I have not flown a Schempp Hirth design with an all
flying tail (stabilator), but I've flown my LS1-d, which does have an all flying tail, for over 10 years, and you can trim it and let go of the stick. No problem. If I need both hands to open a snack or change my sunglasses to my clear glasses, I can easily set up the ship to fly itself. You don't have to 'mind the store' every second. I haven't tried this above 60 knots, but below 60 knots, there is no problem. And because it trims nicely at 75 knots, I'm sure it wouldn't be a problem to let go of the stick for a few seconds at that speed either. Usually, I only need to let go for a couple of seconds. It doesn't take long to peel a banana or open a pack of 'nabs.' Ray Lovinggood Happy Owner of LS1-d s/n 27, 'W8' At 00:00 21 March 2006, Robert Hart wrote: Jeff Runciman wrote: Thank you for all of your help. It turns out the ASW is 50,000. The Cirrus makes me a bit nervous with the tail (attaching and flying) I've not had much to do with Cirrus's - but I have had to deal with the same all flying tail plane on a borrowed Nimbus 2 whilst my 2c was in for repairs (see http://www.hart.wattle.id.au/alice/a...ice3mar04.html). I too was somewhat twitched at the stories I had heard about the all flying tail and its sensitivity, so my first launch had me waiting in some apprehension - which was completely unwarranted. Whilst the all flying tail does mean that you shouldn't let go off the stick at high speed (or even for long at low speed) it does not make the aircraft unstable in pitch. It's certainly more sensitive in pitch and PIOs are easier to do - but remember a PIO is a PILOT induced oscillation and not a problem with the aircraft! As for rigging and making sure the elevator is correctly attached, it is a bit difficult at first, but after a couple of goes it didn't present a great problem. I did however do an extremely careful loaded control check as part of the DI (get someone to hold the all flying tail to restrict its movement and then firmly move the control column) to ensure that it truly was attached and not just 'resting'! I would suggest you don't rule out a Cirrus just because of the 'stories' about the all flying tail. It is my experience that these are exaggerated - but do of course contain a kernel of truth as noted above! Robert |
Ray Lovinggood wrote:
I haven't tried this above 60 knots, but below 60 knots, there is no problem. And because it trims nicely at 75 knots, I'm sure it wouldn't be a problem to let go of the stick for a few seconds at that speed either. Usually, I only need to let go for a couple of seconds. It doesn't take long to peel a banana or open a pack of 'nabs.' It isn't a trim issue on the Std Cirrus, it is a G induced control movement. It does not have a "balanced" elevator drive mechanism, meaning a positive G surge tends to _increase_ the amount of "up" elevator, which tended to increase the G loading, which ... you get the idea. You can feel the stick reacting to bumps and surges as you fly it a higher speeds. That was why letting go of the stick a speeds over 80 mph in my Std Cirrus was most unwise. At lower speeds, especially thermalling, no problem. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Eric Greenwell wrote:
Ray Lovinggood wrote: I haven't tried this above 60 knots, but below 60 knots, there is no problem. And because it trims nicely at 75 knots, I'm sure it wouldn't be a problem to let go of the stick for a few seconds at that speed either. Usually, I only need to let go for a couple of seconds. It doesn't take long to peel a banana or open a pack of 'nabs.' It isn't a trim issue on the Std Cirrus, it is a G induced control movement. It does not have a "balanced" elevator drive mechanism, meaning a positive G surge tends to _increase_ the amount of "up" elevator, which tended to increase the G loading, which ... you get the idea. You can feel the stick reacting to bumps and surges as you fly it a higher speeds. That was why letting go of the stick a speeds over 80 mph in my Std Cirrus was most unwise. At lower speeds, especially thermalling, no problem. You can release the stick for short periods in a Std Cirrus. It is not a fearsome beastie that will bite the moment it is not being actively controlled. There is no stick free stability, so if you let go for any length of time the airspeed will slowly diverge into a phugoid. On mine the amplitude also slowly increases. Turbulence can trigger sharper divergences, but you would surely not be flying hands off in this situation... Often the best way to improve thermal centering is to stop flying - in my case the Cirrus is generally better at grooving a thermal than me, the lighter touch really works a lot better. If you like to make big positive control movements before antything happens get a Grob 103... At high speed it is a different matter. Again I find the pro-disturbance movement helps. You get an automatic "mini pull up" in any good surge of lift. If you want to take it you follow through, if not you correct. The Jantar is apparently also nice and light on the controls. WOuld not go wrong with one of those either. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
One thing non of you guys mention is you need to replace the trim
springs on the all flying tail models. a buddy at minden did that on his Nimbus 2. By replacing the 70's vintage worn out stretched trim springs with new one it changed the glider. He could let go of the stick and it would not go divergent on him for extended periods. Anyone buying of flying an all flying tail Schemp anything should replace the trim springs. Regards Al http://www.gliderforum.com |
At various times I have owned a Cirrus 75 and a Nimbus
2, both with all flying tailplanes. Interestingly we once compared the Nimbus 2 tailplane to that belonging to an adjacent Standard Cirrus in the workshop during a C of A and found they were exactly the same. The Nimbus has a much longer tail boom though. The tailplane usually either goes on properly, or jams in the up position if you fail to engage the elevator drive hook, so it is obvious if you have got it wrong. As for all types a positive control check is recommended before flight. The Nimbus was definitely the twitchier of the two types as it seemed to suffer from aero-elasticity, i.e. if you pulled back on the stick the wings bent up first and then the fuselage followed about a second later. Nevertheless I found it quite easy to fly and even did some cloud climbs in it. By comparison the Standard Cirrus was very easy to fly, subject to the usual provisos for all-flying tailplanes. Don't be put off this lovely glider by all the scare stories! Derek Copeland ------------------------- At 00:00 21 March 2006, Robert Hart wrote: Jeff Runciman wrote: Thank you for all of your help. It turns out the ASW is 50,000. The Cirrus makes me a bit nervous with the tail (attaching and flying) I've not had much to do with Cirrus's - but I have had to deal with the same all flying tail plane on a borrowed Nimbus 2 whilst my 2c was in for repairs (see http://www.hart.wattle.id.au/alice/a...ice3mar04.html). I too was somewhat twitched at the stories I had heard about the all flying tail and its sensitivity, so my first launch had me waiting in some apprehension - which was completely unwarranted. Whilst the all flying tail does mean that you shouldn't let go off the stick at high speed (or even for long at low speed) it does not make the aircraft unstable in pitch. It's certainly more sensitive in pitch and PIOs are easier to do - but remember a PIO is a PILOT induced oscillation and not a problem with the aircraft! As for rigging and making sure the elevator is correctly attached, it is a bit difficult at first, but after a couple of goes it didn't present a great problem. I did however do an extremely careful loaded control check as part of the DI (get someone to hold the all flying tail to restrict its movement and then firmly move the control column) to ensure that it truly was attached and not just 'resting'! I would suggest you don't rule out a Cirrus just because of the 'stories' about the all flying tail. It is my experience that these are exaggerated - but do of course contain a kernel of truth as noted above! Robert |
Don't overlook that Derek Copeland is large and very heavy.
