#29
But in the closed system
that consists of the airplane and the atmosphere, or the fan and the air in the room, momentum is conserved, just as mass and energy are. Except that that's not a closed system. You need the earth to close the system. No earth but phantom gravity, and to conserve momentum, the air will continue to downflow, which is what would happen. If only some of it does, then mass is not conserved. ALL of it, or rather an equivalent amount of displaced mass makes it back to the inlet of the fan. No, mass can be conserved by having some of it pile up. This is in fact what happens. The pressure on one side of the room goes up. Guess why. In te case of the aircraft, the fan is moving through the air so that when the air (or rather an equivalent displaced mass of air) returns to the inlet, the inlet has move on. In the case of the aircraft (propeller), the air does not return to the inlet. It keeps on being blown back, since there is no wall to stop it. The momentum stays with the air and the earth (which starts to spin a little one way) until the airplane lands, and pushes the earth the other way. Momentum is always conserved. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
