HELP -designing new panel
Old February 21st 06, 07:03 AM
freestone freestone is offline
Junior Member
First recorded activity by AviationBanter: Feb 2006
Default HELP -designing new panel
I am new to IFR (pilot a long time just working on rating now, not sure how much I will use it but hope too).
I am restoring an old plane and doing a completely new panel, which I need to spec out in about 6 months.
I would like to keep the plane light, but still...
I need some help in deciding whether to get a 530 with a backup 430 - or something else. Maybe the 480 though I have seen the debates.
Perhaps a mx20 or Avidyne 500?
What about an HSI for the panel? sandel?
One thing I really do want is an active tcas and a display that i can instantly identify target location on.
I will also add a stec autopilot.
What would you put in? I don't have that much space. A 530 would fit in the center below the throttle quadrant, but any other nav/comm would go on the right side of the plane. In liu of a 530, I could put a mx20 like box in the center, but the nav/comm would need to be on the right side.
thanks for the help.
Old February 21st 06, 02:15 PM posted to rec.aviation.ifr
You didn't say what make/model "old plane" but consider
factors...
1. Electrical loads and power available, including backup
battery power;
2. Panel space;
3. Budget
4. Ease of use, system integration.
A quality avionics shop will be able to assist in designing
and fabrication of a new panel and do a proper electrical
system survey. Also, you will want to consider other
systems, such as pneumatic and the engine in general.
You might want to get the rating before you finalize the new
panel, you'll have a better idea of what and where to spend
your money.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"freestone" wrote
in message ...
now, not sure
panel, which I
backup 430 -
debates.
that i can
530 would fit
nav/comm would
could put a mx20
on the right
| side.
| freestone
Old February 21st 06, 10:00 PM
Junior Member
A dehavilland Beaver. 70amp alternator.
as restoration going on i will need to spec the panel out in late summer or so. will Garmin update the 530's with better resolution, waas, airways, etc?
Not planning on doing serious IFR in this plane, but I do need to get above coastal clouds and also will be going into backcountry. Use on the west coast, up and down it.
Panel space is always tight.
Budget can be flexible, but I do want to preserve a lot of the authenticity of the beaver, yet I want to have good situational awareness. Room as mentioned in the center for either a 530 or something like an mx20, and room in front of right seat for another nav/com, transponder, etc.
Will have an active tcas in the plane - and would like a nice display perhaps a sandel hsi to display it on seperate from garmin or so display which gets cluttered. maybe a dedicated 3 inch hazard display instead.
ease of use and "future proofing" of course is nice.
thanks for the advice,
Quote:
factors...
battery power;
2. Panel space;
3. Budget
your money.
James H. Macklin
ATP,CFI,A&P
some support
"freestone" wrote
in message ...
now, not sure
panel, which I
backup 430 -
debates.
that i can
530 would fit
nav/comm would
could put a mx20
on the right
| side.
| freestone
Old February 21st 06, 10:36 PM posted to rec.aviation.ifr
As to what Garmin will do, ask Garmin. They can even help
you with selections for what you want. You may want to have
more electrical power, perhaps a second generator and
battery, with a load shedding bus.
You could just have the Beaver completely refurbed stock
and use a Garmin 396 .
All IFR is serious.
James H. Macklin
ATP,CFI,A&P
some support
"freestone" wrote
in message ...
in late
resolution,
| waas, airways, etc?
need to get
backcountry. Use on
situational
530 or
for another
nice display
or so
hazard display
| instead.
| factors...
backup
| battery power;
| 2. Panel space;
| 3. Budget
designing
electrical
new
spend
| your money.
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
| "freestone"
wrote
| in message
rating
| now, not sure
| panel, which I
a
| backup 430 -
| debates.
display
| that i can
A
| 530 would fit
other
| nav/comm would
| could put a mx20
be
| on the right
| | side.
| | freestone
| freestone
Old February 22nd 06, 01:34 AM posted to rec.aviation.ifr
All you really need is a radio, an IFR GPS, and a VOR with a
glideslope. You don't really NEED marker beacons, DME or ADF. Couple
your all electric autopilot to either your GPS or your VOR head. With a
GPS and an autopilot, you don't really need an HSI (they are
expensive). Back all this up with a handheld radio (with it's own
outside antennae) and a handheld GPS (with it's own antennae) and you
have a modern, redundant, easy to fly panel. Just use the GPS to fly
enroute and when you get there, fly the ILS. The VOR backs up the GPS
and the GPS backs up the VOR. Loose vacuum and you still have the
autopilot. Loose electic and you still have your vacuum instruments and
your handhelds. What a setup!
Why not a hinged panel? Jay Honeck Owning 22 March 7th 05 11:15 PM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 02:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 03:45 AM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 04:41 PM
