sliding wings?
Old February 26th 06, 08:48 AM posted to rec.aviation.homebuilt
Default sliding wings?
Not variable wingspan, but variable wings
http://www.ctrl-c.liu.se/misc/ram/rk-i.html
http://www.ctrl-c.liu.se/misc/ram/is-1.html
KH
"Karl-Heinz Kuenzel" schrieb im Newsbeitrag
There have been a lot of experimentals with variable wingspan.
One you will find here
http://www.aviafrance.com/4806.htm
KH
when I look at my eyeglass case, I see two closely overlapping
wing-type shapes that are being pulled apart for opening.
why would it not be worthwhile to extend wings this way for landing and
departure?
/iaw
Old February 26th 06, 07:38 PM posted to rec.aviation.homebuilt
departure?
This is a solution in search of a problem.
Rich S.
Old February 26th 06, 07:46 PM posted to rec.aviation.homebuilt
"Rich S." wrote in message
departure?
Rich S.
Isn't that pretty much how the B-2 is controlled?
Harold
KD5SAK
Old February 26th 06, 08:16 PM posted to rec.aviation.homebuilt
From a book about the Horton Flying Wings
"... The Horton H VII had a new type of rudder installed. It consisted of
"tongues" that slid spanwise along the spar, and protuded from the tip for
additional wing tip drag. They worked very well, nevertheless the 20 H VII's
in production at Peschke at the end of the war, had conventional drag
rudders..."
around 1944
KH
Old February 26th 06, 09:55 PM posted to rec.aviation.homebuilt
Not really. On a B-2, there is a plain flap, or spoiler, on the top and the
bottom of the wing, out towards the tip. Yaw is done by extending the top
and bottom flap, about equally. You turn to that side, in a flat turn,
though.
To roll and turn left, the spoiler on the top left goes up. Fine tuning of
the yaw and roll, and so-forth, is done with the other flaps, with the fly
by wire doing all ot the thinking.
This is all a gross over simplification, of course.
Jim in NC
Old February 27th 06, 03:35 AM posted to rec.aviation.homebuilt
departure?
Doesn't a swing wing accomplish pretty much the same thing?
FF
Old February 27th 06, 04:26 AM posted to rec.aviation.homebuilt
departure?
FF
Yes, for supersonic fighters. Swept wings aren't a good choice for light
aircraft.
For slow propeller airplanes, the telescoping wing does have its
attractions. It's a way to keep the slow stall speed required for single
engine airplanes and stilll get a fast economical cruise. It probably
wouldn't help the venerable C-172 but an airplane that was already
aerodynamically clean might benefit quite a lot.
The airfoil could be any reasonable one for light aircraft. The outer wing
wouldn't make the innner wing more than an inch thicker. In addition to the
speed, another benefit would be a softer ride in turbulence with the much
higher wing loading.
Bill Daniels
Old February 27th 06, 03:58 PM posted to rec.aviation.homebuilt
FF
aircraft.
IIUC, sweeping the wing backwards has an adverse effect on stall
which is often offset with washout or twist.
How about swinging the wing forward instead?
It would be easier to have the outer wing be the moving part from
a structural perspective, but then you have a longer chord on the
wing tip.
Another even more exotic alternative would be to design a wing
that could shape to higher or lower lift and drag airfoils. Actually
the Wright Brothers sort of did that.
Always happy to muddy the waters.
FF
Old February 26th 06, 10:03 PM posted to rec.aviation.homebuilt
departure?
/iaw
But, wouldn't the eyeglasses fall out onto the runway?
Geoff
Spell checking is left as an excercise for the reader.
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
Charging for Wings safety seminar? Marty Shapiro Piloting 19 June 23rd 04 05:28 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Stolen "Champ" wings located...from 23,000 feet!! Tom Pappano Piloting 17 December 15th 03 01:24 PM
Wings from "Champ" stolen in Oklahoma after emergency landing Tom Pappano Piloting 1 December 7th 03 05:02 AM
