFR IN PUBLISHED ROUTE VR-1354. THE AGCAT WAS TRACKING 334 DEG LEVEL AT 200 FT AGL AT 96 KTS VFR ACROSS THE ROUTE TO HIS DESTINATION SPRAY FIELD. THE TWO AIRCRAFT CONVERGED ON A 59 DEG COLLISION ANGLE WITH A CLOSURE SPEED OF 429 KTS. THE A6E NOTIFIED FSS THAT HE WAS ENTERING THE ROUTE LATE AND PROJECTED EXITING 8 MINUTES AFTER THE PUBLISHED CLOSURE OF THE ROUTE. THE AGCAT PILOT REPORTED HE WAS UNAWARE OF ANY INFORMATION/PUBLICATIONS REGARDING THE OPERATION OF MILITARY AIRCRAFT IN THE AREA. THE LOCAL FSS WAS IN THE HABIT OF REPORTING THE ROUTE 'HOT' 24 HRS A DAY RATHER THAN THE PRECISE SCHEDULE. THE CONVERGENCE ANGLE OF THE A6E WAS 111 DEG (8 O'CLOCK POSITION & BEHIND THE AGCAT'S LEFT WING). THE CONVERGENCE ANGLE OF THE AGCAT WAS 10 DEG. AT THE PROJECTED CLOSURE SPEED THE AGCAT WOULD HAVE SUBTENDED AN ANGLE OF 0.2 DEG 8.6 SECS BEFORE IMPACT; THE A6E 19.2 SECS. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: THE INHERENT LIMITATIONS OF THE SEE-AND-AVOID CONCEPT OF SEPARATION OF AIRCRAFT OPERATING UNDER VISUAL FLIGHT RULES THAT PRECLUDED THE CREW OF THE A6E AND THE PILOT OF THE AGCAT FROM RECOGNIZING A COLLISION HAZARD AND TAKING ACTIONS TO AVOID A MIDAIR COLLISION It would appear that the NTSB investigator got that part of the probable cause right, but why is there no mention of FAR § 91.113 (f): (f) Overtaking. Each aircraft that is being overtaken has the right-of-way and each pilot of an overtaking aircraft shall alter course to the right to pass well clear. I don't know if a Class 1 medical certificate is required to PIC an A6E, but given: http://www.ntsb.gov/ntsb/GenPDF.asp?...3FA094A&rpt=fa Date of Last Medical Exam: 08/1992 Medical Cert.: Valid Medical--no waivers/lim. Class 1 Occurrence Date: 04/14/1993 It would appear that the A6E pilot's Class 1 medical certificate was two months out of date. |
hi-speed ejections | Bill McClain | Military Aviation | 37 | February 6th 04 09:43 AM |
F-15...Longish | Mike Marron | Military Aviation | 9 | October 7th 03 01:49 AM |
