Hi Andrew,
Here is what you do: Put a 0.1 ohm 1 Watt resistor in series with your LEDs between them and ground. Use an LM2904 op amp to amplify the voltage across the 0.1 ohm resistor such that the LM2904 outputs 1.2 VDC when the desired current is flowing through the resistor. The gain resistors you need is something you should be able to figure out. The output of the LM2905 op amp goes to the Feedback input of the LM2576. Best Regards, Dean Wilkinson |
More LED's | Veeduber | Home Built | 19 | June 9th 04 10:07 PM |
Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 07:51 PM |
Building chasing airport lights -- Attn: Jim Weir? | Jay Honeck | Owning | 79 | February 29th 04 02:10 PM |
LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 01:53 AM |
LEDs with Strobe lights | pekka1510 | Home Built | 11 | August 31st 03 11:36 PM |
