Not correct, at least in the USA. There are some jets that
don't have a Vmca as such because the engines are so close to the centerline and although they have two engines, they don't meet the FAA requirement for issuing an unrestricted multiengine certificate. If you obtain your multiengine certificate in such an airplane you are issued a multiengine rating with the centerline thrust limitation. But as it is a turbojet/12.5 gw, a type rating is required also. The Cessna 337 is lighter than the weight floor for requiring a type rating and it is not a turbojet. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jose" wrote in message . com... | Just what did the FAA issue then? | A 'centerline only' thrust limitation to the ME rating. | | Not only that, but if you have a regular multiengine rating, you still | can't fly the thing unless you get a type rating (or somesuch) for it. | | Jose | -- | Money: what you need when you run out of brains. | for Email, make the obvious change in the address. |
Jim Macklin wrote:
Not correct, at least in the USA. There are some jets that don't have a Vmca as such because the engines are so close to the centerline and although they have two engines, they don't meet the FAA requirement for issuing an unrestricted multiengine certificate. I don't think Vmc is the issue, just the failure to be able to demonstrate handling asymetric thrust. There are some regular twins where the Vmc is pretty much aligned with the stall speed. |
Jim Macklin wrote:
Not correct, at least in the USA. There are some jets that don't have a Vmca as such because the engines are so close to the centerline and although they have two engines, they don't meet the FAA requirement for issuing an unrestricted multiengine certificate. If you obtain your multiengine certificate in such an airplane you are issued a multiengine rating with the centerline thrust limitation. But as it is a turbojet/12.5 gw, a type rating is required also. Are these mainly the bizjets? Matt |
Matt Whiting wrote
Are these mainly the bizjets? And F-4s, F-14s, F-18s and the like. Bob Moore |
On Sun, 05 Mar 2006 19:57:58 GMT, Bob Moore
wrote: Matt Whiting wrote Are these mainly the bizjets? And F-4s, F-14s, F-18s and the like. Yes, my brother in law has a multi rating with centerline restriction... ex-USAF (F-15 etc.); he now instructs people with a lot more money than I have in L-39's. -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
