Do a search for wheels with 5:112 or 5/112 to look for 5 lugs with 112mm
spacing. It appears that many Mercedes fit the bill or also Audi, but many are larger diameter. A 15" alloy wheel for an Audi is below. http://www.1010tires.com/wheel.asp?w...udi+TT +Coupe As for quick, I'd check you local foreign salvage yard. Check the offset and rim width as well so you can tell it will fit in the fender. And look for that stamp! Good Luck, np Tim Hanke wrote: I am looking for trailer rims for a 2002 Komet trailer that are 5 lug, 112 mm bolt spacing, and 15 " rims. My understanding is that Komet used a Mercedes truck axel. The rims must have a US DOT stamp. Any clue where to get these quick? Thanks, Tim |
Eberle trailer wheel rims | Bob | Soaring | 7 | November 25th 11 05:39 PM |
Trailer tire rims | Gary Carter | Soaring | 7 | January 21st 05 03:15 PM |
KOMET Trailer Cradle | [email protected] | Soaring | 3 | September 27th 04 04:33 AM |
Komet trailer strut | John Shelton | Soaring | 5 | November 15th 03 05:04 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
