Bob Moore wrote in
. 8: Andrew Sarangan wrote If you have a crosswind, you can't maintain a racetrack shape if you want to do standard rate turns. That is why we double the wind correction on the outbound. The goal is to make standard rate turns on both ends of the holding pattern, not to keep the outbound parallel to the inbound. Gee...thanks for the explanation Andrew, and to think that for all of these years, for a one minute pattern, I've been teaching that one should *triple* the drift on the outbound leg. We taught it that way at PanAm long before the FAA changed the AIM as follows. From AIM 5-3-7 (c) Compensate for wind effect primarily by drift correction on the inbound and outbound legs. When outbound, triple the inbound drift correction to avoid major turning adjustments; e.g., if correcting left by 8 degrees when inbound, correct right by 24 degrees when outbound. Bob Moore OK, now I'm confused. If you triple the correction, wouldn't the inbound turn be less than standard rate? What am I missing here? |
OK, now I'm confused. If you triple the correction, wouldn't the inbound turn be less than standard rate? What am I missing here? Well...ignoring the turns for the moment, using the same drift correction for the outbound leg as used on the inbound leg (with an opposite sign of course) would result in parallel tracks. This is one times the inbound drift (1x). Now, for a one minute pattern, there are two standard rate turns, each requiring one minute to complete. The distance blown off during each of the turns is the same as one would be blown off during one of the one minute strait legs, requiring an ammount of drift correction on the outbound leg for each of the turns equal to the ammount used for the one minute strait leg. All adds up to be three times (3x) the inbound drift correction. Yes, even the old AC 61-27C, Instrument Flying Handbook had it wrong. Bob Moore |
Bob Moore wrote
Well...Now after spell checking.."amount and straight" Bob Moore |
Bob Moore wrote: Andrew Sarangan wrote OK, now I'm confused. If you triple the correction, wouldn't the inbound turn be less than standard rate? What am I missing here? Well...ignoring the turns for the moment, using the same drift correction for the outbound leg as used on the inbound leg (with an opposite sign of course) would result in parallel tracks. This is one times the inbound drift (1x). Now, for a one minute pattern, there are two standard rate turns, each requiring one minute to complete. The distance blown off during each of the turns is the same as one would be blown off during one of the one minute strait legs, requiring an ammount of drift correction on the outbound leg for each of the turns equal to the ammount used for the one minute strait leg. All adds up to be three times (3x) the inbound drift correction. Yes, even the old AC 61-27C, Instrument Flying Handbook had it wrong. Bob Moore The only problem with that is it assumes that tripling the wind correction angle triples the drift correction. For small angles, that's a reasonable approximation (it's saying that sin(x) = x), but it falls apart for big ones. In a 90 kt spam can, a direct 25 kt crosswind requires a 15 degree WCA inbound, which would mean a 45 degree WCA angle outbound. You don't often see a 25 kt crosswind on the runway, but it's not uncommon at 3000 AGL where you might be holding. A jet holding at 180 kts will need half the WCA you do at 90 kts. So, yes, triple is better than double, but even better in a slow airplane is asking the controller for longer legs! 2 minute legs will let you fly double the inbound WCA on the outbound leg, and 3 minute legs will make it even easier. Even easier than that is to ask for 5 or even 10 DME legs, assuming you're so equipped (gotta love GPS). |
IFR Checkride Checklist | BTIZ | Instrument Flight Rules | 0 | April 18th 04 12:06 AM |
IFR Checkride Scheduled | Jon Kraus | Instrument Flight Rules | 15 | April 6th 04 05:30 AM |
Passed my IFR checkride today. | [email protected] | Instrument Flight Rules | 5 | February 8th 04 07:04 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
CFI-I Checkride stories? | Jim | Instrument Flight Rules | 11 | July 18th 03 01:04 AM |
