Hi Group:
Cla Looking at the calculations for the spar, spar.pdf I do not see your interpretation. The 67000 psi value is Bearing Ultimate, not tensile. A MATWEB lookup is in order: 6061-T6 Tensile ultimate: 45000 Tensile yield : 39000 Bearing ultimate: 88000 Bearing Yield : 56000 The values presented in the spar calculation are correct, and the bearing ultimate of 67000 is below spec. So where is the spar calc using bad values except, as you say, in the initial assumptions of 244 pounds versus 288? Curtis Scholl Just a little more input from another more knowledgeable than myself. The material that the plans and the airplane use is 6061t6 correct? The calculations show the material or the identifier as being 6061. The problem in the shown calcs is that the numbers he is using at 68000psi tensile is higher than the ultimate strength of 2024-t4 which is given at 64000. 6061t6 is only 45,000psi ultimate and 39,900 yield. It's no wonder the wing was failing at 2g. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
On Mon, 27 Feb 2006 15:14:24 -0500, Curtis Scholl
wrote: Cla Looking at the calculations for the spar, spar.pdf I do not see your interpretation. The 67000 psi value is Bearing Ultimate, not tensile. A MATWEB lookup is in order: 6061-T6 Tensile ultimate: 45000 Tensile yield : 39000 Bearing ultimate: 88000 Bearing Yield : 56000 The values presented in the spar calculation are correct, and the bearing ultimate of 67000 is below spec. Thjat may well be true, but is "bearing strength" the proper charachteristic of the material to be used in this calculation? As I said - not an engineer - just asking. Please explain for the rest of us how the bearing ultimate and / or yeild values impact the calculation, vs tensile. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
On Mon, 27 Feb 2006 16:02:51 -0500, clare at snyder.on.ca wrote:
On Mon, 27 Feb 2006 15:14:24 -0500, Curtis Scholl wrote: Cla Looking at the calculations for the spar, spar.pdf I do not see your interpretation. The 67000 psi value is Bearing Ultimate, not tensile. A MATWEB lookup is in order: 6061-T6 Tensile ultimate: 45000 Tensile yield : 39000 Bearing ultimate: 88000 Bearing Yield : 56000 The values presented in the spar calculation are correct, and the bearing ultimate of 67000 is below spec. Thjat may well be true, but is "bearing strength" the proper charachteristic of the material to be used in this calculation? As I said - not an engineer - just asking. Please explain for the rest of us how the bearing ultimate and / or yeild values impact the calculation, vs tensile. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** bearing strength The maximum bearing load at failure divided by the effective bearing area. In a pinned or riveted joint, the effective area is calculated as the product of the diameter of the hole and the thickness of the bearing member. ASM, 1 How does this impact the failure of the wing structure by buckling and failure of the main spar??? *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
Cla
Bearing properties are used when designing mechanically fastened joints. The purpose of a bearing test is to determine the the deformation of a hole as a function of the applied bearing stress. The test specimen is basically a piece of sheet or plate with a carefully prepared hole some standard distance from the edge. Edge-to-hole diameter ratios of 1.5 and 2.0 are common. A hardened pin is inserted through the hole and an AXIAL load applied to the specimen and the pin. The bearing stress is computed by dividing the load applied to the pin, which bears against the edge of the hole, by the bearing area (the product of the pin diameter and the sheet or plate thickness). Different axis and on edge rather than in tension or compression. The flat surface described by the hole in the part as it passes through the thickness of the tube or plate of the hole. The stress is spread through the material differently. Curtis S. And I am not an engineer either, I make rocket motors, and need this information constantly. clare at snyder.on.ca wrote: On Mon, 27 Feb 2006 15:14:24 -0500, Curtis Scholl wrote: Cla Looking at the calculations for the spar, spar.pdf I do not see your interpretation. The 67000 psi value is Bearing Ultimate, not tensile. A MATWEB lookup is in order: 6061-T6 Tensile ultimate: 45000 Tensile yield : 39000 Bearing ultimate: 88000 Bearing Yield : 56000 The values presented in the spar calculation are correct, and the bearing ultimate of 67000 is below spec. Thjat may well be true, but is "bearing strength" the proper charachteristic of the material to be used in this calculation? As I said - not an engineer - just asking. Please explain for the rest of us how the bearing ultimate and / or yeild values impact the calculation, vs tensile. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
On Mon, 27 Feb 2006 16:38:44 -0500, Curtis Scholl
wrote: Cla Bearing properties are used when designing mechanically fastened joints. The purpose of a bearing test is to determine the the deformation of a hole as a function of the applied bearing stress. The test specimen is basically a piece of sheet or plate with a carefully prepared hole some standard distance from the edge. Edge-to-hole diameter ratios of 1.5 and 2.0 are common. A hardened pin is inserted through the hole and an AXIAL load applied to the specimen and the pin. The bearing stress is computed by dividing the load applied to the pin, which bears against the edge of the hole, by the bearing area (the product of the pin diameter and the sheet or plate thickness). Different axis and on edge rather than in tension or compression. The flat surface described by the hole in the part as it passes through the thickness of the tube or plate of the hole. The stress is spread through the material differently. Curtis S. And I am not an engineer either, I make rocket motors, and need this information constantly. I understand what the bearing strength is - I'm just saying it is the wrong strength to design to when designing the wing, as the compressive, shear, and tension strengths more realistically represent the loads in the wing. If you substitute the tensile strength numbers into the calculations, I'll bet you find the wing fails around 2 Gs, which is what the test found. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
Cla
