![]() "Gary Drescher" wrote in message ... A clearance to taxi to the active runway is implicitly a clearance to taxi across any other runways that are in your path. What's implicit about it? If you're cleared to taxi to runway XX and runways YY and ZZ are between you and runway XX then are you not explicitly cleared to cross runways YY and ZZ? How else could you comply with the clearance to taxi to runway XX? As AOPA has pointed out, it would be safer if you needed an explicit clearance to cross any runway, whether or not it's active. Otherwise, a pilot who's disoriented (but doesn't know it) may cross the active runway thinking it's an inactive one. How is that safer? A clearance to "taxi to" the runway assigned to the aircraft is a clearance to cross ALL other runways that intersect the taxi route to that assigned takeoff runway, active or inactive. |
ink.net... "Gary Drescher" wrote in message ... A clearance to taxi to the active runway is implicitly a clearance to taxi across any other runways that are in your path. What's implicit about it? If you're cleared to taxi to runway XX and runways YY and ZZ are between you and runway XX then are you not explicitly cleared to cross runways YY and ZZ? No, you're implicitly cleared to cross runways YY and ZZ. How else could you comply with the clearance to taxi to runway XX? No other way. That's why the clearance to cross YY and ZZ is implicit in the clearance to taxi to XX. But in order to be explicit, crossing YY and ZZ would have to be *mentioned* in the clearance too. That's the difference between being implicit and being explicit. As AOPA has pointed out, it would be safer if you needed an explicit clearance to cross any runway, whether or not it's active. Otherwise, a pilot who's disoriented (but doesn't know it) may cross the active runway thinking it's an inactive one. How is that safer? A clearance to "taxi to" the runway assigned to the aircraft is a clearance to cross ALL other runways that intersect the taxi route to that assigned takeoff runway, active or inactive. Here's how requiring runway-crossing clearances to always be explicit would be safer safer. Suppose a pilot is in a situation where it is *not* necessary to cross any runway in order to taxi for takeoff. If the pilot is lost (but doesn't know it), he may mistakenly *think* he needs to cross a runway and may then do so unexpectedly, possibly conflicting with other traffic. (I've actually witnessed that happening.) If runway crossings always required an explicit clearance, the pilot who hadn't received such a clearance would thereby know he shouldn't be crossing any runways, regardless of where he thinks he is or thinks he's going. --Gary |
. .. [...] That's the difference between being implicit and being explicit. I sense a bout of pig wrestling approaching... ![]() |
![]() Peter Duniho wrote: "Gary Drescher" wrote in message . .. [...] That's the difference between being implicit and being explicit. I sense a bout of pig wrestling approaching... ![]() Peter! If you get a moment, please check the RAS newsgroup and a message I left for you. As stated, I've been away from the real McCoy and the sims too but hey, after I spied a few known monikers in both groups, it's always helpful to get some input which can save much vexation. Real McCoy stuff .... or screen virtual versions therein. TIA! Doc Tony |
If I am aware of potential conflicts, I will counteract the implied
clearances by making them explicit. If there are crossing runways active, I will sometimes make those crossings explicit. Tower: "3094P, taxi to runway 16." Me: "Taxi to runway 16, crossing 24, 3094P" Same for taxiways. At my home airport, there are two ways out of the parking area. One of them is the best way to bring planes into the terminal area. But, I am parked closer to that taxiway. I don't go out that way if I know that there are planes coming in. Most of the other planes use the other exit because it is more on the way toward the main part of the airport. Sometimes the tower adds a specific taxiway in the clearance but often not. To avoid a mistaken assumption on the tower's part, I will make it explicit so that they have a chance to stop me, if they want. Tower: "3094P, taxi to runway 16." Me: "Taxi to runway 16 via Alpha, 3094P." Once, they responded with a give way request, Tower: "Alpha's fine. Just give way to the Hawker that's doing a 180 in the runup pad