Nav Lights using Luxeon LEDs
Old March 5th 06, 04:07 PM posted to rec.aviation.homebuilt
Default Nav Lights using Luxeon LEDs
On Sun, 05 Mar 2006 05:16:51 GMT, Ernest Christley
Andrew Sarangan wrote:
Hello
It was my impression that mounting the LED directly to the reflector
(flashing aluminum) will not provide enough heat sinking. A large
surface area is not the only determining factor because the thermal
conductivity of the metal will limit how far the heat can spread. The
thinner the metal, the worse the thermal conductivity. Flashing
aluminum is only 1/100" thick so its conductivity is not very high. One
could construct fins on the back side to increase the surface area, but
commercial heat sinks do that much better.
I think you have a beautiful design with good tradeoffs, Andrew.
However, if one were inclined to go fanless, there are heatsinks now
that are much lighter will provide much greater surface area. It uses a
much greater number of fins, and each is very thin.
Ernest, it takes cross sectional area to conduct heat; if you look at
the TRULY designed heatsinks to maximize heat transfer to air, you
will note a tapered base with tapered fins, larger and thicker fins
close, smaller and thinner further away.
I am weak in describing this, but I think you will get the picture;
think about holding a piece of aluminum foil 2 inches long in a candle
flame, then a piece of 1/4" aluminum rod in the same flame. Your
fingers won't get warm with the foil, but will burn with the rod.
More LED's Veeduber Home Built 19 June 9th 04 10:07 PM
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 07:51 PM
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 02:10 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
LEDs with Strobe lights pekka1510 Home Built 11 August 31st 03 11:36 PM