C. of G. position makes a lot of difference to the feel and stability of any glider. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Derek Copeland" wrote in message ... At various times I have owned a Cirrus 75 and a Nimbus 2, both with all flying tailplanes. Interestingly we once compared the Nimbus 2 tailplane to that belonging to an adjacent Standard Cirrus in the workshop during a C of A and found they were exactly the same. The Nimbus has a much longer tail boom though. The tailplane usually either goes on properly, or jams in the up position if you fail to engage the elevator drive hook, so it is obvious if you have got it wrong. As for all types a positive control check is recommended before flight. The Nimbus was definitely the twitchier of the two types as it seemed to suffer from aero-elasticity, i.e. if you pulled back on the stick the wings bent up first and then the fuselage followed about a second later. Nevertheless I found it quite easy to fly and even did some cloud climbs in it. By comparison the Standard Cirrus was very easy to fly, subject to the usual provisos for all-flying tailplanes. Don't be put off this lovely glider by all the scare stories! Derek Copeland ------------------------- |
W.J. (Bill) Dean (U.K.). wrote:
Don't overlook that Derek Copeland is large and very heavy. C. of G. position makes a lot of difference to the feel and stability of any glider. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. Hi Bill You are right - My partner in the Cirrus is a lot less comfortable - he is 80kg. Conversely, maybe that's why I (110Kg) am so comfortable in the Cirrus. CG is deffinitely "forward" with me in front. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
Derek Copeland wrote:
By comparison the Standard Cirrus was very easy to fly, subject to the usual provisos for all-flying tailplanes. Don't be put off this lovely glider by all the scare stories! When a number of experienced pilots, some of them CFIGs, and some with thousands of hours, who have flown a variety of gliders, issue warnings about a particular glider, that rises above the level of "scare stories". For example, you do not hear this controversy over the LS4. These warnings should be respected and considered carefully, especially if you are a less experienced pilot. The Std. Cirrus is not an LS4 with a quirk or two. For clarification, the Std Cirrus I refer is not the Cirrus 75, but the older models called "Standard Cirrus". The Cirrus 75 had a number of changes, such as better airbrakes, and I am not familiar with it. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Er!...something about the pot calling the kettle black
Bill? My normal weight is in the 14 to 15 stone range, but due to an even larger and heavier syndicate partner who fitted quite a lot of lead to the back of the Nimbus so that he could trim it out when thermalling, I was actually flying the Nimbus pretty close to the minimum cockpit weight limit. Still handled OK though. Derek Copeland ------------------------ At 13:18 21 March 2006, W.J. \bill\ Dean \u.K.\. wrote: Don't overlook that Derek Copeland is large and very heavy. C. of G. position makes a lot of difference to the feel and stability of any glider. W.J. (Bill) Dean (U.K.). Remove 'ic' to reply. 'Derek Copeland' wrote in message ... At various times I have owned a Cirrus 75 and a Nimbus 2, both with all flying tailplanes. Interestingly we once compared the Nimbus 2 tailplane to that belonging to an adjacent Standard Cirrus in the workshop during a C of A and found they were exactly the same. The Nimbus has a much longer tail boom though. The tailplane usually either goes on properly, or jams in the up position if you fail to engage the elevator drive hook, so it is obvious if you have got it wrong. As for all types a positive control check is recommended before flight. The Nimbus was definitely the twitchier of the two types as it seemed to suffer from aero-elasticity, i.e. if you pulled back on the stick the wings bent up first and then the fuselage followed about a second later. Nevertheless I found it quite easy to fly and even did some cloud climbs in it. By comparison the Standard Cirrus was very easy to fly, subject to the usual provisos for all-flying tailplanes. Don't be put off this lovely glider by all the scare stories! Derek Copeland ------------------------- |
Cirrus demo | Dan Luke | Piloting | 12 | December 4th 05 05:26 AM |
New G-1000 182 & Cirrus SR-22 GTS | Dan Luke | Owning | 22 | June 27th 05 07:18 PM |
New G-1000 182 & Cirrus SR-22 GTS | Dan Luke | Piloting | 24 | June 27th 05 07:18 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
