The Impossibility of Flying Heavy Aircraft Without Training
Old February 25th 06, 08:23 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default Very long boring technical discussion of Lift Faries adn Thrust
I am now constructing a push up outfit with feathers on top in the proper ratio
and down on the bottom. Hmmm sounds like that's just where down should be "on
the bottom".
You see, this is why science should be left to the professionals. Such
simple sounding theories are usually wrong, and in this case you have
neglected forward motion, which provides many secondary effects. This
is why the down part of an airplane is at the BACK, not the BOTTOM. The
airplane is travelling through the air, and the first thing the air gets
is the up, and the last thing it gets is the down. Of course, as far as
the air is concerned, it's backwards (plane goes up, air goes down, at
least for a while). That's what makes the vortex.
Money is needed primarily to achieve forward motion. While an airplane
on the ground will consume a certain amount of money, flying it consumes
far more. You put some in at the beginning, and the bills come =after=
the flight. This is what causes the money vortex, which is exactly
analogous to the air vortex that holds the wing up. It is impossible to
put all the money in one place and have the airplane fly.
It is just as impossible to put the up and the down where it seems they
"should" go and get the plane to fly. Only a rocketship can do that,
and there is a =lot= of down coming out of the bottom, and a lot of up
where the top is. But there's no sideways motion (at least there
shouldn't be!)
Jose
Money: what you need when you run out of brains.
Old February 25th 06, 08:58 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
On Sat, 25 Feb 2006 20:23:55 GMT, Jose
I hope you're going to cut and paste this all together and put it on a
Web site somewhere. Decades from now, persons yet unborn will be
asking, "Does anybody have a link . . .?
Don
Old February 25th 06, 11:47 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
proper ratio
be "on
the bottom".
simple sounding theories are usually wrong, ...
snipped the expensive part
Jose
Occom's Razor, Jose.
The simplest explanation is usually the correct one.
Old February 26th 06, 03:57 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Yes, but Occam's razor needs to work with theories that explain the
facts. Fact is, the down on an airplane =is= laterally separated from
the up, and airplanes fly only when they move forward.
If Occam's razor were so simple, we wouldn't have million dollar grants.
Jose
Old March 1st 06, 04:13 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Jose
OK, Jose (just had to say that one) explain delta wings.
http://ernest.isa-geek.org
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old March 1st 06, 07:42 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Oh, that's a tough one. Looking at the CAD drawings, I was at first
inclined towards the helicopter methods (it's ugly; the earth repels it)
but the composite of several deltas belies that simpleminded conclusion.
It resembles a bird in flight, maybe the air can be fooled into
thinking feathers are on their way... but that requires the air to do
the lifting. We know this can't be true. Obviously some out-of-the-box
thinking is in order. Fortunately I'm up to the task; people have been
trying to put me back in my box for ages.
I am drawn to the 200 mph cruise speed; this is pretty fast for a single
engine prop plane. Maybe we are thinking this whole lift thing
backwards. An airplane's natural habitat is the air, and it =wants= to
go into the air. Very often what brings airplanes down are gremlins,
usually traced to the control system, the avionics, or even the pilot
himself. The object of the propeller is to shake the gremlins off the
plane and allow the plane to achieve its natural state. Since gremlins
are pretty fast, the airplane has to also move forward to keep them off
the plane.
This is a homebuilt, which is the natural habitat of gremlins. So, it
has to move =very= fast in order to shake them off and keep them off.
When you consider how hard gremlins are, and how soft feathers are, it's
a natural that feathers repel gremlins, and lift is sometimes
erroniously attributed to feathers. Many researchers have been down
this path, and there is a large body of accepted literature in support
of the feathers theory. At low speeds, the feather theory and the
gremlin theory give pretty much the same answers, but at high enough
speeds the relationship breaks down and the feather theory gives
erronious answers. This is where gremlin theory shines (it should be
noted that lift fairies are just gremlins gone bad).
Gremlin theory holds the potential for explaining a lot of aviation that
is otherwise unexplainable, but experiments are difficult and fraught
with peril. However, I would be happy to conduct the appropriate
research. Send grant money to Jose, care of Usenet.
Jose
Old March 1st 06, 09:08 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
If you feed the gremlins hot chili with lots of beans, the
rocket like exhaust provided lift and propulsion.
"Jose" wrote in message
om...
was at first
earth repels it)
fooled into
the air to do
out-of-the-box
people have been
fast for a single
thing
it =wants= to
are gremlins,
even the pilot
gremlins off the
Since gremlins
keep them off
| the plane.
gremlins. So, it
keep them off.
feathers are, it's
sometimes
been down
and the
high enough
gives
(it should be
aviation that
and fraught
appropriate
| Jose
Old March 2nd 06, 03:59 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
On 2006-03-01 20:42, Jose wrote:
-snip-
Jose
I'm with you on the gremlins theory; since the feathers theory can be
proven to work or not in at least two disparate ways:
1. Why is is that a feathered prop does not provide more lift than an
unfeathered one? If the feather theory was correct, it would make sense
to feather all props to increase lift.
2. Manned flight would have been possible long ago, by just applying
feathers to the human body; while some think this is difficult to
achieve, I've read several successfull reports using tar for this
purpose. (It is the removing thereof that is the difficult part.)
None of the tarred aviators seemed to fly wery well afterwards, so the
feathers have been demonstrated not to work in this case.
(I note that the excact mass of feathers may have been too small,
according to calculations in this group, so I invite anyone to try this
method for themselves, to prove or disprove it.)
/Rolf
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
