I am saying that Houston APPROACH will not hand off outbound VFR's to
Center, and Approach will RARELY accept inboung VFR's as handoff's with regards to flight following. It is particularly frustrating because folks at Regional Approach (Dallas) work the handoff's both ways pretty much 100% of the times I've been there. I personally would much rather be talking to someone, or be in the system. I dont mind taking a vector even though its "voluntary" if it helps me stay separated. And while I dont rely on it, it's nice to have another set of eyes calling pertinent traffic when able The occasions that I have departed from towered fields in the HOU terminal airspace, I have only recieved a local (tower or Tracon) code with regards to VFR flight following. Never a center code, even when they know you are heading out of bounds. The drill is "get terminated, call up the center in a few miles" I apologize for not being more clear in my initial post. Dave John Clonts wrote: "Dave S" wrote in message link.net... I have tried to do such a thing down here in the Houston terminal airspace to try and circumvent a common practice by the TRACON. It didnt work for me. What I did, which I garnered from usenet, was file an IFR plan under DUATS with VFR in the altitude block, and VFR flight following in the remarks section. The rationale was based on the fact that when you are placed in the system from a flight following standpoint, you have to submit nearly the same info that you would to get an IFR plan (pop up or pre-filed). You are assigned a data block just like any other IFR plan, the only diff is that unless in Class B, separation isnt the controllers "fault". Well.. it may work elsewhere, but it does NOT work in Houston. The standard practice in Houston is NO HANDOFFS for VFR's at all. Cant even get a "center" code, rather than a "local" code if you call up early on clearance delivery. If its night, and slow, sometimes I can get Houston to take the handoff coming back IN from the Center's territory but never on the outbound leg. Hello Dave, Regarding VFR flights departing the Houston area... Are you saying that Houston Center will generally not take a VFR handoff from Houston Approach? Or are you saying Approach will not accept a VFR handoff from a tower? Which airport exactly are you talking about, as an example? DWH? SGR? ?? Cheers, John Clonts Temple, Texas N7NZ |
![]() "Dave S" wrote in message link.net... The occasions that I have departed from towered fields in the HOU terminal airspace, I have only recieved a local (tower or Tracon) code with regards to VFR flight following. Never a center code, even when they know you are heading out of bounds. The drill is "get terminated, call up the center in a few miles" We do this as standard procedure because that's what people want. We have found that virtually nobody wants center flight following, less than 5% ask for it, whether on the ground before departure or in the air. |
![]() We have found that virtually nobody wants center flight following, less than 5% ask for it, whether on the ground before departure or in the air. If somebody calls asking for center flight following, do you still assume they dont' want it? Jose -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... We have found that virtually nobody wants center flight following, less than 5% ask for it, whether on the ground before departure or in the air. If somebody calls asking for center flight following, do you still assume they dont' want it? Nope, then we'll give you a center code and hand you off to the center. But you have to ask for it. Simply telling me your destination, which happens to be a long way away, won't do it. |
But you have to ask for it. Simply telling me your destination, which happens to be a long way away, won't do it. What if you saw someone pop up out of Columbia Missouri, heading East. They call you up and inform you they want VFR flight following to Wichita KS. What exactly would you say to him? ;-() |
![]() "Bill Gamelson" wrote in message . com... Nope, then we'll give you a center code and hand you off to the center. But you have to ask for it. Simply telling me your destination, which happens to be a long way away, won't do it. What if you saw someone pop up out of Columbia Missouri, heading East. They call you up and inform you they want VFR flight following to Wichita KS. What exactly would you say to him? ;-() Flight following are the magic words. I work at a class C, you will get a transponder code when you depart VFR. But unless you specifically say you want flight following you will be terminated at 20 miles. |
transponder code when you depart VFR. But unless you specifically say you want flight following you will be terminated at 20 miles. Yea, I know. Obviously you didn't catch that goof. A plane takes off out of Columbia Missouri and heads 090 and then asks for flight following to Wichita KS which is 270. I though you would catch it. I was embarrased when the controller said "Well I'd be happy to...but..there's something I can't quite understand....[10-15 second pause]...I'll tell you what, turn heading 270 and that should get you to Wichita." I was so embarrased I know I literally double-backed on his screen! |
Regional Approach in Dallas does it without being asked.
Houston approach in Houston wont do it, even when asked. Dave Newps wrote: "Teacherjh" wrote in message ... We have found that virtually nobody wants center flight following, less than 5% ask for it, whether on the ground before departure or in the air. If somebody calls asking for center flight following, do you still assume they dont' want it? Nope, then we'll give you a center code and hand you off to the center. But you have to ask for it. Simply telling me your destination, which happens to be a long way away, won't do it. |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 07:47 AM |
IFR flight plan filing question | Tune2828 | Instrument Flight Rules | 2 | July 23rd 03 03:33 AM |
