"paddydix" wrote in message
nk.net... That is true ,..and please add in some Repair manuals if the left or right hand is is called for IT HAS TO BE DONE or it will not pass FAA. No need to shout, Paddy. I won't add that bit of advice because this is the homebuilt newsgroup. An aircraft certificated under the Experimental Amateur built class need not comply with a repair manual. You can glue your nuts on using Barge's All Purpose Sealer if'n you want. Rich "Mebbe I should rephrase that???" S. |
I Wanna Build an Aeroplane | Badwater Bill | Home Built | 71 | August 19th 03 02:24 PM |
