#211
OK, I'll buy this. I should remind everyone that I am still
talking about an infinite wing, having no induced drag. I claim that my statement is generally true, and does not require an infinite wing, just an infinite air field (as per the example I'm developing). However, air will still have to be accelerated downwards to keep the airplane from succumbing to gravity. No it won't. Now we have no acceleration of the plane upwards. It's true that the wing must still throw air down, but now it's catching the air that is rising ahead of the wing, and throwing it down at a speed that exactly matches the rising speed of the air. Thus, the net downward speed of the air is zero and the wing leaves undisturbed air behind it.. Yes, it will. The rising air in front of the wing doesn't rise by magic. It doesn't rise before the wing does its thing (though it may rise before the wing gets there); it rises =because= the wing is doing its thing, which is throwing the air down (where it pushes the other air aside, and that other air has to go somewhere). Think about it. There's no earth, just this "magic plane gravity" which pushes the airplane down. Something has to push up on the plane to keep it in the air. The air can't push up (the way the runway can) because the air is fluid - it smooshes out of the way and lets the plane through. The only way the air can push up is by being thrown down - accelerated at a rate that matches the acceleration due to "magic plane gravity". A wing not only keeps the plane away from the earth, it keeps the earth away from the plane. If you could measure the total forces on the earth due to everything on top of it (essentially making the earth a giant bathroom scale), the reading would not change when an airplane takes off. Even though the plane is not touching the earth, it is throwing air down at the earth, and that impact registers as weight. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#212
'Dissipation' is flow. If you include that dissipation into your
sum, there is no net flow. Otherwise, as stated above, the ambient pressure at ground level would steadily increase and, as you note below, the pressure higher up woudl steadily drop. But the ambient pressure at ground level =does= increase, by an amount equal to the weight of the airplane (divided by the surface area of the earth). This remains true for as long as the airplane is being "supported" by the air. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#213
![]() wrote: In the real world there are many photographs of huge canyons carved in layers of cloud and smoke as airplanes fly over them, Cool! Got any links to some? How about pictures of airplanes flying just below the ceiling? The most famous photo is one that you can see on this site he http://adamone.rchomepage.com/index4.htm He has the caption wrong, though. The Citation never flew through the cloud, only over it. Pictures of airplanes flying just below the ceiling are an interesting idea, but I have not seen any. Usually the ceiling is fairly ill defined and ragged anyway. |
#214
Jose wrote:
Occom's Razor, Jose. Yes, but Occam's razor needs to work with theories that explain the facts. Fact is, the down on an airplane =is= laterally separated from the up, and airplanes fly only when they move forward. If Occam's razor were so simple, we wouldn't have million dollar grants. Jose OK, Jose (just had to say that one) explain delta wings. http://ernest.isa-geek.org -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
#215
![]() Jose wrote: I think you are refering to Newton's third law, often stated as: "For every action there is an equal and opposite reaction." Yes. For an aircraft in level flight, the upwards acceleration due to lift is counterbalanced by the downward acceleration due to gravity. This satisfies Newton's third law. Yes. For a wing in level flight, the vertical component of momentum is zero. No. Please show us your arithmetic. Suppose a 1500 lb airplane is flying horizontally at 120 mph at 5000 feet above MSL. What are the vertical and horizontal components of the momentum of that aircraft? That is, on a microscopic scale, no. The wing is constantly freefalling, then being bounced back up by impact with air molecules. Averaged over all the molecules, yes, the net is zero (the wing flies) but on a microscopic scale, the wing is in constant brownian motion. This implies momentum transfer, and following the momentum on a microscopic scale is instructive. OK, show us your arithmetic. The wing imparts as much upward momentum to the air as it does downward momentum. This is where I disagree. Upward momentum gets imparted, but not (directly) by the wing. Rather, it is imparted by the ground, mediated through other air molecules. The ground is stationary. How does the stationary ground impart momentum to anything? Of course this wouldn't happen if the wing didn't pass through and throw the air down to begin with, but the ground is what ultimately imparts the upwards momentum. The pressure differential through the wing, from bottom to top, integrated over the wing area, provides an upward force for a wing in level flight. That's the shortcut. Where does this pressure differential come from - Bernouli effect. that is the question. The downwash behind the aircraft, which is counterbalanced by a more diffuse upwash around it, is real but not relevent to the issue of lift. I disagree here too. It's important in seeing the entire picture. Well, yes it is part of the entire picture. Its just not relevent to the issue of lift, which is only part of the picture. -- FF |
#216
Dan wrote in news:L_1Nf.55333$Ug4.44233@dukeread12:
george wrote: Richard Lamb wrote: Al wrote: Remember, Time flies like an arrow... Fruit Flies Like a Banana... Do all fruit flies have bannana ratings ? :-) Only visual banana rules in most cases. I heard the IBR are a tad tough. Dan, U.S. Air Force, retired The scarcity of tiny instrument training hoods or banana simulators makes it even more difficult. |
#217