Bearing strength is for the Connecting Points of all those items you mentioned. And the engineer stopped the test before complete failure from what I read. Excessive deflection is not a failure mode unless the engineer states it is out of spec. And again, what was the sandbag testing weight at which the testing was stopped? And again, excessive deflection where? In the skins? In the Spars? in the struts? You stated: ** "No- Gary built a wing according to plans and sandbag tested it under an engineer's supervision. The engineer stopped the loading before failure because of excessive deflection IIRC." ** And I have a set of plans, and I recall seeing the sleeves being called out in the manual. And I don't see where aluminum skins are in the plans. Again, deflection where? "And sleaves in the spars by your own admission. Which are NOT in the plans." See wing plan D-WING3. It clearly shows what to do on the wing as for the sleeve inserts to reinforce the connecting points, wing to cabane, and strut to wing. Look, this aircraft flies, in it's designed weight class, it has worked for many years. The designer flies it. There are many copies flying, and the death rate is not "significant" considering what happened in the accident reports. As you said, Clare, you are not an engineer. And you don't have current validated DATA to back you up. I have stated instances of you being incorrect in your assumptions. And in one of the instances, given you the reference for corrections of your statements. We are done. No response is necessary or wanted. This will be an agree to disagree situation and no further contact is warranted. Curtis Scholl |
On Tue, 28 Feb 2006 09:50:32 -0500, Curtis Scholl
wrote: Cla Bearing strength is for the Connecting Points of all those items you mentioned. And the engineer stopped the test before complete failure from what I read. Excessive deflection is not a failure mode unless the engineer states it is out of spec. And again, what was the sandbag testing weight at which the testing was stopped? And again, excessive deflection where? In the skins? In the Spars? in the struts? The wing was tested to 2 G's at 600 lb gross. At that point the spars were ready to fail if I recall correctly. You stated: ** "No- Gary built a wing according to plans and sandbag tested it under an engineer's supervision. The engineer stopped the loading before failure because of excessive deflection IIRC." ** And I have a set of plans, and I recall seeing the sleeves being called out in the manual. And I don't see where aluminum skins are in the plans. Again, deflection where? The wing was tested with NO ALUMINUM SKINS. There are doublers at the arttach points in the plans, but the spars are not doubled between the root and the struts, which is where the spar is not up to the job from what I gathered. I'll be talking to Gary tomorrow "And sleaves in the spars by your own admission. Which are NOT in the plans." See wing plan D-WING3. It clearly shows what to do on the wing as for the sleeve inserts to reinforce the connecting points, wing to cabane, and strut to wing. Look, this aircraft flies, in it's designed weight class, it has worked for many years. The designer flies it. There are many copies flying, and the death rate is not "significant" considering what happened in the accident reports. As you said, Clare, you are not an engineer. And you don't have current validated DATA to back you up. I have stated instances of you being incorrect in your assumptions. And in one of the instances, given you the reference for corrections of your statements. We are done. No response is necessary or wanted. This will be an agree to disagree situation and no further contact is warranted. Curtis Scholl *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
![]() Curtis Scholl wrote: Cla Bearing strength is for the Connecting Points of all those items you mentioned. And the engineer stopped the test before complete failure from what I read. Excessive deflection is not a failure mode unless the engineer states it is out of spec. And again, what was the sandbag testing weight at which the testing was stopped? And again, excessive deflection where? In the skins? In the Spars? in the struts? I disagree. Excessive deflection is a failure mode if it has sufficient adverse impact on function or safety, without regard to whether or not any particular engineer realized it and said so. That is more a criticism of the wording you used, than it is of the implied question--How do we know the deflection was excessive? (And what was it that deflected?) -- FF |
wrote: Clare wrote: "No- Gary built a wing according to plans and sandbag tested it under an engineer's supervision. The engineer stopped the loading before failure because of excessive deflection IIRC." ** As you said, Clare, you are not an engineer. And you don't have current validated DATA to back you up. I have stated instances of you being incorrect in your assumptions. And in one of the instances, given you the reference for corrections of your statements. Just an update on the testing procedure and results on the TP wing tested at Kitchener Waterloo International Airport last year. The wing was instrumented with strain guages. The main spar was bending significantly between the Cabane mounting and the strut, and the strain readings were beyond the limits the engineer was comfortable with at 2Gs testing for a 600 lb plane.Failure was IMMINENT. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
![]() clare at snyder.on.ca wrote Just an update on the testing procedure and results on the TP wing tested at Kitchener Waterloo International Airport last year. The wing was instrumented with strain guages. The main spar was bending significantly between the Cabane mounting and the strut, and the strain readings were beyond the limits the engineer was comfortable with at 2Gs testing for a 600 lb plane.Failure was IMMINENT. I don't understand why the testing did not continue. Seems to me that having someone say that failure was imminent, based on strain gauges, leaves a lot of room for opinion to creep in. -- Jim in NC |
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation | Richard Lamb | Home Built | 12 | August 9th 05 08:00 PM |
want to trade 601 plans for 701 plans | [email protected] | Home Built | 0 | January 27th 05 07:50 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Texas Soars into Aviation History | A | Piloting | 7 | December 17th 03 02:09 AM |
good book about prisoners of war | Jim Atkins | Military Aviation | 16 | August 1st 03 10:18 AM |
