Sticking yoke
Old February 22nd 06, 07:13 PM posted to rec.aviation.owning
Default Sticking yoke
I have used a teflon spray. But it may have the same carrier characterists.
Bob Noel wrote:
In article t%vKf.811830$xm3.579900@attbi_s21,
"Jay Honeck" wrote:
At the risk of disagreeing with Jay, I would not use a silicone spray.
The carrier for the silicone oil has destroyed more plastic than I care to
tell.
Interesting -- I've never heard that before. Having your yoke come off in
your hands could ruin your whole day.
Anyone else experienced this nasty side effect of silicone sprays?
yes - not with any plastic on an aircraft. But I've seen silicone destroy
some plastic years ago.
Old February 22nd 06, 10:00 PM posted to rec.aviation.owning
My plane is a turbo arrow IV. The sticking is definitely right in the
bearing that goes through the panel. It provides just a little bit of
resistance so that when you try to make fine adjustments, its sticks and
then gives a little causing me to slightly overshoot. It does not pose a
real problem, but I think I would be more precise if it was smooth as silk.
I am now working on my instrument rating and that is all about being smooth.
ps.com...
soxinbox wrote:
When doing steep turns, I noticed that there is a little resistance to
pitch
changes on the yoke. It seems it binds a little in the bearing through
panel. Does anyone have a suggestion for the type of lubricant I could
use
on this? Do they make anything for this purpose?
What sort of airplane is it? Some of the older 172s had a
problem with a bending/breaking panel brace that would let the panel
flex enough that the control shaft bearing would start snagging and
restricting elevator control.
172s also have a problem with cracking forward horizontal stab
spars (caused mostly by people pushing down on the stab to turn the
airplane on the ground when parking or whatever) and I have seen the
spar broken clear through so that only the skin was keeping things
straight. Under higher loadings (such as a steep turn) the stab will
flex downward, misaligning the elevator hinges and making the elevator
stiffer. A really bad sign. Might be a good idea to get it checked, if
it's a 172. Look around the big lightening hole in the stab's forward
spar.
Sticky controls also result when pulley bearings dry out and
the pulley stops (or resists) turning.
Dan
Old February 23rd 06, 03:52 PM posted to rec.aviation.owning
That sticking / overshooting phenomenon is endemic to the whole Cherokee model
line if that bearing is not kept lubricated. I used a silicone lubricant when I
owned one. It makes a huge difference in the flying qualities of the airplane.
Reapply the silicone every oil change.
Old February 26th 06, 11:24 PM posted to rec.aviation.owning
I have a Cessna 150 that had silicone sprayed on the yoke shaft during it's
annual without me knowing. The next time I fly it the yoke was grabby. I
wiped off most of the silicone and use a little Wd40. Was ok after that.
Roger
"Dave Butler" wrote in message
news:1140709739.67207@sj-nntpcache-5...
silk. I am now working on my instrument rating and that is all about
being smooth.
model line if that bearing is not kept lubricated. I used a silicone
lubricant when I owned one. It makes a huge difference in the flying
qualities of the airplane. Reapply the silicone every oil change.
Old February 27th 06, 04:36 PM posted to rec.aviation.owning
In my Seneca the bushing sort of floats and articulates as the shaft
changes angles as it is pulled aft. On the left side it doesn't and I
think it is a bit of a binding problem for me. Very minor and keeping it
lubed seems to fix it.
soxinbox wrote:
When doing steep turns, I noticed that there is a little resistance to pitch
changes on the yoke. It seems it binds a little in the bearing through the
panel. Does anyone have a suggestion for the type of lubricant I could use
Old February 28th 06, 04:36 AM posted to rec.aviation.owning
All this talk about sticky yokes make me realize mine had started getting
stiff also. I sprayed a bit of LPS1 on the extended shaft and wiped off the
greyish film from the previous annual, then put on a little more and let the
carrier evaporate. After that the yoke was smooth as silk. My bearing also
floats a bit in and out and allows fine adjustments even when the yoke binds
a bit.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
silk.
smooth.
Sounds like oil has attracted dust which accumulates inside the
bearing and reduces the clearance between it and the shaft. The oil
dries and leaves behind the guck, which is made of dirt and varnish.
Repeated applications of lube build it up further. The shaft should be
removed and the hard scale cleaned out of the bearing. Some cold day
that bearing might shrink enough to stop movement altogether.
Dan
O-360 sticking valve update [email protected] Owning 19 January 31st 06 01:04 PM
Beech dual yoke w/rams horns/color preference Dan Karshin Aviation Marketplace 1 March 28th 04 05:04 PM
CH yoke and peddals? Tlewis95 Simulators 8 December 2nd 03 11:58 AM
CH Product Yoke with IP Trainer 6.5 Sanjay Kumar Instrument Flight Rules 2 October 10th 03 07:47 AM
CFS-1 and CH Yoke / Pedals Andy & Lucinda Simulators 3 September 4th 03 01:14 PM
