Newps wrote:
Peter Duniho wrote: One big downside to plasma is the issue of burn-in. They are getting better, but you can still wind up with latent images of an image that stays on the screen for extended periods of time. This might be a TV channel logo, a ticker from CNN, computer graphics, or whatever. Another downside is that the lifetime of the display itself is somewhat limited, as it fades over time. Plasma displays are also VERY heavy, consume a lot of power, and generate a lot of heat. They do look VERY nice though. ![]() I bought a 42" plasma January 2005. I was concerned about burn in and how long it would last. The life of the TV is supposed to be 40,000 hours before it gets to half brightness. Well, run the numbers. That's 5000 days at 8 hours a day. I've never kept my primary TV that long. As for burn in it isn't a problem. We've got lots of hours with Fox News on the TV with the scroll running on the bottom. Just not a factor. Plasma is not heavy. Our 42" TV weighs about 75 pounds, less than any similar sized CRT TV and a lot easier to carry. As for power my 42" uses 350 watts which is quite a bit, a lot of heat comes of a plasma. As for picture, no question a plasma is better. I also have an LCD flat screen HD TV, the plasma makes it look silly. If you consider a projector make sure you check on the cost of repalcement bulbs. I see some of them can be over $200, plus not all projectors are capable of HD. You'll need to spen at least $1000 to get a halfway decent projector picture plus the disadvantage of having to have a dark room. Burn in takes about two years to set in on the newer sets. I'm not surprised that you haven't seen anything in only 13 months. By 4-5 years it will be very noticeable if you watch certain channels too much. For folks that watch a variety of standard TV shows, then it likely won't be a big problem. Matt |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
Winching: Steel vs. Plasma | Bob Johnson | Soaring | 10 | August 12th 03 05:41 PM |
