"Morgans" wrote: "Orval Fairbairn" wrote IIRC, George meant to use a water pump such as used on Merlins or Allisons. he found the automotive pumps to be lacking. I was unaware that a water pump for a Merlin or an Allison would fit on an American V-8! g Really, though, I don't understand what he would be referring to. Is it something like what is commonly used on racing (NASCAR) engines? What companies make something compatible, in that design? I had always thought that special design was needed to get the accessories running at a slower than stock RPM, either by using a smaller than normal drive pulley, or larger than normal accessory pulley. I would think that better bearings would be good things for a water pump. I, also, am not sure what George was referring to. Military engines have standard accessory mountings, so, I am assuming that coolant pumps would simply bolt on to the accessory cases. You would have to add a similar provision to an auto engine. Yes, bearings were the weak point in the auto pumps. |
It sure makes a difference to own your own plane!! | Marco Rispoli | Piloting | 9 | June 29th 04 11:15 PM |
Rental policy | Robert | Piloting | 83 | May 13th 04 05:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
