ASW20A and Cirrus
Old March 11th 06, 08:18 PM posted to rec.aviation.soaring
Default ASW20A and Cirrus
At 17:00 11 March 2006, Eric Greenwell wrote:
Rowan Griffin wrote:
There's probably a scare story for every glider made,
so read about it and learn from other people's mistakes...ASW20
elevator works perfectly if you remember to connect
it,
I urge you to consider a B or C models. I know many
people - all
experienced pilots - that took off with the elevator
not connected in an
ASW 20. It's just an ASW 20 problem, of course. I think
it's a lot
easier to deal with a disconnected flap or aileron,
and it seems these
are much less likely to be overlooked.
snip
Only ever wire launched it, which it does well. BUT
it is extremely important to make sure that the flap
lever is fully engaged with the gate (and that is
unworn),
as there have been serious accidents where the flaps
have slipped into full landing on the wire, causing
an immediate stall...I have heard of the same thing
happening on the airtow ground run, though with less
dramatic outcome.
Do you mean the flaps slipped into a high speed position?
It takes a
fair amount of force to pull the flaps into the landing
position, but
they will slide easily forward into a negative flap
position. This will
reduce the lift and cause the glider to descend, which
might look like a
stall. Regardless, having the flap handle move itself
to a new position
is a bad thing!
You have to be correct there - thinking about it, the
flap handle would want to fly forward. I didn't witness
the accident I was thinking of but the glider was observed
doing a snap roll on the wire and crashing inverted
- maybe the pilot reacted to the sudden loss of lift
by hauling the stick back?
Get a carbon sparred wing one - the others feel like
they come pre filled with water ballast, seriously!
Frankly, most ASW 20 pilots consider the bendy wings
a real asset and
part of their charm! It was one of the reasons it was
so popular with
the ridge runners on the Alleghenies: those bendy wings
give it a
smoother, more comfortable ride in turbulence. I certainly
enjoyed the
smooth ride in my ASW 20C, and was a bit disappointed
that the carbon
fiber wing of my ASH 26 E wasn't so forgiving. It's
still bendy compared
to many gliders, but not like the ASW 20 and 20 C.
Regardless, I know the ASW 20 and 20 C did not have
carbon fiber spars,
and I'm pretty sure the B didn't either. The B model
did have much
heavier wings because of the extra fiberglass to needed
carry the extra
water ballast it was rated for, but I think was mostly
due to thicker
wing skins. Should you decide on an ASW 20 model, and
you don't need the
extra wing loading, go for a C model.
I fully agree with you about the bendy wing, it was
the sheer weight of rigging I was referring to. The
one I flew had much heavier wings than another I helped
rig some years later and I was told it had a carbon
spar??
Change 'netto' to 'net' to email me directly
www.motorglider.org - Download 'A Guide to Self-launching
Sailplane
Operation'
Old March 12th 06, 12:51 AM posted to rec.aviation.soaring
Default ASW 20 wire launch accident.
I didn't witness the accident I was thinking of but
the glider was observed doing a snap roll on the wire
What you have described is a stall /spin while during a winch launch.
Caused by too high an angle of attack -- for what ever reason.
Old March 12th 06, 02:54 AM posted to rec.aviation.soaring
spar??
The C model, which I flew for 11 years, did not have a carbon spar. It's
wing was the same weight (and structurally the same) at the original ASW
20 (sometimes called the A model). The wing had a different airfoil,
blow-hole turbulators, mylar control gap fairings, and only a 40 degree
landing flap. Also, it had the automatic hookup elevator, a shock
absorbing gear design with a 500 x 5 wheel and a disk brake.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
ASW20A and Cirrus Jeff Runciman Soaring 4 March 12th 06 05:06 PM
