Why didn't the Cessna 337 make it?
Old March 5th 06, 03:46 AM posted to rec.aviation.piloting
Default Why didn't the Cessna 337 make it?
Just a few of the things.
Bought to use on trail. However if you lost an engine over the trail
the single engine altitude way they were loaded prevented you from
getting over the mountains and back to VN to land.
At cruise power, when FACing, you could turn about 270 degree's and
then got the stall warning and had to go to METO power to stay
airborne and FAC.
In 0-1 you could drop a wing and kick rudder and be on target to fire
a Willie Pete marking rocket. In 0-2 you had to fly a coordinated turn
from a base leg to the launch heading and then coordinate corrections
to get pipper on target.
In 0-1 you lost about 150 altitude and didn't pick up any airspeed to
speak of. In 0-2 you picked up a lot of airspeed and lost a lot of
altitude and had to pull a high 'G' recovery. Doing this all day tired
you out in heat and also put you closer to any ground fire from target
area.
Bird had 'X' number of feet of ground roll on take off. You couldn't
pull off and stagger into the air in a short field.
If you landed on Laderite (sp)you almost always got rear prop damage
from front prop picking up rock, gravel, Msc and it hitting the rear
prop and causing damage.
Cockpit was pretty air tight and hot at low altitude (FAC altitude) in
heat and moisture. No way to keep cool like you could in the 0-1 with
the windows open. And more and more and more...............
Big John
On Fri, 3 Mar 2006 21:57:17 -0600, "Jim Macklin"
I know they bought a lot of them, but it seems from your
tone, that you know first-hand. Tell us all.
"Big John" wrote in message
| Jim
| Not so. Be glad to tell you the limitations of 0-2 in VN.
| Big John
| On Mon, 27 Feb 2006 20:18:12 -0600, "Jim Macklin"
| wrote:
| It was not a safer twin since the failure of an engine
was
| not as quickly detected since there was no yaw, just
reduced
| performance. It did not have good baggage areas and it
was
| noisy inside.
| It was successful as a FAC aircraft in VN as the O-2
| "Dudley Henriques" wrote in
| message
link.net...
| | "john smith" wrote in message
| | Looking at the design of the C377, it seems like
it
| should have been
| | more
| | of a winner. Why did it flop?
| | My old CFI said guys would forget to start the back
| engine or not notice
| | that it would quit and end up crashing, true or not
I
| don't know but it
| | was
| | his story. I always thought it was an odd looking
| piece.
| | To that I would add that I personally think the 200
hp
| O-360's are not
| | enough power for the size and weight of the aircraft.
| | Maintenance wise, we had a cracked case on one of the
| engines that was a bit
| | costly to fix :-) and you had to monitor the EGT
| carefully on takeoff
| | because the noise was so bad you couldn't pick up an
| engine problem during
| | the run, but aside from that, fun to fly!
| | Dudley Henriques
Old March 5th 06, 04:41 AM posted to rec.aviation.piloting
Sounds underpowered, cheap and make-shift. I wonder why
they sold/bought so many of them?
| Jim
the trail
you from
degree's and
stay
| airborne and FAC.
target to fire
coordinated turn
corrections
airspeed to
a lot of
all day tired
from target
| area.
You couldn't
prop damage
hitting the rear
altitude) in
the 0-1 with
more...............
| Big John
| | Jim
VN.
| | Big John
| was
| reduced
it
| was
| | noisy inside.
| | message
link.net...
like
| it
| | should have been
| | | more
back
not
| I
| | don't know but it
| | | was
| | piece.
200
| hp
| | O-360's are not
aircraft.
| | | Dudley Henriques
Old June 2nd 06, 06:37 PM posted to rec.aviation.piloting
On Sat, 4 Mar 2006 22:41:04 -0600, "Jim Macklin"
In "our world" where people don't shoot at you, at least not very
often, it was big, roomy, and you did have a second engine without the
problems of asymmetrical thrust on an engine failure.
OTOH As I recall it was not all that fast, used a lot of gas, and as
John said, noisy and not well ventilated
If you wanted to really use gas you could get the turbo charged
version. I don't know how many of those they sold.
We had one (turbo charged version) here on the field about 10 years
ago. The guy said he'd always wanted one, but only kept it about a
year. It was eating him out of house and home for gas and maintenance.
I don't know if it was due to that specific plane or it was a trait of
the breed.
www.rogerhalstead.com
| Jim
the trail
you from
degree's and
stay
| airborne and FAC.
target to fire
coordinated turn
corrections
airspeed to
a lot of
all day tired
from target
| area.
You couldn't
prop damage
hitting the rear
altitude) in
the 0-1 with
more...............
| Big John
| | Jim
VN.
| | Big John
| was
| reduced
it
| was
| | noisy inside.
| | message
link.net...
like
| it
| | should have been
| | | more
back
not
| I
| | don't know but it
| | | was
| | piece.
200
| hp
| | O-360's are not
aircraft.
| | | Dudley Henriques
Old June 2nd 06, 10:47 PM posted to rec.aviation.piloting
Actually I [Jim Macklin] did not say it was cheap,
under-powered and make-shift.
Cessna even tried to put it on floats but it ate props with
water spray.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Roger" wrote in message
not very
without the
gas, and as
charged
10 years
it about a
maintenance.
was a trait of
| the breed.
| | Jim
over
| the trail
prevented
| you from
| degree's and
to
| stay
| | airborne and FAC.
| target to fire
| coordinated turn
coordinate
| corrections
any
| airspeed to
lost
| a lot of
this
| all day tired
fire
| from target
| | area.
| You couldn't
rear
| prop damage
| hitting the rear
(FAC
| altitude) in
in
| the 0-1 with
| more...............
| | Big John
your
| | | Jim
in
| VN.
| | | Big John
engine
| | was
just
| | reduced
and
| it
| | was
| | | noisy inside.
O-2
in
| | | message
link.net...
| like
| | it
| | | should have been
| | | | more
| back
or
| not
| | I
| | | don't know but it
| | | | was
looking
| | | piece.
| 200
| | hp
| | | O-360's are not
| aircraft.
| the
an
| | | | Dudley Henriques
Old June 4th 06, 04:44 AM posted to rec.aviation.piloting
In article em2gg.25301$ZW3.22928@dukeread04,
water spray.
Wadn't that the 336?
Old June 4th 06, 05:50 AM posted to rec.aviation.piloting
Probably, basically the same airplane with fixed gear.
Cessna did their seaplane testing at Grand Lake, in north
east Oklahoma. A pilot named George "Mally" Malischii [sp]
who also was a seaplane instructor for Spartan and a DPE.
some support
| "Jim Macklin"
with
| water spray.
Old June 4th 06, 04:43 AM posted to rec.aviation.piloting
the breed.
Not just turbocharged... pressurized AND turbocharged!
Old June 5th 06, 02:29 AM posted to rec.aviation.piloting
the breed.
I had forgotten, but yes, it was pressurized. They tell me a P-Baron
is cheaper to operate and one whale of a lot faster. Being retired
they are both out of my budget range unless I win the lottery. Then
again, if I plan on that I should probably buy a ticket.
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
