Pooh Bear wrote in
: TRUTH wrote: Pooh Bear wrote in : TRUTH wrote: Pooh Bear wrote in : TRUTH wrote: "Matt Wright" wrote in oups.com: Another poster provided FAA records showing that Mohammed Atta was both commercial and instrument rated - hardly a "clueless non-pilot". Flight instructors maybe had poor overall opinions of the pilots, but you don't know how long they trained away from the flight school. You don't know how much "book time" they had studying avionics. The attack had years of planning behind it. I guess they could have spent that time playing pinball... but maybe instead they were studying. That something is hard does not make it impossible. Matt. I missed that. Please post it. Still, showing one of them was instrument trained does not explain the others How many times do you need to have it explained to you that there was no need for any of them to be instrument trained ? Flying in clear skies does not require an instrument rating. Graham At 30,000 feet it does INCORRECT ! FAA regulations require the licensed crew to use instrument flying techniques ( for obvious reasons ). That doesn't mean that it's impossible to fly VFR ( visual flight rules ) - it just means you're breaking the law. Do you think the hijackers even cared about that ? If you can see the horizon / ground ( at any height ) you don't need to fly instruments ( other than to obey regulations ). Graham Okay, I'll admit you "might" know about this stuff, Thank you ! Trust me I do ! although I would give an Aeronautical Engineer's opinion a little more weight. I am not an expert in every aspect of 9/11. And I admit it. Stange how others do not do the same The issue of whether or not the hijackers were instrument rated is of zero consequence in the context of 9/11 since the weather was VFR ( visual flight rules ). Commercial pilots often have to fly in rather poorer weather where you may not be able to see the ground, horizon, or even much in front of your nose. That's why they have instrument ratings. The idea behind flying 'on instruments' is about when you can't see where you're going. The reaon for the FAA rules about mandatory use of 'IFR' ( instrument flight rules ) flight is essentially precautionary. Graham Do you know that this, in fact, is applicable for 757/767s ?? |
![]() TRUTH wrote: Pooh Bear wrote in : The issue of whether or not the hijackers were instrument rated is of zero consequence in the context of 9/11 since the weather was VFR ( visual flight rules ). Commercial pilots often have to fly in rather poorer weather where you may not be able to see the ground, horizon, or even much in front of your nose. That's why they have instrument ratings. The idea behind flying 'on instruments' is about when you can't see where you're going. The reaon for the FAA rules about mandatory use of 'IFR' ( instrument flight rules ) flight is essentially precautionary. Graham Do you know that this, in fact, is applicable for 757/767s ?? It applies to all major airline operations. If you want the details see the FAA regs. Graham |
TRUTH wrote: Pooh Bear wrote in : Commercial pilots often have to fly in rather poorer weather where you may not be able to see the ground, horizon, or even much in front of your nose. That's why they have instrument ratings. The idea behind flying 'on instruments' is about when you can't see where you're going. The reaon for the FAA rules about mandatory use of 'IFR' ( instrument flight rules ) flight is essentially precautionary. Do you know that this, in fact, is applicable for 757/767s ?? You might want to consider the fact that people have been flying planes at 30,000+ feet for several decades now, and many of them didn't have anything lie that we'd consider IFR equipment. WWII bomber pilots routinely flew at 30-33,000 feet, navigating by landmarks. |
On Fri, 24 Feb 2006 14:44:10 GMT, Chad Irby wrote:
In article , TRUTH wrote: Pooh Bear wrote in : Commercial pilots often have to fly in rather poorer weather where you may not be able to see the ground, horizon, or even much in front of your nose. That's why they have instrument ratings. The idea behind flying 'on instruments' is about when you can't see where you're going. The reaon for the FAA rules about mandatory use of 'IFR' ( instrument flight rules ) flight is essentially precautionary. Do you know that this, in fact, is applicable for 757/767s ?? You might want to consider the fact that people have been flying planes at 30,000+ feet for several decades now, and many of them didn't have anything lie that we'd consider IFR equipment. WWII bomber pilots routinely flew at 30-33,000 feet, navigating by landmarks. Or in the worst case, compass headings and time of travel adjusted by wind speed. The weather in Germany isn't always good enough for seeing the ground from 30k feet. ![]() |
![]() Johnny Bravo wrote: On Fri, 24 Feb 2006 14:44:10 GMT, Chad Irby wrote: In article , TRUTH wrote: Pooh Bear wrote in : Commercial pilots often have to fly in rather poorer weather where you may not be able to see the ground, horizon, or even much in front of your nose. That's why they have instrument ratings. The idea behind flying 'on instruments' is about when you can't see where you're going. The reaon for the FAA rules about mandatory use of 'IFR' ( instrument flight rules ) flight is essentially precautionary. Do you know that this, in fact, is applicable for 757/767s ?? You might want to consider the fact that people have been flying planes at 30,000+ feet for several decades now, and many of them didn't have anything lie that we'd consider IFR equipment. WWII bomber pilots routinely flew at 30-33,000 feet, navigating by landmarks. Or in the worst case, compass headings and time of travel adjusted by wind speed. The weather in Germany isn't always good enough for seeing the ground from 30k feet. ![]() Or indeed in the dark ! It's barely believable today that RAF navigators used star sightings on early raids. Graham |
Pooh Bear wrote:
Johnny Bravo wrote: On Fri, 24 Feb 2006 14:44:10 GMT, Chad Irby wrote: WWII bomber pilots routinely flew at 30-33,000 feet, navigating by landmarks. Or in the worst case, compass headings and time of travel adjusted by wind speed. The weather in Germany isn't always good enough for seeing the ground from 30k feet. ![]() Or indeed in the dark ! It's barely believable today that RAF navigators used star sightings on early raids. Even prior to WWII, WWI Zeppelins flew to London in night raids using dead reckoning and an extremely crude radio navigation system. The radio system required German ground stations determine the direction the Zeppelin's radio transmissions were coming from and had to radio back that information to the airships who then did the triangulation. It was not only relatively inaccurate, it clued the British in to the airship raids. |
On Fri, 24 Feb 2006 19:40:47 +0000, Pooh Bear
wrote: Or in the worst case, compass headings and time of travel adjusted by wind speed. The weather in Germany isn't always good enough for seeing the ground from 30k feet. ![]() Or indeed in the dark ! It's barely believable today that RAF navigators used star sightings on early raids. The RAF nighttime bombing campaign was a bit different, for one thing they didn't pick a precision target, they just dropped on a whole city. Easy enough to do in the dark that they got it right a whole lot more often than they got it wrong. ![]() |
Aeronautical Engineer says Official 9/11 Story Not Possible | Miss L. Toe | Piloting | 11 | February 23rd 06 02:25 PM |
Aeronautical Engineer says Official 9/11 Story Not Possible | Jim Macklin | Piloting | 12 | February 22nd 06 10:09 PM |
Aeronautical Engineer says Official 9/11 Story Not Possible | Bob Gardner | Piloting | 18 | February 22nd 06 08:25 PM |
Aeronautical Engineer says Official 9/11 Story Not Possible | Scott M. Kozel | Piloting | 1 | February 22nd 06 03:38 AM |
