Earlier, UltraJohn wrote:
My question, How much permanent deflection in the wings after the test? I think that that is one of the most central questions in this exchange. If there was no permanant deflection, then the material never reached its 35 ksi (some books like Machinery's Handbook say 40 ksi) yield stress, and without deflection records we'll never really know how close the test wing came to actually failing. Overall, I'm satisfied with the descriptions that a fairly valid static test was done. However, I know from watching videos of static tests and from running deflection estimates for various wings that tests even to just the design limit can result in some seriously spooky deflections. And to add to that, the spar under consideration here is very shallow, and that will also tend to give it a lot of deflection. One thing I would have expected for a test like this is a comparison between the wing under test and some sort of deflection reference like a template. Since the spar in this case has a constant depth of 2", the same template can be applied anywhere on the spar to check the deflection and deduce the stress from that. If I've run the numbers right, for a 2" tall aluminum (Young's modulus of 10 meg) element, at 35 KSI in the extreme fibers the element will have a curvature radius of about 20 feet. That may sound like a pretty shallow curve, but over four feet it results in a bend of about 9.5 degrees and a vertical deflection of about 4". But don't take my word for it, I'm _not_ an engineer... Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation | Richard Lamb | Home Built | 12 | August 9th 05 08:00 PM |
want to trade 601 plans for 701 plans | [email protected] | Home Built | 0 | January 27th 05 07:50 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Texas Soars into Aviation History | A | Piloting | 7 | December 17th 03 02:09 AM |
good book about prisoners of war | Jim Atkins | Military Aviation | 16 | August 1st 03 10:18 AM |
