filing IFR plan for VFR flight conditions
Old May 10th 04, 06:37 PM
Newps
"Greg Esres" wrote in message
Dave, in my opinion what you are describing isn't exactly an IFR
flightplan.
Your co-worker, Don Brown, is hostile towards the procedure for just
this reason. He says that an IFR sqwawk code gets reserved for these
flight plans and sometimes center runs out.
Codes are codes. Centers use the same codes for VFR as for IFR. In the
TRACON we use separate VFR codes and IFR codes.
  #52
Old May 10th 04, 07:58 PM
Ron Natalie
"Dave S" wrote in message link.net...
Filing a VFR plan goes to FSS. Filing an "IFR" plan goes to Center/ATC.
This isnt tooo unlike what is happening in the DC ADIZ, P49 and other
selected locations (Without referring to the specifics, here goes). You
can operate VFR out of there, but you have to have a discreet code and
are in continuous contact with ATC (essentially flight following).
You are in radio contact with ATC, but there is no guarantee of services provided.
  #53
Old May 11th 04, 02:39 AM
Dave S
Read my other posts... some of which you've responded to.
Dave
hlink.net...
Steve...
Do you by any chance fly VFR, in a busy terminal airspace, perhaps
during the "push"? You sure seem to have a hard time grasping some
pretty obvious and simple concepts that I am discussing... or you just
seem determined to ask "why" an awful lot. I'm sorry I am not being
detailed enough to suit your needs.
Dave, I think it's you that's having difficulty grasping the concept. A
previous poster wrote about flying "right over top of Class-C and Class-B"
airspace. He added, "if you talk to them, even if you're clear of their
airspace, they'll try to route you over hell and gone." In my response I
stated that was possibly an error on ATC's part over the top of Class C
airspace and definitely an error on their part over Class B airspace. It's
possibly an error over Class C airspace because Class C services are
provided to participating aircraft in the outer area just as they are in the
Class C airspace proper. Outside of Class B or Class C airspace, or the
outer area associated with Class C airspace, or a TRSA, ATC should not
assign headings, routes altitudes, etc, to VFR aircraft. To do so violates
FAA Order 7110.65, the document which prescribes air traffic control
procedures and phraseology for use by persons providing air traffic control
services. If you've been following the thread, you know we've been
discussing operations outside of these types of airspace. So what is this
"busy terminal airspace" you're referring to?
  #54
Old May 11th 04, 03:07 AM
Steven P. McNicoll
link.net...
Which indicates I've already read them. What would I gain by reading them
again?
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 07:47 AM
IFR flight plan filing question Tune2828 Instrument Flight Rules 2 July 23rd 03 03:33 AM