and will be coming in to the ramp." Another time, they ask that I go out the other way, Tower: "Can you use Bravo? I've got a fuel truck coming across in a few minutes." Me: "3094P will use Bravo to runway 16." -- ------------------------------- Travis "Gary Drescher" wrote in message . .. "Steven P. McNicoll" wrote in message ink.net... "Gary Drescher" wrote in message ... A clearance to taxi to the active runway is implicitly a clearance to taxi across any other runways that are in your path. What's implicit about it? If you're cleared to taxi to runway XX and runways YY and ZZ are between you and runway XX then are you not explicitly cleared to cross runways YY and ZZ? No, you're implicitly cleared to cross runways YY and ZZ. How else could you comply with the clearance to taxi to runway XX? No other way. That's why the clearance to cross YY and ZZ is implicit in the clearance to taxi to XX. But in order to be explicit, crossing YY and ZZ would have to be *mentioned* in the clearance too. That's the difference between being implicit and being explicit. As AOPA has pointed out, it would be safer if you needed an explicit clearance to cross any runway, whether or not it's active. Otherwise, a pilot who's disoriented (but doesn't know it) may cross the active runway thinking it's an inactive one. How is that safer? A clearance to "taxi to" the runway assigned to the aircraft is a clearance to cross ALL other runways that intersect the taxi route to that assigned takeoff runway, active or inactive. Here's how requiring runway-crossing clearances to always be explicit would be safer safer. Suppose a pilot is in a situation where it is *not* necessary to cross any runway in order to taxi for takeoff. If the pilot is lost (but doesn't know it), he may mistakenly *think* he needs to cross a runway and may then do so unexpectedly, possibly conflicting with other traffic. (I've actually witnessed that happening.) If runway crossings always required an explicit clearance, the pilot who hadn't received such a clearance would thereby know he shouldn't be crossing any runways, regardless of where he thinks he is or thinks he's going. --Gary |
everything. If you're cleared to taxi to runway XX and runways YY and ZZ are between you and runway XX then are you not explicitly cleared to cross runways YY and ZZ? No. How else could you comply with the clearance to taxi to runway XX? That is the essence of an implicit clearance. "How else could you do it?" Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
"Steven P. McNicoll" writes:
"Gary Drescher" wrote in message ... A clearance to taxi to the active runway is implicitly a clearance to taxi across any other runways that are in your path. What's implicit about it? If you're cleared to taxi to runway XX and runways YY and ZZ are between you and runway XX then are you not explicitly cleared to cross runways YY and ZZ? How else could you comply with the clearance to taxi to runway XX? No; in fact that's a poster-child for what "implicit" means. Nowhere in that clearance are runways YY or ZZ even mentioned. It is *implied* that you may cross them, since they're on the way, but it's not *explicitly* stated. As AOPA has pointed out, it would be safer if you needed an explicit clearance to cross any runway, whether or not it's active. Otherwise, a pilot who's disoriented (but doesn't know it) may cross the active runway thinking it's an inactive one. How is that safer? A clearance to "taxi to" the runway assigned to the aircraft is a clearance to cross ALL other runways that intersect the taxi route to that assigned takeoff runway, active or inactive. One way: I hear it's pretty easy to get lost on a big, unfamiliar airport. So, if you *think* you're on the way to the runway you're cleared to, and you come to another runway you need to cross, you'll assume you're implicitly cleared to cross it. But if you are in fact lost, and this runway *isn't* on the way to the one you're cleared to, then you aren't actually cleared to cross it. Oops. If the clearance had been explicit, you'd have a chance at noticing that the runway in your way wasn't one of the ones you were *explicitly* cleared to cross. -- David Dyer-Bennet, , http://www.dd-b.net/dd-b/ RKBA: http://noguns-nomoney.com/ http://www.dd-b.net/carry/ Pics: http://dd-b.lighthunters.net/ http://www.dd-b.net/dd-b/SnapshotAlbum/ Dragaera/Steven Brust: http://dragaera.info/ |
