The Impossibility of Flying Heavy Aircraft Without Training
Old March 2nd 06, 06:43 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default lift, wings, and Bernuolli
Two years ago when I was in college I used to read science journals for
fun... One particular, just published within the past two years
(spring '04?) caught me.
It discussed the Bernuolli theory of flight- and (if I recall) quite
conclusively proved that one of the _fundamental_ assumptions of the
Bernuolli theory- that air that travels path over the top of the wing
is flowing appreciably faster than air that flows over the bottom- is
simply incorrect in a compressible fluid....
Obviously, you should take this with a grain of salt because A- this is
my first post on this board and B- I can't remember either the journal
or the exact date... but take it for what its worth
Old March 3rd 06, 01:27 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
On Wed, 1 Mar 2006 at 22:43:58 in message
.com,
There is not really a Bernoulli theory of lift. Bernoulli's theory
shows the relationship between the velocity and pressure of fluid flow
when energy is not added or removed and the flow is subsonic. It is a
very simple theory which is correct for much of the time. It quite
accurately, at lower speeds, represents the velocity and pressures
between streamlines.
The air does flow faster over the top than the bottom and for the lower
subsonic region air behaves very closely to being incompressible.
Generally pressure changes are transmitted at the velocity of sound.
At high subsonic and of course at supersonic speed the effect of
compressibility cannot be ignored.
Shock waves form, first on places like the top surface of the wing where
the air first reaches the velocity of sound. As the speed rises they
become bigger and move towards the leading and trailing edges. Above
Mach one the air does not detect the approaching aircraft! :-)
I have just read a few more messages in this thread and discussing lift
in this general way without maths and without using at least simple
physics and slowly developing the methods is almost futile.
What's it matter about lift as long as the aircraft fly? !!!!!
David CL Francis
Old March 3rd 06, 02:27 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
I hate to be a spoil sport (or dullard?), but...
the (stationary) air does WHAT (as the wing passes by)???
Old March 7th 06, 12:50 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
On Fri, 3 Mar 2006 at 02:27:02 in message
. net, Richard Lamb
The nature of things is such that the situation does not change if you
change the frame of reference. It is normal in doing calculations to
start with a frame of reference based on the aircraft. If you follow the
aircraft then the air is going past it.
The presence of the wing changes the air flowing past the aircraft in
the same way as if you consider the aircraft passing through the air.
The 'stationary' air as you call it has its local velocity and direction
changed by the aircraft.
David CL Francis
Old March 7th 06, 02:15 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
. net, Richard Lamb
Yeahbut...
A handy frame of reference is - handy.
But it can be very misleading.....
Old March 7th 06, 03:58 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
. net, Richard Lamb
the aircraft then the air is going past it.
direction changed by the aircraft.
Yeahbut...
For instance?
If the air is moving, we expect a lower pressure. Nod to Bernoulli.
But the air would also be moving along the bottom side of the wing also?
And what would that do to the pressure under the wing?
And if the pressure under the wing is below ambient....
Old March 3rd 06, 09:21 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
On Fri, 03 Mar 2006 01:27:46 +0000, David CL Francis wrote:
Above
If it did, what would happen?
On Fri, 3 Mar 2006 at 15:21:11 in message
, "00:00:00Hg"
Above
The whole point is that disturbances in the air are propagated at or
near the velocity of sound. It follows that at supersonic speeds
nothing happens to the air until it reaches the supersonic aircraft, or
vice versa.
David CL Francis
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 05:45 AM
