Winglets
Old March 13th 06, 03:23 AM posted to rec.aviation.piloting
Default Winglets
On 12 Mar 2006 16:18:44 -0800, "Tony" wrote:
Most winglets I've seen point upward, but thinking about the physics of
the things, if they had to extend in only one direction wouldn't down
be better, and wouldn't a plate -- extending both up and down, be best
for sub sonic flight?
According to something I read somewhere :-) either up or down
winglets (or tiplets if you prefer) accomplilsh the same thing with
the same efficiency... increase the effective wingspan of the
aircraft. Most commercial aircraft (Boeing, Airbus, etc.) turn them
up for ground clearance.
Don't know about tip plates.
Ron
Old March 13th 06, 03:46 AM posted to rec.aviation.piloting
Default Winglets
It seems to me tip plates would remove wing tip effects completely:
airflow would be along the chord all the way to the plate. I'd expect
the tip vortex effects one often sees would no longer exist.
Old March 13th 06, 04:58 AM posted to rec.aviation.piloting
Default Winglets
"Tony" wrote in message
The plate would have to big enough to block most of the tip flow in order to
be effective. That would be a fairly large tip plate and may have other
consequences such as directional stability. I used to tow banners in
modified Super Cibs with tip fences. The fences were about about 4 inches
bigger than the chord profile and did very little in reality.
D.
Old March 13th 06, 12:47 PM posted to rec.aviation.piloting
Default Winglets
Ron
Airbus has plates that go both up and down at the end......
Michelle
winglets bagmaker Soaring 25 March 3rd 06 10:39 PM
Discus Winglets Peter F Soaring 8 December 12th 05 04:29 AM
winglets for LS-1 Brad Soaring 4 October 26th 04 06:11 PM
ASW20L extentions with winglets? goneill Soaring 6 September 17th 04 10:28 PM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
