Commercial rating?
Old March 8th 06, 04:37 PM posted to rec.aviation.piloting
Default Commercial rating?
Changing a tire on an airplane requires removal of the brake
assembly, perhaps splitting the wheel halves and installing
the new tire on the old wheel and properly torquring the
wheel bolts. Then the wheel must be installed after packing
the cleaned and inspected wheel bearing.
Changing a tire on an airplane is more like changing the
front hub on a car.
The FAA assumes that all work allowed under the term,
"preventative maintenance" by a private pilot will be done
using the tools, techniques and procedures as a licensed A&P
would use. On my car, I can do just as most oil change
shops do, get under the vehicle, remove the drain plug,
remove the old oil filter, reinstall the drain plug, install
a new oil filter, then pour 4 or 5 quarts of oil in the
engine. An aircraft oil change requires the additional
steps of cleaning oil screens and inspecting for metal and
cutting the old oil filter open and examining the paper for
metal.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Matt Barrow" wrote in message
| "Jim Macklin" wrote
in message
| news:JktPf.116461$QW2.88175@dukeread08...
| The FAA lawyers make the rules. For instance, a brand
new
| private pilot may change a tire, but cannot work on the
| brakes on the same wheel.
| My wife and daughter can change a tire on the car, but
neither of them could
| do a brake job on those cars.
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
Commercial rating: Am I wrong here? gatt Piloting 12 November 21st 05 12:35 AM
Skip the IR rating and go straight to commercial and CFI? [email protected] Piloting 17 May 20th 05 02:50 AM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 04:49 PM
