On 2006-02-28, Matt Whiting wrote:
Hard to imagine a pilot so sensory impaired that he or she can't detect the loss of 50% of their power, which results in lost of far more than 50% of most performance attributes. I'd really not want to fly with a pilot who was that out of touch with their airplane. I don't think that was necessarily the problem - imagine being just airborne on an obstructed and reasonably short airfield, then one of the engines quit. Although you feel the loss of thrust, it's not obvious which engine has actually failed from the yaw because there isn't any. Add to that the typical market segment for a 337 (people who percieve they won't be safe enough in a normal twin) and you're asking for trouble. The only way of figuring out which engine has quit short of pulling a throttle back and see if you lose even *more* power (which is ineffective if one engine is only losing partial power) is to look at the gauges. You might not even notice the loss of an engine if it happens on approach until you throttle up for a go-around and find up to 50% of your power is missing (if an engine fails on approach, the only indication may be a decreasing EGT - the windmilling prop may still make the same RPM and the manifold pressure does not change if an engine isn't actually combusting fuel). Even if one fails on takeoff, where the failed engine will almost certainly lose RPM you still have to look at and interpret the gauges which is a slower process (particularly if it's a high workload instrument departure) than 'dead foot dead engine'. The people who are liable to VMC roll a conventional twin are probably the same people who will stall a 337 while taking their time over trying to figure out which engine has quit. -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
"Dylan Smith" wrote in message
... [...] The people who are liable to VMC roll a conventional twin are probably the same people who will stall a 337 while taking their time over trying to figure out which engine has quit. I don't see how this is an issue. With centerline thrust, the pilot shouldn't NEED to know which engine has quit. The primary reason for knowing which engine has quit in a convential twin is so you can use the correct control inputs. With centerline thrust, you just keep flying the airplane. Why would any pilot spend any time trying to figure out which engine has quit on a 337? What are they going to do with that information, at least in the immediate sense? Pete |
... I don't see how this is an issue. With centerline thrust, the pilot shouldn't NEED to know which engine has quit. Perhaps there is a need to feather the prop on the dead engine to cut drag? |
"Grumman-581" wrote in message
... Perhaps there is a need to feather the prop on the dead engine to cut drag? Ahh...good point, thanks. |
Sorry Duniho, the "dufus" guy was somebody else. My mistake.
Dudley Henriques "Peter Duniho" wrote in message ... "Grumman-581" wrote in message ... Perhaps there is a need to feather the prop on the dead engine to cut drag? Ahh...good point, thanks. |
![]() Dudley Go over the proedure for the troops about losing the wrong engine on Take Off and having to leave the engine wind milling to have enough hydraulic pressure to slowly retract the gear before you can feather the prop and the donut rings you cut doing this. Big John `````````````````````````````````````````````````` ``````````````` On Tue, 28 Feb 2006 21:51:35 GMT, "Dudley Henriques" wrote: Sorry Duniho, the "dufus" guy was somebody else. My mistake. Dudley Henriques "Peter Duniho" wrote in message ... "Grumman-581" wrote in message ... Perhaps there is a need to feather the prop on the dead engine to cut drag? Ahh...good point, thanks. |
You need to know hoe to identify the dead engine and feather
the correct prop, otherwise you're going down. In a conventional twin identification is holding heading with rudder, "dead foot dead engine" and the litany is CONTROL POWER (up) DRAG (gear and flaps) IDENTIFY VERIFY FEATHER FLY secure it In the 336/337 it isn't as easy or obvious which engine is sick or dead. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "Dylan Smith" wrote in message | ... | [...] | The people who are liable to VMC roll a conventional twin are probably | the same people who will stall a 337 while taking their time over trying | to figure out which engine has quit. | | I don't see how this is an issue. With centerline thrust, the pilot | shouldn't NEED to know which engine has quit. The primary reason for | knowing which engine has quit in a convential twin is so you can use the | correct control inputs. With centerline thrust, you just keep flying the | airplane. Why would any pilot spend any time trying to figure out which | engine has quit on a 337? What are they going to do with that information, | at least in the immediate sense? | | Pete | | |
![]() "Peter Duniho" wrote in message ... "Dylan Smith" wrote in message ... [...] The people who are liable to VMC roll a conventional twin are probably the same people who will stall a 337 while taking their time over trying to figure out which engine has quit. I don't see how this is an issue. With centerline thrust, the pilot shouldn't NEED to know which engine has quit. The primary reason for knowing which engine has quit in a convential twin is so you can use the correct control inputs. With centerline thrust, you just keep flying the airplane. Why would any pilot spend any time trying to figure out which engine has quit on a 337? What are they going to do with that information, at least in the immediate sense? Pete With a conventional twin you "just keep flying the airplane" as well. It's HOW you keep flying the airplane that matters. Any "dufus" as you have said, who thinks that just because those engines are in line on the 337 means you don't have a prop drag issue with engine failure needs to go out on a hot Sunday afternoon on a short runway with trees at the end and lose one at rotation! Dudley Henriques |
Dylan Smith wrote:
On 2006-02-28, Matt Whiting wrote: Hard to imagine a pilot so sensory impaired that he or she can't detect the loss of 50% of their power, which results in lost of far more than 50% of most performance attributes. I'd really not want to fly with a pilot who was that out of touch with their airplane. I don't think that was necessarily the problem - imagine being just airborne on an obstructed and reasonably short airfield, then one of the engines quit. Although you feel the loss of thrust, it's not obvious which engine has actually failed from the yaw because there isn't any. Add to that the typical market segment for a 337 (people who percieve they won't be safe enough in a normal twin) and you're asking for trouble. In a center-line twin, why does it matter which engine failed? You have to adjust to the reduced thrust no matter which engine gave up, right? Sure, you need to feather the correct prop and secure the dead engine, but that doesn't have to be done in the first millisecond after failure. And it isn't that hard to look at the gauges and decide which one quit. Matt |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