First, do you agree that air is made of individual molecules separated by a lot of space compared to the size of the molecules themselves? Then do you accept that a wing is in freefall during all the (very brief but very numerous) time in between molecular collisions? (If not, what holds it up when it is not in contact with any air molecules?) If so, then during the time it is in freefall, it acquires a downward velocity. Small, no doubt, but nonzero. The next molecular impact pushes it back up. On the average they will sum to a net zero vertical motion. Is this the arithmetic you want to see? The ground is stationary. How does the stationary ground impart momentum to anything? The ground is not stationary. Like the wing, the ground is jiggling around in brownian motion. Such motion is greatly overwhelmed in quantity by other things, but it is nonzero. Gravity pulls the ground towards the airplane just as strongly as it pulls the airplane towards the ground. This is the same effect as the one that gives high tides on the side of the earth that is away from the moon. Where does this pressure differential come from - Bernouli effect. That's the shortcut. Where does the Bernoulli effect come from - on a molecular level? That's what I'm addressing. The Bernoulli effect is a shortcut for doing the calculation in bulk (where it makes the most sense if you want a numerical answer) but it all comes from molecular collisions. Its just not relevent to the issue of lift, which is only part of the picture. We disagree here. Both explanations are true as far as they go, but it is important to see just how far they go (or don't go). The Beruoulli effect does not explain, for example, how the earth ultimately supports the aircraft, nor how the upwash starts (for example, suppose there were a vertical column of vacuum separated from the air by a very strong piece of cellophane. A wing travels through the vacuum and penetrates this cellophane. The air behind the cellophane does not rise up to meet the wing - it has no idea there's a wing coming. Once the wing has entered the air, that rising motion will start, but why? That's the question to which I am applying my molecular model. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#218
Richard Lamb wrote:
Sez one old fart to another??? Al wrote: Richard you give away your age. Only an "Old Fart" would know that. Al "Richard Lamb" wrote in message ink.net... Al wrote: Remember, Time flies like an arrow... Fruit Flies Like a Banana... Grouch Marx! Well _I_ really do know how to spell it. and now, my spell checker does too... ![]() |
#219
![]() Jose wrote: fredfighter wrote: Please show us your arithmetic. Suppose a 1500 lb airplane is flying horizontally at 120 mph at 5000 feet above MSL. What are the vertical and horizontal components of the momentum of that aircraft? That is, on a microscopic scale, no. The wing is constantly freefalling, then being bounced back up by impact with air molecules. Averaged over all the molecules, yes, the net is zero (the wing flies) but on a microscopic scale, the wing is in constant brownian motion. This implies momentum transfer, and following the momentum on a microscopic scale is instructive. OK, show us your arithmetic. First, do you agree that air is made of individual molecules separated by a lot of space compared to the size of the molecules themselves? Yes. Then do you accept that a wing is in freefall during all the (very brief but very numerous) time in between molecular collisions? (If not, what holds it up when it is not in contact with any air molecules?) Yes. If so, then during the time it is in freefall, it acquires a downward velocity. Small, no doubt, but nonzero. Sometimes it does, sometimes it does not. I'll allow as the vertical component of velocity decreases during that time, for a positive up coordinate system and a plane in (macroscopic) level flight. Do you agree that in each collision momentum is transferred to the air molecule that is equal and opposite to the momentum transferred to the wing? The next molecular impact pushes it back up. On the average they will sum to a net zero vertical motion. Is this the arithmetic you want to see? No, I want you to calculate the horizontal and vertical componenets of momentum for the example I gave, or any other reasonable example of a fixed wing airplane in horizontal flight. ... That's the shortcut. Where does the Bernoulli effect come from - on a molecular level? That's what I'm addressing. The Bernoulli effect is a shortcut for doing the calculation in bulk (where it makes the most sense if you want a numerical answer) but it all comes from molecular collisions. I agreed quite some time ago that the theoretical basis for macroscopic gas laws is to be found in statistical mechanics. On a macroscopic level, the vertical component of momentum of the wing is zero. Therefor on a macroscopic level, the sum of the momenta transferred to the air molecules, integrated over all of the air molecules must also be zero by Newton's third law. Right? For an airplane in straight level flight there is no net momentum transfer in the vertical direction, between the air and the airplane, just like there is no net vertical force acting on the airplane. -- FF |
#220
velocity. Small, no doubt, but nonzero. Sometimes it does, sometimes it does not. I'll allow as the vertical component of velocity decreases during that time, for a positive up coordinate system and a plane in (macroscopic) level flight. Ok. (I was sloppy - it doesn't "acquire a downward velocity", it really "endures a downward acceleration", which depending on the initial vertical velocity may or may not end up with the plane going downward.) So we are saying the same thing here. Do you agree that in each collision momentum is transferred to the air molecule that is equal and opposite to the momentum transferred to the wing? Yes I do. This is what I call "throwing the air down". That downward momentum will remain with the air (dissipated across many other molecules as it keeps colliding, but never disappearing) until it is transferred to the earth, which has been accelerating upwards in the same fashion. I agreed quite some time ago that the theoretical basis for macroscopic gas laws is to be found in statistical mechanics. Ok. On a macroscopic level, the vertical component of momentum of the wing is zero. Yes. Therefor on a macroscopic level, the sum of the momenta transferred to the air molecules, integrated over all of the air molecules must also be zero by Newton's third law. Right? Only in a nonaccelerated frame. We are dealing with an accelerated frame. Consider a rocketship hovering over the moon. The (macroscopic) vertical component of its momentum is zero also. However it has to continually throw down rocket exhaust to stay there. So, without looking at the rest of the picture, your conclusion about momentum is flawed. In the case of the wing, the momentum is transferred a few times... once when the wing hits the air molecule (throwing the air down), again when that molecule hits the earth and bounces back (throwing the earth away from the wing), and then again when that air molecule (or its proxy) hits the wing on the way back up. Think about a person sitting on a stool. No momentum transfer (or so it would seem). But then think about a person supporting himself by dribbling a basketball. There is a lot of momentum transfer, but no =net= change. The reason there is no net change is that the basketball keeps pushing the earth away too. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 05:45 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
