The Impossibility of Flying Heavy Aircraft Without Training
  #37
Old March 8th 06, 12:29 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default lift, wings, and Bernuolli
But in the closed system
that consists of the airplane and the atmosphere, or the fan and
the air in the room, momentum is conserved, just as mass and
energy are.
Except that that's not a closed system. You need the earth to close the
system. No earth but phantom gravity, and to conserve momentum, the air
will continue to downflow, which is what would happen.
If only some of it does, then mass is not conserved. ALL of it,
or rather an equivalent amount of displaced mass makes it
back to the inlet of the fan.
No, mass can be conserved by having some of it pile up. This is in fact
what happens. The pressure on one side of the room goes up. Guess why.
In te case of the aircraft, the fan is moving through the air so that
when the air (or rather an equivalent displaced mass of air) returns
to the inlet, the inlet has move on.
In the case of the aircraft (propeller), the air does not return to the
inlet. It keeps on being blown back, since there is no wall to stop it.
The momentum stays with the air and the earth (which starts to spin a
little one way) until the airplane lands, and pushes the earth the other
way. Momentum is always conserved.
Jose
Money: what you need when you run out of brains.
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 05:45 AM
