clare at snyder.on.ca wrote:
On Tue, 07 Mar 2006 15:36:29 GMT, "ngreader" wrote: "Tony" wrote in message ups.com... Does anyone have a circuit diagram or access to power supplies for Litton G200 Gyros ??? Mfr keeps these under wraps. U R (likely) SOL I used to have a little "dynamotor" inverter that made 400cps 3 phase from 24 volts - have not seen it for a couple of years, *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** I have a dynamotor that weighs about 10 pounds. I use it to power test equipment. Too heavy for aircraft. Dan, U.S. Air Force, retired |
On Tue, 07 Mar 2006 12:14:04 -0600, Dan wrote:
clare at snyder.on.ca wrote: On Tue, 07 Mar 2006 15:36:29 GMT, "ngreader" wrote: "Tony" wrote in message ups.com... Does anyone have a circuit diagram or access to power supplies for Litton G200 Gyros ??? Mfr keeps these under wraps. U R (likely) SOL I used to have a little "dynamotor" inverter that made 400cps 3 phase from 24 volts - have not seen it for a couple of years, *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** I have a dynamotor that weighs about 10 pounds. I use it to power test equipment. Too heavy for aircraft. Dan, U.S. Air Force, retired Mine was less than 5 lbs and came from a plane. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
On Tue, 07 Mar 2006 12:14:04 -0600, Dan wrote: clare at snyder.on.ca wrote: On Tue, 07 Mar 2006 15:36:29 GMT, "ngreader" wrote: "Tony" wrote in message ups.com... Does anyone have a circuit diagram or access to power supplies for Litton G200 Gyros ??? Mfr keeps these under wraps. U R (likely) SOL I used to have a little "dynamotor" inverter that made 400cps 3 phase from 24 volts - have not seen it for a couple of years, *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** I have a dynamotor that weighs about 10 pounds. I use it to power test equipment. Too heavy for aircraft. Dan, U.S. Air Force, retired Mine was less than 5 lbs and came from a plane. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** Mine came from an airplane too, I was intending to mean too heavy in the context of home builts. I have a couple of 26 VAC 400 hz single phase inverters. Handy dandy for synchros. Dan, U.S. Air Force, retired |
Funny story about naval | [email protected] | Naval Aviation | 0 | December 20th 04 03:37 AM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
Winch Experts wanted | Ulrich Neumann | Soaring | 117 | April 5th 04 06:52 AM |
Beech Sundowner strobe power supply location???? | Jack McAdams | Owning | 3 | September 13th 03 09:18 PM |
Disregard - Strobe power supply location question | Jack McAdams | Owning | 0 | September 12th 03 04:12 PM |
