In order to lift an object by moving air, you need to create enough
force. Force is equal to a change in momentum with respect to time. That is, you can think of force as being equal to changing the momentum of a constant mass at a constant rate of acceleration (F = ma), *or* you can think of it as applying a constant speed change to a flow of mass (F = m/s * v). But as long as multiplying the two together gives you the same total force, it does matter from a momentum perspective. Alan: Does this mean that a helicopter in hover is continuously pushing down a mass of air equal to the weight of the aircraft? The corollary is that a rotary wing or fixed wing aircraft in unaccelerated flight is displacing a mass of air equal to its weight, i.e., it is not flying because of low pressure above the wing but because of the upward force on the airfoil from the displacement of air downward. True? Russell Thorstenberg Houston, Texas |
Propellors for sale | Jean-Paul Roy | General Aviation | 0 | July 15th 04 02:33 PM |
Propellors for sale | Jean-Paul Roy | Owning | 0 | July 15th 04 02:32 PM |
Inflatable Rotors (Flying Car?) | Ken Sandyeggo | Home Built | 13 | August 6th 03 06:37 AM |
Inflatable Rotors (Flying Car?) | Ken Sandyeggo | Rotorcraft | 2 | August 6th 03 06:37 AM |
Inflatable Rotors (Flying Car?) | Mark Hickey | Rotorcraft | 4 | August 1st 03 05:20 AM |
