#271
![]() Jose wrote: In open air the volume of air moving around the fan is larger, but moving at a lower speed than the air moving through the fan so that the momenta of the flow in either direction is equal magnitude and opposite in direction to the flow in the other direction. Seems to me "almost equal" would make more sense, otherwise an airplane propeller would not work. A propeller throws air backwards (alabeit imperfectly); the airplane moves forwards in response. For the stationary fan if it were only _almost equal_ then you would eventually run out of air on one side of the fan. Air molecules flowing through the propellor cetainly experience momentum changes. But you can have a net flow of energy without a net exchange of momentum because momentum is a vector, energy is a scaler. If the airplane is in level flight at constant speed it does not NEED to gain any momentum from the propellor because the momentum of the airplane is not changing. It needs force to counter the force of drag. Consider your example of the person who 'hovers' by dribbling a basektball. His momentum is zero, the momentum of the Earth is zero and the momentum of the ball is constantly changing and reverses twice each dribble. The dribbler is pumping energy into the Earth yet there is no net exchange of momentum. -- FF |
#272
The flying wing has some horizontal momentum which is secondary here,
How much? mv The air thrown forward (or, if you will, the higher pressure ahead) tries to reduce that, the engine presumably makes up for it. Energy is 'pumped' into the air by the plane. Yes, and what form does that energy take? I maintain that it takes the form of a net increase in mv^2/2 over all the air molecules. Since m doesn't change, and 2 only changes in a pentium, that leaves v to change. This changes mv, thus momentum. We agree that there is (microsocopic) momentum transfer at each collision. We disagree as to whether the net is zero, and I think that part of that disagreement has to do with just how much of the system we are looking at. The wing throws air down. If that causes other air to be squeezed up, so be it - the wing will grab that air and throw it down again. The air piles up in front of and below the wing, and ultimately pushes on the earth. New (undisturbed) air keeps appearing in front of the wing (where it is pushed up, and then back down). But if, instead of feeding this system fresh air, we instead feed it the same air, say, by flying around in circles, there will be a net movement of air. Air will be sucked from the (infinite amount of) air above, and pushed down into the (infinite volume of) air below. The next time the wing encounters this area, there will already be downward movement of air from the first passage... etc. etc. and so forth. Momentum is conserved in elastic collisions Low speed collisions between air molecules and aluminum sheets are to first order elastic (although some energy goes into making molecules wiggle and spin, and I suppose an electron is knocked out every now and again). Roll the airplane into a 90 degree bank. The weight is now orthogonal to the lift. As teh airplane falls, it banks even though there is no Earth 'under' the belly. Why? I'm not sure I understand the question. But if you put an airplane in a knife edge and let it dive as it will, and maintain a lift-producing AOA, the wing will push air in the belly direction, as it pushes itself against that air in the antibelly direction. Some of that air will swirl around the wing, but enough of it will dissipate the momentum that the wing imparted to it over the entire atmosphere, and there will be a (very) slight breeze blowing in the belly direction. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#273
![]() Jose wrote: What is the net momentum change when the airplane falls to the ground? The vertical compenent first rises from zero to Vt * M where Vt is the terminal velocity of the falling aircraft and M is the mass of the falling aircraft. Then the vertical component of momentum RAPIDLY drops to zero again after the aircraft contacts the ground. Well, actually, only sorta. The momentum of the airplane is equal to the momentum of the earth, except in sign. Net is zero. The center of mass of the earth/airplane does not move. Leave the earth out of it and just look at the aircraft, and you are correct. And to keep an airplane up, in view of this acceleration, an opposite acceleration needs to be applied. Air must be thrown down with sufficient (net) force to counteract gravity's attempt to accelerate the wing downwards. No. You can also generate an upward force on an airplane by creating low pressure over the upper surface of the wing while the pressure below the wing remains at ambient. I dunno if there are any airfoils that leave the air below the wing exactly the same as ambient, but if there were, it would fly. There is no NEED to throw anything downward. -- FF |
#274
you would eventually run out of air on one side of the fan. No, the pressure would build up on one side of the fan, and that pressure would push against the wall and against the other air that is being pushed by the fan. When the pressure on that side is sufficiently high, no more (net) air will be able to be smooshed together on that side, and the air will all be going around. But a pressure difference will be maintained until the fan is turned off. Consider your example of the person who 'hovers' by dribbling a basektball. His momentum is zero, the momentum of the Earth is zero and the momentum of the ball is constantly changing and reverses twice each dribble. The dribbler is pumping energy into the Earth yet there is no net exchange of momentum. I agree. Overall, no net change. Microscopically (at each impact) there is a momentum change. Inbetween dribbles, the earth and the dribbler experience momentum changes which each dribble then counteracts. Now look at the same situation with a "basketball transparant" earth, and an endless supply of basketballs being tossed at the dribbler (who is backed up against a frictionless wall, so for now we don't need to consider horizontal forces). The dribbler keeps on deflecting basketballs downwards, but they don't bounce back up - they pass through the earth. The dribbler (who admittedly is no longer really dribbling) is imparting momentum to basketballs, and once he stops doing that, he will himself experience a momentum change. In both cases, as far as the putative dribbler is concerned, he is throwing basketballs down. He imparts momentum to basketballs, and really doesn't care what happens to that momentum afterwards. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#275
creating low pressure over the upper surface of the wing while the pressure below the wing remains at ambient. I dunno if there are any airfoils that leave the air below the wing exactly the same as ambient, but if there were, it would fly. There is no NEED to throw anything downward. I suppose a wing that gobbled up air molecules from the top of the wing and beamed them into outer space would do the trick. Another way would be to supercool the top surface, and let the general gas law reduce the pressure above. But doing either one, air above the air above the wing would rush down, as the air below the wing pushes the wing up into that same space. The two will collide, or the wing will have passed by then. In the latter case, downward momentum has been imparted to the air above the air above the wing, which gets dissipated as I argued for conventional wings. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#276
#277
Air is pressurized behind the speaker, just as well as the air in front of
it. That is how bass reflex speakers work. Yes, but out of phase. Air is pressurized in the direction the speaker cone is moving. It goes back and forth. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#278
#279
F = m/t * v/t; the force is equal to the rate of mass per unit time,
multiplied by the distance per unit time. I assume a typo: F = m/t * d/t (since v=d/t) Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#280
Jose wrote: F = m/t * v/t; the force is equal to the rate of mass per unit time, multiplied by the distance per unit time. I assume a typo: F = m/t * d/t (since v=d/t) Jose You assume correctly. g -- Alan Baker Vancouver, British Columbia "If you raise the ceiling 4 feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
