Winglets
Old March 13th 06, 12:18 AM posted to rec.aviation.piloting
Default Winglets
Most winglets I've seen point upward, but thinking about the physics of
the things, if they had to extend in only one direction wouldn't down
be better, and wouldn't a plate -- extending both up and down, be best
for sub sonic flight?
Old March 13th 06, 01:29 AM posted to rec.aviation.piloting
Default Winglets
be better
Not on a crosswind landing.
Jose
Money: what you need when you run out of brains.
Old March 13th 06, 02:32 AM posted to rec.aviation.piloting
Default Winglets
"Tony" wrote in message
Ground clearance, for one. As for your latter, that would be like a vortex
generator such as Bonanza wings have.
Old March 13th 06, 03:23 AM posted to rec.aviation.piloting
Default Winglets
According to something I read somewhere :-) either up or down
winglets (or tiplets if you prefer) accomplilsh the same thing with
the same efficiency... increase the effective wingspan of the
aircraft. Most commercial aircraft (Boeing, Airbus, etc.) turn them
up for ground clearance.
Don't know about tip plates.
Ron
Old March 13th 06, 03:46 AM posted to rec.aviation.piloting
Default Winglets
It seems to me tip plates would remove wing tip effects completely:
airflow would be along the chord all the way to the plate. I'd expect
the tip vortex effects one often sees would no longer exist.
Old March 13th 06, 04:58 AM posted to rec.aviation.piloting
Default Winglets
The plate would have to big enough to block most of the tip flow in order to
be effective. That would be a fairly large tip plate and may have other
consequences such as directional stability. I used to tow banners in
modified Super Cibs with tip fences. The fences were about about 4 inches
bigger than the chord profile and did very little in reality.
D.
Old March 13th 06, 12:47 PM posted to rec.aviation.piloting
Default Winglets
Ron
Airbus has plates that go both up and down at the end......
Michelle
Old March 13th 06, 08:35 AM posted to rec.aviation.piloting
Default Winglets
Take a look at some models of Airbus - they have winglets that extend
both above and below the wingtip.
Dylan Smith, Port St Mary, Isle of Man
Flying: http://www.dylansmith.net
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Frontier Elite Universe: http://www.alioth.net
Old March 13th 06, 03:55 PM
Chris Wells Chris Wells is offline
Senior Member
First recorded activity by AviationBanter: Oct 2005
I've seen a lot of discussion on this topic in radio-controlled plane groups, and I've been working out winglet design on the r/c planes I've built for years. I've also seen the results of tests done by laboratories. (on the internet somewhere, hunt & I'm sure you'll find them) I think it's pretty well established that upwards is better, though a small projection on the bottom seems to be a good thing.
The way the tip transitions into the winglet is probably just as important as the shape of the winglet itself. I've had several flying wings that flew well without winglets or any vertical surfaces at all, by shaping the tips. The stock wings, with squared-off tips, don't fly well at all without the winglets.
Of course, if someone can provide evidence of an advantage for downward-pointing tips (other than non-aeronautical reasons such as LG convenience, such as on the Quickie) I'd like to see it.
Old March 14th 06, 04:42 AM posted to rec.aviation.piloting
Default Winglets
On Mon, 13 Mar 2006 15:55:21 +0000, Chris Wells
Well, the XB-70 Valkyrie is the only example I can come up with at
the moment. Although the wing tips in this case were more for
increase lift, reduced drag and increased speed at sub-sonic and
supersonic speeds.
See: http://www.labiker.org/xb70.html#compression
Ron
winglets bagmaker Soaring 25 March 3rd 06 10:39 PM
Discus Winglets Peter F Soaring 8 December 12th 05 04:29 AM
winglets for LS-1 Brad Soaring 4 October 26th 04 06:11 PM
ASW20L extentions with winglets? goneill Soaring 6 September 17th 04 10:28 PM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
