Why didn't the Cessna 337 make it?
Old February 28th 06, 09:00 PM posted to rec.aviation.piloting
Default Why didn't the Cessna 337 make it?
I have been thinking that it would be cool to refit an old 337 with
twin jet engines mounted in place of the rear engine with snorkles for
the intakes and a nose extension fairing in place of the front engine
for drag reduction and CG adjustment. Given the advances in small jet
engines in recent years, this might be feasible. Imagine the rate of
climb you would get. You could run the throttles at a modest setting
for cruise.
There is an experimental aircraft for you!
Dean
Dallas wrote:
Looking at the design of the C377, it seems like it should have been more of
a winner. Why did it flop?
Dallas
Old February 28th 06, 09:09 PM posted to rec.aviation.piloting
wrote)
I have been thinking that it would be cool to refit an old 337 with twin
jet engines mounted in place of the rear engine with snorkles for the
intakes and a nose extension fairing in place of the front engine for drag
reduction and CG adjustment. Given the advances in small jet engines in
recent years, this might be feasible. Imagine the rate of climb you would
get. You could run the throttles at a modest setting for cruise.
I'm waiting to see the real world numbers for the HondaJet - Plane and/or
engine.
Engine guys at Oshkosh said Honda was considering selling just the power
plant to others.
Montblack
Old February 28th 06, 09:31 PM posted to rec.aviation.piloting
The Eclipse 500 will sell for about what a new Beech 58G
Baron will sell for, as soon as I win the lottery, I'll make
my deposit.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Montblack" wrote in
message ...
| wrote)
old 337 with twin
snorkles for the
jet engines in
of climb you would
cruise.
| engine.
just the power
| plant to others.
| Montblack
Old February 28th 06, 09:12 PM posted to rec.aviation.piloting
snip
Actually, you would be implementing / developing an STC, not building a new
experimental aircraft... The rules are a bit stricter for that...
Old February 28th 06, 09:25 PM posted to rec.aviation.piloting
Knowing how flimsily Cessna tends to make their designs,
using the thinnest possible metals, etc, a re-engine job is
critical. Airplanes have speed and power limits, both for
structural strength and aerodynamics...the 337 is pretty
well at that point as sold by Cessna.
337 with
snorkles for
front engine
in small jet
the rate of
modest setting
| for cruise.
| Dean
| Dallas
Old February 28th 06, 09:37 PM posted to rec.aviation.piloting
Hi Jim,
That is true, but if the jet engines were small enough they wouldn't
necessarily overpower the airframe. There are some really small
turbines out these days...
Dean
Old March 1st 06, 02:06 AM posted to rec.aviation.piloting
A jet needs to be faster to be efficient, the airframe is
not designed for Mach 0.60, let alone real jet speeds.
| Hi Jim,
they wouldn't
small
| Dean
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
